2003-06-06 | 2003-06-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* automake/local.am: Remove $(ARCH), clean-local. | |||||
2003-05-27 | 2003-05-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+9 | |
PR 321: * aclocal/check-bsp-cache.m4: Remove support for profile-variant. * aclocal/env-rtemsbsp.m4 * automake/compile.am * automake/host.am * automake/local.am | |||||
2003-05-16 | 2003-05-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+6 | |
* aclocal/check-cxx.m4: Remove LIBSUFFIX_VA. * automake/compile.am: Remove LIBSUFFIX_VA. Merger from rtems-4-6-branch. | |||||
2003-04-17 | 2003-04-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* VERSION: Updated to rtems-ss-20030417. | |||||
* aclocal/version.m4: Updated to rtems-ss-20030417. | |||||
2003-04-11 | 2003-04-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* VERSION: Updated to rtems-ss-20030411. | |||||
* aclocal/version.m4: Updated to rtems-ss-20030411. | |||||
* VERSION: Updated to rtems-ss-20020411. | |||||
* aclocal/version.m4: Updated to rtems-ss-20020411. | |||||
2003-03-25 | Merger from rtems-4-6-branch. | Ralf Corsepius | 1 | -0/+55 | |
2003-02-15 | 2003-02-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* Makefile.am: Remove references to obsoleted files aclocal/enable-gcc28.m4, aclocal/enable-libcdir.m4. | |||||
2003-02-15 | 2003-02-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -6/+0 | |
* ChangeLog: Take out bogus ppc changelog entry. | |||||
2003-02-14 | 2003-02-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+5 | |
* README.configure, aclocal/rtems-cpu-subdirs.m4: Remove a29k references. | |||||
2003-02-14 | 2003-02-14 Till Straumann <strauman@slac.stanford.edu> | Joel Sherrill | 1 | -0/+6 | |
PR 347/rtems * rtems/powerpc/registers.h (PPC_Set_decrementer): Correct inline assembly so it correctly generates on newer gcc's. | |||||
2003-02-14 | Fix ChangeLog. | Ralf Corsepius | 1 | -8/+0 | |
2003-02-14 | Merger from rtems-4-6-branch. | Ralf Corsepius | 1 | -0/+12 | |
2003-02-11 | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+6 | |
* bootstrap: Remove attempts to detect autoconf and automake using "which" (PR 325). | |||||
2003-02-07 | 2003-02-06 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* README.configure: Updated to reflect new BSPs and deprecated targets. | |||||
2003-01-28 | 2003-01-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* VERSION: Updated to rtems-ss-20030128. | |||||
* aclocal/version.m4: Updated to rtems-ss-20030128. | |||||
2003-01-21 | 2003-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* automake/compile.am: Remove CLEAN_DEPEND (Unused). Remove CLOBBER_DEPEND (Unused). | |||||
2003-01-20 | 2003-01-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* automake/local.am: Remove distclean-local. | |||||
2003-01-16 | 2001-01-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* aclocal/rtems-cpu-subdirs.m4: Print out RTEMS_CPU in error message. * aclocal/enable-cxx.m4: Use $enable_cxx instead of $enableval. | |||||
2002-12-19 | 2002-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* aclocal/prog-cxx.m4: Remove RTEMS_PROG_CXX. Rework RTEMS_PROG_CXX_FOR_TARGET. | |||||
2002-12-12 | 2002-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* automake/compile.am: Remove creating $(ARCH) in compilation rules. | |||||
* configure.ac: Require autoconf >= 2.57 and automake-1.7.2. | |||||
2002-12-10 | 2002-12-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* aclocal/prog-cxx.m4: Swap RTEMS_CHECK_TOOL/AC_PROG_CXX. | |||||
2002-12-09 | 2002-12-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* bootstrap: Require autoconf 2.54 or 2.57. Require automake-1.7.2. | |||||
2002-12-07 | 2002-12-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+6 | |
* aclocal/bsp-configure.m4: Remove RTEMS_CHECK_BSP_CACHE. * aclocal/env-rtemsbsp.m4: Add comments to AC_ARG_VARs. Add AC_ARG_VAR(RTEMS_CPU_MODEL). | |||||
2002-12-06 | 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* automake/compile.am: Rework *FLAGS, AM_*FLAGS handling. | |||||
2002-12-06 | 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+7 | |
* automake/compile.am: Remove hard-coded *_PROFILE_V. Add autoconf-supplied CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V, CFLAGS_PROFILE_V. Remove CPPFLAGS_GCC. | |||||
* aclocal/env-rtemsbsp.m4: Add AC_ARG_VAR for CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V, CFLAGS_PROFILE_V, RTEMS_BSP_FAMILY. * aclocal/prog-cc.m4: Reworked CFLAGS handling. * aclocal/prog-cxx.m4: Reworked CXXFLAGS handling. | |||||
* aclocal/rtems-flags.m4: New. | |||||
2002-12-04 | 2002-12-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* bootstrap: Allow autoconf-2.57. | |||||
2002-12-01 | 2002-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* aclocal/prog-cc.m4: Remove GCCSED. | |||||
2002-12-01 | 2002-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+9 | |
* automake/compile.am: Remove LDFLAGS_INCOMPLETE. Remove LDFLAGS. Add CCAS, CCASCOMPILE. Remove compilation rules for *.cpp, *.cxx, *.C. Use CCASCOMPILE to compile *.S. Add -pg to RTEMS_CFLAGS_PROFILE_V. | |||||
2002-11-29 | 2002-11-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Remove c/make. | |||||
2002-11-29 | 2002-11-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+7 | |
* aclocal/prog-ccas.m4: New. * aclocal/check-custom-bsp.m4: New, split out from check-bsps.m4. * aclocal/check-bsps.m4: Split out RTEMS_CHECK_CUSTOM_BSP. * aclocal/canonicalize-tools.m4: Remove RTEMS_GCC_PRINT. | |||||
2002-11-20 | 2002-11-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* acinclude.m4: Conditionally append --target=. | |||||
2002-11-20 | 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* aclocal/quoting.m4: Reworked (Part of fix to PR 312). | |||||
2002-11-19 | 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+6 | |
* automake/compile.am: Remove LD_PATHS (Unused). * aclocal/check-newlib.m4: Adaptation to autoconf-2.5x (AC_TRY_LINK is announced obsolete). | |||||
2002-11-19 | 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Reflect having removed aclocal/sysv-ipc.m4. | |||||
2002-11-19 | 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* aclocal/sysv-ipc.m4: Remove (Unused). * aclocal/target.m4: Sync with acinclude.m4 (Part of fix to PR 312). | |||||
* acinclude.m4: Lots of changes addressing PR 312. | |||||
2002-11-19 | 2002-11-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+9 | |
* aclocal/target.m4: Apply RTEMS_CONFIGURE_ARGS_QUOTE (Part of fix to PR 312). | |||||
2002-11-18 | 2002-11-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* VERSION: Updated to rtems-ss-20021118. | |||||
* aclocal/version.m4: Updated to rtems-ss-20021118. | |||||
2002-11-18 | 2002-11-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+5 | |
* aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Added support for Motorola MTX603e. | |||||
2002-11-18 | 2002-11-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* acinclude.m4: Use AS_IF instead of if/then/else/endif. * configure.ac: Ditto. | |||||
2002-11-15 | 2002-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+6 | |
* automake/compile.am: Remove CFLAGS_DEBUG_OPTIMIZE_V, CXXFLAGS_DEBUG_OPTIMIZE_V, LDFLAGS_DEBUG_V, CFLAGS_DEFAULT. Support @CFLAGS@, @CXXFLAGS@. |
