path: root/ChangeLog (follow)
* 2006-11-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-11-151-0/+4
| | | | * ampolish3: New.
* 2006-10-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-10-191-0/+7
| | | | | | | * configure.ac: Remove all macro implementations and use only the static inline. Static inline functions are now well supported so there is no reason for duplicate maintenance. * aclocal/enable-inlines.m4: Removed.
* 2006-10-18 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-10-181-0/+5
| | | | | * aclocal/rtems-top.m4: Remove RTEMS_API. * aclocal/version.m4: Add RTEMS_API. Bump RTEMS_API to 4.8.
* 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-10-171-0/+4
| | | | * aclocal/version.m4: Bump version to 4.7.99.0.
* changesRalf Corsepius2006-10-171-0/+4
* 2006-08-09 Kolja Waschk <waschk@telos.de>Joel Sherrill2006-08-091-0/+4
| | | | * config-ml.in: New port to Altera NIOS II.
* added ChangeLog entries for PR1117/1118/1119/1120Thomas Doerfler2006-07-141-0/+5
* 2006-06-23 Worth Burruss <worth@motioncontrol.org>Joel Sherrill2006-06-231-0/+4
| | | | * README.configure: Add mcf5235.
* 2006-04-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-04-191-0/+4
| | | | * VERSION: Updated to rtems-4.6.99.3.
| | | | * aclocal/version.m4: Updated to rtems-4.6.99.3.
* 2006-04-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-04-191-3/+3
| | | | * release_support: Fix typos.
* 2006-04-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-04-191-4/+0
* 2006-04-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-04-181-0/+4
* 2006-03-09 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2006-03-091-0/+4
| | | | * acinclude.m4: Requires autoconf-2.59.
* 2006-03-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-03-071-0/+5
| | | | | PR 694/rtems * release_support: Do not include .cvsignore files in release tarballs.
* 2006-02-01 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2006-02-011-0/+5
| | | | | PR 882/make_build * bootstrap: Only remove bspopts.h.in instead of bspopts.h*.
* 2006-01-12 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2006-01-121-0/+2
| | | | | * aclocal/bsp-alias.m4: Revert Joel's 2006-01-10 change. Alpha-sort the aliases list.
* 2006-01-12 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2006-01-121-0/+5
| | | | | * automake/host.am, automake/local.am, automake/subdirs.am: Remove depend-am, depend-recursive.
* 2006-01-10 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-01-101-0/+4
| | | | * aclocal/bsp-alias.m4: Add sis as alias of erc32.
* 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2006-01-091-0/+7
| | | | | | | * aclocal/bsp-alias.m4: Remove brs5l. Remove leon2. Alias leon1 to leon2. Add sis. * aclocal/check_bsps.m4: Remove brs5l. Remove leon. Add leon2. Add sis to erc32 family.
* 2005-11-31 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-12-311-0/+6
| | | | | | PR 851/bsps * aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add gen5200 BSP family.
* Fixed formattingJoel Sherrill2005-11-071-2/+2
* 2005-11-03 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-031-0/+4
| | | | * aclocal/check-bsps.m4: Add the plethora of mbx* BSP.
* 2005-09-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2005-09-021-0/+4
| | | | * VERSION: Updated to rtems-4.6.99.2.
* 2005-09-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2005-09-021-8/+0
| | | | * aclocal/version.m4: Updated to rtems-4.6.99.2.
* 2005-09-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2005-09-021-2/+2
* 2005-07-06 Philippe SimonsPhilippe Simons2005-07-071-0/+4
| | | | * MAINTAINERS: Added me as arm/gp32 bsp maintainer.
* 2005-04-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2005-04-281-0/+5
| | | | | * README.configure: Updated to account for removal of dmv177 and ppcn_60x as well as other additions and deletions.
* 2005-02-04 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-02-041-0/+4
| | | | * aclocal/enable-itron.m4: Allow unix.
* 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-021-0/+4
| | | | * Makefile.am: Remove ACLOCAL_FILES.
* 2004-11-16 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-11-161-0/+5
| | | | | * aclocal/check-bsps.m4: Use ls instead of globs to pickup bsp_specs.
* 2004-11-12 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-11-121-0/+5
| | | | | * aclocal/check-bsps.m4: Add MVME2100 BSP as alias of motorola_shared.
* 2004-11-10 Joel Sherrill <joel@oarcorp.com>Joel Sherrill2004-11-101-0/+4
| | | | * aclocal/bsp-alias.m4: Add MVME2100 BSP as alias of motorola_shared.
* 2004-10-22 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-10-221-0/+4
| | | | * alocal/check-custom-bsp.m4: Reflect new location of bspkit*cfg.
* 2004-10-18 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-10-181-0/+6
| | | | | | * aclocal/check-bsps.m4: Add bspkit support. Don't check for presence of *.cfg. * aclocal/check-custom-bsp.m4: Add bspkit support.
* 2004-10-18 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-10-181-0/+4
| | | | * aclocal/enable-bare.m4: Remove.
* 2004-09-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-09-291-0/+5
| | | | | * MAINTAINERS, README.configure, c/ACKNOWLEDGEMENTS, c/TOOL_TARGETS: i960 obsoleted and all references removed.
* 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-09-241-0/+4
| | | | * configure.ac: Require automake > 1.9.
| | | | * aclocal/rtems-cpu-subdirs.m4: Remove (unused).
* 2004-08-18 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-08-181-0/+7
| | | | | | PR 673/make_build * config-ml.in: Quote 'cd "${ml_origdir}"'. Quote 'cd "${ML_POPDIR}"'.
* 2004-08-17 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-08-181-1/+5
| | | | * acinclude.m4 (_RTEMS_CONFIG_SUBDIR): Quote ac_popdir uses.
* Removing message from cut release trial.Joel Sherrill2004-07-291-8/+0
* 2004-07-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-07-281-0/+4
| | | | * VERSION: Updated to rtems-4.6.99.1.
| | | | * aclocal/version.m4: Updated to rtems-4.6.99.1.
* Back off version again.Joel Sherrill2004-07-281-12/+0
