* | 2006-08-09 Kolja Waschk <waschk@telos.de> | Joel Sherrill | 2006-08-09 | 1 | -0/+4 |
| | | | | * config-ml.in: New port to Altera NIOS II. | ||||
* | added ChangeLog entries for PR1117/1118/1119/1120 | Thomas Doerfler | 2006-07-14 | 1 | -0/+5 |
* | 2006-06-23 Worth Burruss <worth@motioncontrol.org> | Joel Sherrill | 2006-06-23 | 1 | -0/+4 |
| | | | | * README.configure: Add mcf5235. | ||||
* | 2006-04-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-04-19 | 1 | -0/+4 |
| | | | | * VERSION: Updated to rtems-4.6.99.3. | ||||
| | | | | * aclocal/version.m4: Updated to rtems-4.6.99.3. | ||||
* | 2006-04-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-04-19 | 1 | -3/+3 |
| | | | | * release_support: Fix typos. | ||||
* | 2006-04-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-04-19 | 1 | -4/+0 |
* | 2006-04-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-04-18 | 1 | -0/+4 |
* | 2006-03-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-03-09 | 1 | -0/+4 |
| | | | | * acinclude.m4: Requires autoconf-2.59. | ||||
* | 2006-03-07 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-03-07 | 1 | -0/+5 |
| | | | | | PR 694/rtems * release_support: Do not include .cvsignore files in release tarballs. | ||||
* | 2006-02-01 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-02-01 | 1 | -0/+5 |
| | | | | | PR 882/make_build * bootstrap: Only remove bspopts.h.in instead of bspopts.h*. | ||||
* | 2006-01-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-12 | 1 | -0/+2 |
| | | | | | * aclocal/bsp-alias.m4: Revert Joel's 2006-01-10 change. Alpha-sort the aliases list. | ||||
* | 2006-01-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-12 | 1 | -0/+5 |
| | | | | | * automake/host.am, automake/local.am, automake/subdirs.am: Remove depend-am, depend-recursive. | ||||
* | 2006-01-10 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-10 | 1 | -0/+4 |
| | | | | * aclocal/bsp-alias.m4: Add sis as alias of erc32. | ||||
* | 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-09 | 1 | -0/+7 |
| | | | | | | | * aclocal/bsp-alias.m4: Remove brs5l. Remove leon2. Alias leon1 to leon2. Add sis. * aclocal/check_bsps.m4: Remove brs5l. Remove leon. Add leon2. Add sis to erc32 family. | ||||
* | 2005-11-31 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-12-31 | 1 | -0/+6 |
| | | | | | | PR 851/bsps * aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add gen5200 BSP family. | ||||
* | Fixed formatting | Joel Sherrill | 2005-11-07 | 1 | -2/+2 |
* | 2005-11-03 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-03 | 1 | -0/+4 |
| | | | | * aclocal/check-bsps.m4: Add the plethora of mbx* BSP. | ||||
* | 2005-09-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-09-02 | 1 | -0/+4 |
| | | | | * VERSION: Updated to rtems-4.6.99.2. | ||||
* | 2005-09-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-09-02 | 1 | -8/+0 |
| | | | | * aclocal/version.m4: Updated to rtems-4.6.99.2. | ||||
* | 2005-09-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-09-02 | 1 | -2/+2 |
* | 2005-07-06 Philippe Simons | Philippe Simons | 2005-07-07 | 1 | -0/+4 |
| | | | | * MAINTAINERS: Added me as arm/gp32 bsp maintainer. | ||||
* | 2005-04-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-04-28 | 1 | -0/+5 |
| | | | | | * README.configure: Updated to account for removal of dmv177 and ppcn_60x as well as other additions and deletions. | ||||
* | 2005-02-04 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-04 | 1 | -0/+4 |
| | | | | * aclocal/enable-itron.m4: Allow unix. | ||||
* | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-02 | 1 | -0/+4 |
| | | | | * Makefile.am: Remove ACLOCAL_FILES. | ||||
* | 2004-11-16 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-11-16 | 1 | -0/+5 |
| | | | | | * aclocal/check-bsps.m4: Use ls instead of globs to pickup bsp_specs. | ||||
* | 2004-11-12 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-11-12 | 1 | -0/+5 |
| | | | | | * aclocal/check-bsps.m4: Add MVME2100 BSP as alias of motorola_shared. | ||||
* | 2004-11-10 Joel Sherrill <joel@oarcorp.com> | Joel Sherrill | 2004-11-10 | 1 | -0/+4 |
| | | | | * aclocal/bsp-alias.m4: Add MVME2100 BSP as alias of motorola_shared. | ||||
* | 2004-10-22 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-10-22 | 1 | -0/+4 |
| | | | | * alocal/check-custom-bsp.m4: Reflect new location of bspkit*cfg. | ||||
* | 2004-10-18 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-10-18 | 1 | -0/+6 |
| | | | | | | * aclocal/check-bsps.m4: Add bspkit support. Don't check for presence of *.cfg. * aclocal/check-custom-bsp.m4: Add bspkit support. | ||||
* | 2004-10-18 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-10-18 | 1 | -0/+4 |
| | | | | * aclocal/enable-bare.m4: Remove. | ||||
* | 2004-09-29 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-09-29 | 1 | -0/+5 |
| | | | | | * MAINTAINERS, README.configure, c/ACKNOWLEDGEMENTS, c/TOOL_TARGETS: i960 obsoleted and all references removed. | ||||
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 1 | -0/+4 |
| | | | | * configure.ac: Require automake > 1.9. | ||||
| | | | | * aclocal/rtems-cpu-subdirs.m4: Remove (unused). | ||||
* | 2004-08-18 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-08-18 | 1 | -0/+7 |
| | | | | | | PR 673/make_build * config-ml.in: Quote 'cd "${ml_origdir}"'. Quote 'cd "${ML_POPDIR}"'. | ||||
* | 2004-08-17 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-08-18 | 1 | -1/+5 |
| | | | | * acinclude.m4 (_RTEMS_CONFIG_SUBDIR): Quote ac_popdir uses. | ||||
* | Removing message from cut release trial. | Joel Sherrill | 2004-07-29 | 1 | -8/+0 |
* | 2004-07-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-07-28 | 1 | -0/+4 |
| | | | | * VERSION: Updated to rtems-4.6.99.1. | ||||
| | | | | * aclocal/version.m4: Updated to rtems-4.6.99.1. | ||||
* | Back off version again. | Joel Sherrill | 2004-07-28 | 1 | -12/+0 |
| | | | | * release_support: Have a user name. | ||||
* | Back off version. | Joel Sherrill | 2004-07-28 | 1 | -8/+0 |
