* | 2008-12-31 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-12-31 | 1 | -0/+5 |
| | | | | | * config-ml.in: Comment out arm/thumb exception (Add arm/thumb multilib). | ||||
* | 2008-12-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-12-30 | 1 | -0/+4 |
| | | | | * aclocal/check-bsps.m4: remove stray ")" from rtl22xx_t alias. | ||||
* | 2008-12-22 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-12-22 | 1 | -0/+4 |
| | | | | * aclocal/canonical-target-name.m4: Remove tic4x. | ||||
* | 2008-12-04 Jukka Pietarinen <jukka.pietarinen@mrf.fi> | Joel Sherrill | 2008-12-04 | 1 | -0/+4 |
| | | | | * README.configure: Add Lattice Mico32 support. | ||||
* | 2008-10-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-10-14 | 1 | -0/+5 |
| | | | | | * aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add h8sxsim as variant of h8sim. | ||||
* | 2008-10-02 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-10-02 | 1 | -0/+5 |
| | | | | | * README.configure: Add new M32R port. It is just a beginning but the BSP is functional enough to initialize and shutdown RTEMS. | ||||
| | | | | | * README.configure, aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add M32C port and m32csim BSP. | ||||
* | 2008-10-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-10-01 | 1 | -0/+4 |
| | | | | * VERSION: Bump version to 4.9.99.0 | ||||
* | 2008-10-01 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-10-01 | 1 | -0/+5 |
| | | | | | PR 1324/bsps * aclocal/check-bsps.m4: Revert Joel's icecube patch. | ||||
* | 2008-09-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-29 | 1 | -0/+4 |
| | | | | * MAINTAINERS: Remove myself from avr. | ||||
* | 2008-09-25 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-25 | 1 | -0/+7 |
| | | | | | | | * README.configure, aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Recognize the the GDB SuperH simulator is just an architectural simulator and does not include devices. Rename existing simulator BSP configurations to simsh1 and simsh2 and add simsh4. | ||||
* | 2008-09-24 Ralf Corsépius <ralf.corsepius@rtems.org> | Joel Sherrill | 2008-09-24 | 1 | -0/+5 |
| | | | | | PR 1324/bsps * aclocal/check-bsps.m4: Add missing icecube. | ||||
* | 2008-09-22 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-22 | 1 | -0/+5 |
| | | | | | * aclocal/version.m4: Bump RTEMS_API to 4.10. Bump _RTEMS_VERSION to 4.9.99.0. | ||||
* | added BSP for ARM LPC24xx | Thomas Doerfler | 2008-09-22 | 1 | -0/+5 |
* | 2008-09-09 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-09 | 1 | -0/+4 |
| | | | | * README.configure: Updated list of BSPs. | ||||
* | added new BSP for powerpc/tqm8xx boards | Thomas Doerfler | 2008-09-08 | 1 | -0/+7 |
* | Remove bogus entry. | Joel Sherrill | 2008-09-05 | 1 | -4/+0 |
* | 2008-08-15 Allan Hessenflow <allanh@kallisti.com> | Joel Sherrill | 2008-08-15 | 1 | -0/+4 |
| | | | | * src/lib/libbsp/mips/jmr3904/tools/runtest: Add bf537Stamp. | ||||
* | 2008-07-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-07-27 | 1 | -0/+4 |
| | | | | * acinclude.m4 (_RTEMS_OUTPUT_SUBDIRS): Allow empty configdirs. | ||||
* | 2008-07-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-07-27 | 1 | -0/+7 |
| | | | | | | | * aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Remove doxygen comments. * aclocal/rtems-top.m4: Require AC_DISABLE_OPTION_CHECKING. AC_PREREQ(2.62). | ||||
* | updated gen83xx BSP | Thomas Doerfler | 2008-07-14 | 1 | -0/+5 |
| | | | | | updated haleakala BSP added MPC55xx BSP | ||||
* | added haleakala BSP contributed by Michael Hamel | Thomas Doerfler | 2008-07-14 | 1 | -1/+6 |
* | added BSP to m68k | Thomas Doerfler | 2008-07-11 | 1 | -0/+7 |
| | | | | adapted PPC exception code | ||||
* | 2008-06-01 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-06-01 | 1 | -0/+4 |
| | | | | * configure.ac, acinclude.m4: s/AC_HELP/AS_HELP/. | ||||
* | 2008-04-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-04-14 | 1 | -0/+4 |
| | | | | * bootstrap: Use find . ... preinstall.am for portability reasons. | ||||
* | 2008-02-20 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-02-20 | 1 | -0/+8 |
| | | | | | | | | * aclocal/enable-cxx.m4, aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4, aclocal/enable-posix.m4, aclocal/enable-rtems-debug.m4, aclocal/enable-rtemsbsp.m4, aclocal/enable-tests.m4, aclocal/multilib.m4: s/AC_HELP/AS_HELP/. | ||||
* | 2007-11-06 Ray Xu <rayx.cn@gmail.com> | Joel Sherrill | 2007-11-06 | 1 | -0/+4 |
| | | | | * aclocal/bsp-alias.m4, aclocal/check-bsps.m4: | ||||
* | 2007-09-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-09-21 | 1 | -0/+1 |
| | | | | * VERSION: Bump VERSION to 4.8.99.0. | ||||
* | 2007-09-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-09-21 | 1 | -0/+5 |
| | | | | | * aclocal/version.m4: Bump RTEMS_API to 4.9. Bump RTEMS_VERSION to 4.8.99.0. | ||||
* | 2007-09-04 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-09-04 | 1 | -0/+5 |
| | | | | | * Makefile.maint: touch all documentation master files so the date on the manual reflects the release date of the software. | ||||
* | 2007-08-07 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-08-07 | 1 | -0/+5 |
| | | | | | * Makefile.maint: Add touching master files for various manuals so the date on the cover page will reflect the date a tarball is cut. | ||||
* | 2007-08-06 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-08-06 | 1 | -0/+6 |
| | | | | | | * README.configure, aclocal/bsp-alias.m4: Rename EP5200 to IceCube since that is the nickname for the Freescale evaluation board it is based upon. BSP was tested on a Freescale MPC5200LITE. | ||||
* | 2007-08-02 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-08-02 | 1 | -0/+5 |
| | | | | | * Makefile.maint, configure.ac, release_support: Remove RDBG. * aclocal/enable-rdbg.m4: Removed. | ||||
* | compilable release of virtex/gen83xx/gen5200 powerpc adaptations. Merged ↵ | Thomas Doerfler | 2007-07-10 | 1 | -1/+6 |
| | | | | many different versions of new exception handling code to shared sources. | ||||
* | merged individual exception handler code to a common one. | Thomas Doerfler | 2007-07-04 | 1 | -0/+4 |
* | 2007-06-20 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-06-20 | 1 | -0/+4 |
| | | | | * aclocal/bsp-alias.m4, README.configure: Add ep5200, IceCube, 5200Lite. | ||||
* | 2007-06-12 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-06-12 | 1 | -0/+4 |
| | | | | * README.configure: Removed armulator. | ||||
* | 2007-05-15 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-05-15 | 1 | -0/+5 |
| | | | | | * README.configure, aclocal/check-bsps.m4: Remove references to mbx860_1b since it is just an alternate name for the mbx860_001b. | ||||
* | 2007-05-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-05-11 | 1 | -0/+5 |
| | | | | | * README.configure, aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Per Jiri Gaisler remove unused erc32nfp and leon1 BSP variants. | ||||
* | 2007-05-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-05-11 | 1 | -0/+4 |
| | | | | * README.configure: DMV152 obsoleted. | ||||
* | 2007-02-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2007-02-21 | 1 | -0/+4 |
| | | | | * Makefile.maint: Added TOOL_VERSIONS stanza and fixed typo. | ||||
* | 2007-02-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-02-21 | 1 | -0/+4 |
| | | | | * Makefile.am: Use MKDIR_P instead of mkdir_p. | ||||
* | 2007-02-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-02-15 | 1 | -0/+1 |
| | | | | * Makefile.maint: Use VERSION as master source for version.m4's. | ||||
* | 2007-02-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-02-15 | 1 | -0/+4 |
| | | | | * VERSION: Sync with version in aclocal/version.m4. | ||||
* | 2007-01-28 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-28 | 1 | -0/+6 |
| | | | | | | * Makefile.maint: Sync nomenclature with that being used in cpukit/score/include/rtems/system.h (major->minor, minor->revision). | ||||
* | 2007-01-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-27 | 1 | -0/+2 |
| | | | | | * Makefile.maint: Remove references to cpukit/score/include/rtems/system.h. | ||||
* | 2007-01-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-27 | 1 | -0/+4 |
| | | | | * Makefile.maint: Add CVS_RUN. | ||||
* | 2007-01-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-26 | 1 | -0/+4 |
| | | | | * Makefile.maint: New. | ||||
* | 2007-01-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-08 | 1 | -0/+4 |
| | | | | * acinclude.m4: AC_PREREQ(2.60). | ||||
| | | | | * ampolish3: Use MKDIR_P instead of mkdir_p. |
