* aclocal/gcc-pipe.m4: Use $GCC instead of ac_cv_prog_gcc (autoconf
standard).
* aclocal/gcc-specs.m4: Use $GCC instead of ac_cv_prog_gcc (autoconf
standard).
* aclocal/multilib.m4: Fix m4-quoting (BUG-FIX).
* aclocal/check-bsp-cache.m4: Fix m4-quoting (autoconf-2.49b).
* aclocal/prog-cc.m4: Use $GCC instead of ac_cv_prog_gcc (autoconf
standard), replace CC_FOR_TARGET with CC (BUG-FIX).
* aclocal/enable-itron.m4: Remove changequotes (autoconf-2.49b).
* aclocal/enable-posix.m4: Remove changequotes (autoconf-2.49b), use
$host instead of $target (BUG-FIX).
* configure.in: Use $target and $host instead of $target_alias and
$host_alias (autoconf-2.49b).
* aclocal/check-newlib.m4: Remove CC_FOR_TARGET (BUG-FIX)
* aclocal/sysv-ipc.m4: Move AC_DEFINE outside of AC_CACHE (BUG-FIX)
NOTES:
* autoconf-2.49b depredicates using changequotes.
* The changes to configure.in are due to cleanups in
autoconf-2.49b's implemention of canonicalization. With
autoconf-2.1x it wasn't always clear, when to use $xxx or
$xxx_alias. Now this is clear.
* aclocal/canonicalize-tools.m4, aclocal/check-tool.m4,
aclocal/prog-cc.m4, aclocal/prog-cxx.m4: Replace AC_CHECK_TOOL
with an RTEMS specific but more restrictive autoconf macro.
* automake/lib.am: Add LD.
* aclocal/canonicalize-tools.m4: Remove RTEMS_PATH_TOOL, use
AC_CHECK_TOOL instead of RTEMS_PATH_TOOL in RTEMS_CANONICALIZE_TOOLS.
* aclocal/*: Replace with contents of macros/*.m4
* macros/: Remove.
* aclocal/ar-s.m4 aclocal/tool-prefix.m4: Remove.
* Makefile.am: Reflect changes to aclocal/ and macros/.
* configure.in: New, Cygnus/GNU style configuration.
* Makefile.am: Add macros/, reflect new configure.in,
ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/macros
* automake/compile.am: BSP_SPECS, remove RTEMS_CANONICALIZATION.
* automake/lib.am: Remove RTEMS_CANONICALIZATION.
* macros/tool-prefix.m4: Remove.
* macros/target.m4: Remove RTEMS_CONFIG_SUBDIRS, RTEMS_OUTPUT_SUBDIRS.
* macros/enable-rtemsbsp.m4: Add RTEMS_CONFIG_PER_BSP, add setting
RTEMS_ROOT.
* macros/i386-gas-code16.m4: Define NEW_GAS only for 16bit mode-
* macros/multilib.m4: Various minor fixes.
* macros/project-root.m4: Remove setting PROJECT_TOPdir,
PROJECT_ROOT, RTEMS_ROOT.
* macros/rtems-top.m4: Remove RTEMS_CANONICALIZATION, TARGET_SUBDIRS;
Add with_target_subdirs, PROJECT_TOPdir, PROJECT_ROOT.
* automake/multilib.am: New file.
* Makefile.am: Update AUTOMAKE_FILES to reflect the contents of
the automake/ directory.
* macros/enable-hwapi.m4: Removed.
* aclocal/rtems-top.m4, automake/compile.am, automake/lib.am:
A small cleanup step towards gnu-canonicalization.
* macros: New directory.
* macros/bsp-alias.m4: new file.
* macros/canonical-host.m4: new file.
* macros/canonical-target-name.m4: new file.
* macros/canonicalize-tools.m4: new file.
* macros/check-bsp-cache.m4: new file.
* macros/check-bsps.m4: new file.
* macros/check-cpu.m4: new file.
* macros/rtems-debug.m4: new file.
* macros/check-cxx.m4: new file.
* macros/check-itron.m4: new file.
* macros/check-multiprocessing.m4: new file.
* macros/check-networking.m4: new file.
* macros/check-newlib.m4: new file.
* macros/check-posix.m4: new file.
* macros/check-rdbg.m4: new file.
* macros/enable-bare.m4: new file.
* macros/enable-cxx.m4: new file.
* macros/enable-gcc28.m4: new file.
* macros/enable-inlines.m4: new file.
* macros/enable-itron.m4: new file.
* macros/enable-libcdir.m4: new file.
* macros/enable-multiprocessing.m4: new file.
* macros/enable-networking.m4: new file.
* macros/enable-posix.m4: new file.
* macros/enable-rdbg.m4: new file.
* macros/enable-rtemsbsp.m4: new file.
* macros/enable-tests.m4: new file.
* macros/gcc-pipe.m4: new file.
* macros/gcc-specs.m4: new file.
* macros/i386-gas-code16.m4: new file.
* macros/path-ksh.m4: new file.
* macros/path-perl.m4: new file.
* macros/prog-cc.m4: new file.
* macros/prog-cxx.m4: new file.
* macros/project-root.m4: new file.
* macros/rtems-top.m4: new file.
* macros/sysv-ipc.m4: new file.
* macros/target.m4: new file.
* macros/rtems-test-no-pause.m4: new file.
* macros/multilib.m4: new file.
* macros/tool-paths.m4: new file.
* macros/tool-prefix.m4: new file.
* Makefile.am: Referenceed aclocal/enable-hwapi.m4 that was removed.
* aclocal/enable-hwapi.m4: Now longer used and removed.
* automake/lib.am: Remove leaf.cfg.
* aclocal/rtems-top.m4: Add ENDIF-hack.
* automake/compile.am: Add include $(DEPENDS) + ENDIF-hack.
* aclocal/check-cxx.m4: Add AC_SUBST(CPLUS_LD_LIBS)
* aclocal/prog-cc.m4: Cleanup comments, require RTEMS_ENABLE_GCC28,
add automake conditionals RTEMS_USE_GCC, RTEMS_USE_GCC272.
* automake/compile.am: Replaced.
* automake/local.am: Remove building variant handling.
* aclocal/enable-rtemsbsp.m4: Add RTEMS_ENABLE_BARE,
AC_SUBST(BARE_CPU_MODEL),AC_SUBST(BARE_CPU_CFLAGS).
* aclocal/i386-gas-code16.m4: AC_DEFINE NEW_GAS.
* aclocal/target.m4: Cleanup comments
* Automake/compile.am: Add DEFS support to keep building happy.
* aclocal/project-root.m4: Introduce PROJECT_TOPdir, add comments.
* automake/compile.am: New file
* ChangeLog: Fix email addresses
* LICENSE.NET, README, README.configure: Spelling corrections.
* aclocal/check-bsps.m4: Fix c4* and sim68000 entries
* LICENSE.NET, LICENSE.RPCXDR, LICENSE.WEBSERVER: New files.
* ChangeLog: Moved incorrect entries to make/ChangeLog.
* make/custom/pck6.cfg: New file
* make/custom/pc486.cfg: Use -m486
* make/custom/pc586.cfg: Use -mpentium
* make/custom/pc686.cfg: Use -mmpentiumpro
* make/custom/i386ex.cfg: Use -msoft-float
* aclocal/check-bsps.h:
- Add pck6-BSP
- Exclude ChangeLog from being picked up as BSP
* aclocal/bsp-alias.m4: Add pck6-BSP
