* release_support: Correct method used to find ChangeLog associated
with the version.m4 files. Keep going until I can get a tarball cut.
* VERSION: Updated to rtems-20031217-test.
* release_support: Use dirname not basedir. Keep going until I
* release_support: New file -- assistant to new cut_release script.
* Makefile.am: Remove automake/compile.am
* automake/compile.am: Remove (Unused).
* automake/lib.am: Remove (Unused).
* configure.ac: Remove make/custom/Makefile.
* Makefile.am: Cosmetics.
* automake/compile.am: Remove compilation rules.
Remove $(ARCH) directory generation.
* MAINTAINERS: New file.
* aclocal/bsp-alias.m4, aclocal/canonical-target-name.m4,
aclocal/check-bsps.m4, aclocal/check-custom-bsp.m4,
aclocal/enable-bare.m4, aclocal/enable-cxx.m4,
aclocal/enable-inlines.m4, aclocal/enable-itron.m4,
aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4,
aclocal/enable-posix.m4, aclocal/enable-rdbg.m4,
aclocal/enable-rtems-debug.m4, aclocal/enable-rtemsbsp.m4,
aclocal/enable-tests.m4, aclocal/multilib.m4,
aclocal/path-ksh.m4, aclocal/project-root.m4,
aclocal/rtems-top.m4, aclocal/tool-paths.m4,
acinclude.m4:
Fix underquoting to silence automake-1.8.
* config-ml.in: Don't built multilib variant normal (-mn) for
h8300-*-rtems*.
* aclocal/config-subdirs.m4: Remove.
* aclocal/canonical-host.m4: Remove.
* bootstrap: Use $RTEMS_BSP_FAMILY instead of RTEMS_BSP_ALIAS in
c/src/lib/libbsp/*/acinclude.m4.
* aclocal/check-cpu.m4: Remove.
* Makefile.am: Remove reference to aclocal/check-cpu.m4.
* acinclude.m4 (RTEMS_TARGET_CONFIG_SUBDIR): Check for presence of
$1 in $srcdir before adding dir to SUBDIRS.
* README.configure, aclocal/rtems-cpu-subdirs.m4: Removing HPPA port.
* aclocal/enable-rtems-debug.m4: New (Missed in yesterday's
patches).
* aclocal/enable-tests.m4: Change to support
--enable-tests=no|yes|samples, default is samples.
* Makefile.am: Correct bogus ACLOCAL_FILES.
* aclocal/bsp-arg-enable.m4, aclocal/bsp-configure.m4,
aclocal/bspopts.m4, aclocal/canonicalize-tools.m4,
aclocal/check-bsp-cache.m4, aclocal/check-cxx.m4,
aclocal/check-itron.m4, aclocal/check-multiprocessing.m4,
aclocal/check-networking.m4, aclocal/check-newlib.m4,
aclocal/check-posix.m4, aclocal/check-rdbg.m4,
aclocal/check-tool.m4, aclocal/env-rtemsbsp.m4,
aclocal/gcc-isystem.m4, aclocal/gcc-pipe.m4,
aclocal/gcc-specs.m4, aclocal/i386-gas-code16.m4,
aclocal/path-perl.m4, aclocal/ppc.m4,
aclocal/prog-cc.m4, aclocal/prog-ccas.m4,
aclocal/prog-cxx.m4, aclocal/prog-gnat.m4,
aclocal/rtems-debug.m4, aclocal/rtems-flags.m4,
aclocal/rtems-test-no-pause.m4, aclocal/target.m4:
Remove (Unused).
* automake/leaf.am, automake/force-preinstall.am:
Remove (Unused).
* automake/local.am, automake/host.am: Remove "debug".
* config-ml.in: Partial sync with gcc-3.4's config-ml.in.
Add "autoconf-2.5x unquoting" hack.
* SUPPORT: Fix Mark Johannes' email address.
* VERSION: Updated to rtems-ss-20030703.
* aclocal/version.m4: Updated to rtems-ss-20030703.
* bootstrap: Reflect having added config.sub.
* config.sub: New from subversions to accomodate c4x/tic4x.
* configure.ac: Remove "BLEEDING EDGE" warning.
Put docs into RTEMS_BUILD_CONFIG_SUBDIRS.
* acinclude.m4: Add AC_PREREQ(2.57).
Major overhaul (PR 412).
* aclocal/prog-cc.m4: Add RTEMS_GCC_ISYSTEM.
* aclocal/gcc-isystem.m4: New.
* Makefile.am: Add aclocal/gcc-isystem.m4.
* automake/local.am: Remove $(ARCH), clean-local.
PR 321:
* aclocal/check-bsp-cache.m4: Remove support for profile-variant.
* aclocal/env-rtemsbsp.m4
* automake/host.am
* automake/local.am
* aclocal/check-cxx.m4: Remove LIBSUFFIX_VA.
* automake/compile.am: Remove LIBSUFFIX_VA.
Merger from rtems-4-6-branch.
* VERSION: Updated to rtems-ss-20030417.
* aclocal/version.m4: Updated to rtems-ss-20030417.
* VERSION: Updated to rtems-ss-20030411.
* aclocal/version.m4: Updated to rtems-ss-20030411.
* VERSION: Updated to rtems-ss-20020411.
* aclocal/version.m4: Updated to rtems-ss-20020411.
* Makefile.am: Remove references to obsoleted files
aclocal/enable-gcc28.m4, aclocal/enable-libcdir.m4.
* ChangeLog: Take out bogus ppc changelog entry.
* README.configure, aclocal/rtems-cpu-subdirs.m4: Remove a29k
references.
PR 347/rtems
* rtems/powerpc/registers.h (PPC_Set_decrementer): Correct inline
assembly so it correctly generates on newer gcc's.
* bootstrap: Remove attempts to detect autoconf and automake using
"which" (PR 325).
