* configure.ac: Remove "BLEEDING EDGE" warning.
Put docs into RTEMS_BUILD_CONFIG_SUBDIRS.
* acinclude.m4: Add AC_PREREQ(2.57).
Major overhaul (PR 412).
* aclocal/prog-cc.m4: Add RTEMS_GCC_ISYSTEM.
* aclocal/gcc-isystem.m4: New.
* Makefile.am: Add aclocal/gcc-isystem.m4.
* aclocal/check-cxx.m4: Remove LIBSUFFIX_VA.
* automake/compile.am: Remove LIBSUFFIX_VA.
* VERSION: Updated to rtems-4.6.0pre3.
* aclocal/version.m4: Updated to rtems-4.6.0pre3.
* VERSION: Updated to rtems-4.6.0pre2.
* aclocal/version.m4: Updated to rtems-4.6.0pre2.
* acinclude.m4: Reformat build_* handling.
Preset *_alias if empty.
* configure.ac: Change tools/build to build-config dirs.
Conditionally build tools/build as host-config dirs.
* acinclude.m4: Fix broken comments.
Add hidden option --enable-experimental.
* README.cdn-X: Update.
* configure.ac: Build tools/build as host and build-host tools to
accomodate those BSPs applying packhex in <BSP>.cfg.
Build tools/cpu as build-host tools.
* tools/Makefile.am: Remove.
* configure.ac: Remove tools/Makefile.am
* acinclude.m4: Fix build_subdir handling.
* Makefile.am: Remove tools from SUBDIRS.
Rename HOST|BUILD|TARGET_SUBDIRS into host|build|target_SUBDIRS.
* configure.ac: Remove AC_CONFIG_AUX_DIR.
* alocal/rtems-top.a4: Add AC_CONFIG_AUX_DIR.
* bootstrap: Add ACLOCAL, AUTOHEADER.
Don't check for auto*tool-versions.
* config-ml.in: Don't build sh-rtems ml and ml/m2 multilib variants.
* automake/compile.am: Introduce depend-gcc.
* automake/lib.am: Remove stray comment.
* automake/local.am: Introduce depend-gcc.
* config-ml.in: Don't build arm-rtems/*fpu* multilib variants.
* aclocal/rtems-top.m4: Set PROJECT_ROOT unconditionally.
* automake/local.am: Remove $(ARCH), clean-local.
* automake/compile.am: Add $(ARCH), clean-local.
Set CXXFLAGS = @RTEMS_CFLAGS@ $(XCXXFLAGS).
* Makefile.am: Remove references to obsoleted files
aclocal/enable-gcc28.m4, aclocal/enable-libcdir.m4.
* config.sub (rtems-4-6-branch only): New from subversion.
* bootstrap (rtems-4-6-branch only): Do not delete config.sub.
* aclocal/canonical-target-name.m4: Transform tic4x -> RTEMS_CPU=c4x.
* VERSION: Updated to rtems-4.6.0pre1.
* aclocal/version.m4: Updated to rtems-4.6.0pre1.
* bootstrap: Remove attempts to detect autoconf and automake using
"which" (PR 325).
* README.configure: Updated to reflect new BSPs and deprecated
targets.
* VERSION: Updated to rtems-ss-20030128.
* aclocal/version.m4: Updated to rtems-ss-20030128.
* automake/compile.am: Remove CLEAN_DEPEND (Unused).
Remove CLOBBER_DEPEND (Unused).
* automake/local.am: Remove distclean-local.
* aclocal/rtems-cpu-subdirs.m4: Print out RTEMS_CPU in error message.
* aclocal/enable-cxx.m4: Use $enable_cxx instead of $enableval.
* aclocal/prog-cxx.m4: Remove RTEMS_PROG_CXX.
Rework RTEMS_PROG_CXX_FOR_TARGET.
* automake/compile.am: Remove creating $(ARCH) in compilation rules.
* configure.ac: Require autoconf >= 2.57 and automake-1.7.2.
* aclocal/prog-cxx.m4: Swap RTEMS_CHECK_TOOL/AC_PROG_CXX.
* bootstrap: Require autoconf 2.54 or 2.57.
Require automake-1.7.2.
* aclocal/bsp-configure.m4: Remove RTEMS_CHECK_BSP_CACHE.
* aclocal/env-rtemsbsp.m4: Add comments to AC_ARG_VARs.
Add AC_ARG_VAR(RTEMS_CPU_MODEL).
* automake/compile.am: Rework *FLAGS, AM_*FLAGS handling.
* automake/compile.am: Remove hard-coded *_PROFILE_V.
Add autoconf-supplied CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V,
CFLAGS_PROFILE_V.
Remove CPPFLAGS_GCC.
* aclocal/env-rtemsbsp.m4: Add AC_ARG_VAR for CPU_CFLAGS,
CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V, CFLAGS_PROFILE_V, RTEMS_BSP_FAMILY.
* aclocal/prog-cc.m4: Reworked CFLAGS handling.
* aclocal/prog-cxx.m4: Reworked CXXFLAGS handling.
* aclocal/rtems-flags.m4: New.
* bootstrap: Allow autoconf-2.57.
* aclocal/prog-cc.m4: Remove GCCSED.
* automake/compile.am: Remove LDFLAGS_INCOMPLETE.
Remove LDFLAGS.
Add CCAS, CCASCOMPILE.
Remove compilation rules for *.cpp, *.cxx, *.C.
Use CCASCOMPILE to compile *.S.
Add -pg to RTEMS_CFLAGS_PROFILE_V.
* configure.ac: Remove c/make.
* aclocal/prog-ccas.m4: New.
* aclocal/check-custom-bsp.m4: New, split out from check-bsps.m4.
* aclocal/check-bsps.m4: Split out RTEMS_CHECK_CUSTOM_BSP.
* aclocal/canonicalize-tools.m4: Remove RTEMS_GCC_PRINT.
* acinclude.m4: Conditionally append --target=.
* aclocal/quoting.m4: Reworked (Part of fix to PR 312).
* automake/compile.am: Remove LD_PATHS (Unused).
* aclocal/check-newlib.m4: Adaptation to autoconf-2.5x (AC_TRY_LINK
is announced obsolete).
* Makefile.am: Reflect having removed aclocal/sysv-ipc.m4.
* aclocal/sysv-ipc.m4: Remove (Unused).
* aclocal/target.m4: Sync with acinclude.m4 (Part of fix to PR 312).
* acinclude.m4: Lots of changes addressing PR 312.
