* aclocal/env-rtemscpu.m4: Remove.
* aclocal/multi.m4: Remove.
* aclocal/multilib.m4: Remove RTEMS_ENABLE_MULTILIB_MASTER.
* aclocal/version.m4: Updated to rtems-ss-20020528.
* aclocal/prog-cc.m4: Remove GCC272 support.
Remove ENABLE_LIBCDIR.
* aclocal/prog-cxx.m4: Ditto.
* aclocal/enable-gcc28.m4: Remove.
* aclocal/enable-libcdir.m4: Ditto.
* aclocal/enable-libcdir.m4, aclocal/enable-gcc28.m4: Remove
ENABLE_GCC28.
* automake/compile.am: Remove GCC272 support.
Remove *.sh rule (unused).
* .cvsignore: Added mdate-sh and texinfo.tex.
* aclocal/version.m4: New file.
* aclocal/rtems-top.m4: Add RTEMS_VERSIONING, replace VERSION w/
aclocal/version.m4.
* bootstrap: Use aclocal/version.m4 instead of VERSION.
* configure.ac: Use aclocal/version.m4 instead of VERSION.
* tools/Makefile.am: Remove AUTOMAKE_OPTIONS.
* aclocal/env-rtemscpu.m4: automake-1.6 preparations:
Add AM_CONDITIONAL([RTEMS_CONFIG_PER_BSP],[false]).
* VERSION: Updated to rtems-mg5-20020808.
* VERSION: Updated to rtems-ss-20020301.
* VERSION: Updated to rtems-ss-20020215.
* aclocal/subdirs.m4: Propagate the current $prefix to the
sub-configures.
* VERSION: Updated to rtems-ss-20020205.
* aclocal/sysv-ipc.m4: Use 3-args AC_DEFINE for autoconf-2.5x
compatibility.
* bootstrap: Let --clean remove texinfo.tex.
* aclocal/env-rtemsbsp.m4: Use ${RTEMS_BSP} to setup includedir.
* configure.ac: Add --enable-docs support. Add
RTEMS_HOST_CONFIG_SUBDIRS(doc). Remove doc/Makefile.
* Makefile.am: Add HOST_SUBDIRS to SUBDIRS. Remove doc from
hard-coded SUBDIRS.
* README.configure: Added a bit of information on this new option.
* VERSION: Updated to rtems-ss-20020118.
* VERSION: Updated to rtems-20020118.
* VERSION: Updated to rtems-ss-20020717.
* aclocal/check-tool.m4: Remove AC_CHECK_TOOL_PREFIX, conditionalize
check upon host_alias != build_alias.
* automake/compile.am (LINK_LIB_RTEMS): Removed line continuation for
last line to eliminate 100's of warnings.
* aclocal/check-newlib.m4: Apply AS_IF.
* aclocal/config-subdirs.m4: Remove _RTEMS_PUSH_BUILDDIR,
_RTEMS_POP_BUILDDIR, _RTEMS_GIVEN_INSTALL, _RTEMS_SUB_SRCDIR.
* aclocal/subdirs.m4: Fix comments, apply AS_IF.
* aclocal/sysv-ipc.m4: Reflect autoconf-2.5x canonicalization
changes.
* aclocal/target.m4: Add _RTEMS_PUSH_BUILDDIR, _RTEMS_POP_BUILDDIR,
* automake/compile.am: Remove librtemsall from LINK_FILES.
* configure.ac: Reworked for multilibs, reflect changes to aclocal/*.m4.
* aclocal/subdirs.m4: New file.
* aclocal/multi.m4: New file, adopted from autoconf-2.52 w/
modifications.
* aclocal/check-posix.m4: Apply AS_IF.
* aclocal/config-subdirs.m4: Reflect changes to other m4-macros.
* aclocal/env-rtemsbsp.m4: Add PROJECT_INCLUDE, PROJECT_RELEASE.
Add AM_CONDITIONAL(MULTILIB). Adapt GCC_SPECS to multilibs.
* aclocal/env-rtemscpu.m4: Remove RTEMS_BSP. Add support for
MULTIBUILDTOP, MULTISUBDIR. Adapt GCC_SPECS to multilibs.
Add PROJECT_INCLUDE, PROJECT_RELEASE, includedir, libdir.
* aclocal/multilib.m4: Fix m4-quoting, adopt automake-1.5's
OUTPUT_COMMANDS.
* aclocal/project-root.m4: Remove PROJECT_INCLUDE, PROJECT_RELEASE.
* aclocal/rtems-debug.m4: Minor cleanups.
* aclocal/rtems-top.m4: Minor cleanups.
* automake/compile.am: Further steps towards automake's rules.
* automake/multilib.am: include @RTEMS_BSP@.cfg, cleanup.
* automake/lib.am: Add MULTISUBDIR.
* bootstrap: Run autoheader when configure.ac contains
RTEMS_BSP_CONFIGURE. Remove bspopts.h* files.
* aclocal/bsp-configure.m4: New file.
* Makefile.am: Add aclocal/bsp-configure.m4.
* Makefile.am: Add automake/force-preinstall.am,
aclocal/ppc.am, remove ACLOCAL_M4.
* aclocal/bsp-alias.m4: Remove score603e_g1.
* aclocal/check-bsps.m4: Remove score603e_g1.
* aclocal/prog-cc.m4: Apply m4_if.
* automake/force-preinstall.am: New file.
* aclocal/ppc.m4: New file.
* aclocal/check-bsps.m4: Reworked.
* aclocal/bsp-alias.m4: Add score603e_g1, apply m4sugar.
* aclocal/bspopts.m4: New file.
* COPYING: Test of $Id$ -> $RTEMS$.
process was captured as PR50.
* README.configure: Added gen405 BSP.
* Adopt more automake rules:
* automake/compile.am: Add LINK, CXXLINK, AS, ASCOMPILE;
Remove ARFLAGS, LINK.c, COMPILE.S, LINK.cc;
Add CPU_CFLAGS to CXXFLAGS, CFLAGS, ASFLAGS;
* automake/leaf.am: Add CXXLINK_APP, LINK_APP, make-exe, apply
CXXLINK_APP in make-cxx-exe.
* automake/lib.am: Add ARFLAGS.
* aclocal/check-rdbg.m4: Fix latent bug exposed by removal of
config.cache's which prevented powerpc targets librdbg from building.
* aclocal/rtems-cpu-subdirs.m4: Add PREFIX arg to RTEMS_CPU_SUBDIRS,
add 2nd arg to _RTEMS_CPU_SUBDIR.
* aclocal/target.m4: Replace ac_configure_args with
rtems_configure_args, add rtems_configure_args to INIT-CMDS.
* configure.in: Remove.
* aclocal/rtems-cpu-subdirs.m4: New file.
* automake/compile.am: Fundamentally reworked compilation rules for
closer adaptation to automake's behavior.
* automake/lib.am: Comment out LD.
* Makefile.am: Use ACLOCAL_FILES = to make automake-1.5 happy; Add
automake/leaf.am to AUTOMAKE_FILES.
* config.guess: No longer in CVS since installed by bootstrap.
* bootstrap: remove/add automake added files.
* .cvsignore: reflect changes to bootstrap.
* automake/leaf.am: New file.
* aclocal/canonical-target-name.m4: Use AC_CANONICAL_TARGET instead
of AC_CANONICAL_SYSTEM.
* aclocal/config-subdirs.m4: Use AS_MKDIR_P instead of
mkinstalldirs and mkdir.
* aclocal/target.m4: Obsolete RTEMS_OUTPUT_BUILD_SUBDIRS,
hack RTEMS_CONFIG_BUILD_SUBDIRS, introduce
_RTEMS_OUTPUT_BUILD_SUBDIRS.
* missing: Updated to latest version.
* configure.in: autoupdate to autoconf-2.52.
* bootstrap: Add handling for configure.ac, make autoheader verbose,
fix auto*tool invocation order.
* aclocal/rtems-test-no-pause.m4: Introduce AC_HELP_STRING.
* aclocal/enable-bare.m4: Introduce AC_HELP_STRING.
* aclocal/enable-cxx.m4: Introduce AC_HELP_STRING.
* aclocal/enable-gcc28: Introduce AC_HELP_STRING.
* aclocal/enable-inlines.m4: Introduce AC_HELP_STRING.
* aclocal/enable-itron.m4: Introduce AC_HELP_STRING.
* aclocal/enable-libcdir.m4: Introduce AC_HELP_STRING.
* aclocal/enable-multiprocessing.m4: Introduce AC_HELP_STRING.
* aclocal/enable-networking.m4: Introduce AC_HELP_STRING.
* aclocal/enable-posix.m4: Introduce AC_HELP_STRING.
* aclocal/enable-rdbg.m4: Introduce AC_HELP_STRING.
* aclocal/enable-rtemsbsp.m4: Introduce AC_HELP_STRING.
* aclocal/enable-tests.m4: Introduce AC_HELP_STRING.
* aclocal/env-rtemsbsp.m4: Add AC_ARC_VAR(RTEMS_BSP), apply true in
RTEMS_CONFIG_PER_BSP conditional.
* aclocal/multilib.m4: Introduce AC_HELP_STRING.
* aclocal/rtems-debug.m4: Introduce AC_HELP_STRING.
* aclocal/rtems-top.m4: Add AC_PREFIX_DEFAULT(/opt/rtems).
* README.configure: Corrected the name of the MRM332 BSP.
Strengthened the distinction between what the target
and the BSP each select. Added more targets to list.
* README.configure: Updated the list of BSPs.
* canonical-target-name.m4: Fix m4-quoting for autoconf-2.49f.
* aclocal/config-subdirs.m: Fix m4-quoting for autoconf-2.49f,
Add support for DOS-drive-letters.
