2011-03-04 | 2011-03-04 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* Makefile.am: Merge-in make/Makefile.am. * configure.ac: Reflect change above. | |||||
* Makefile.maint, aclocal/rpm.m4, aclocal/rtems-top.m4, aclocal/version.m4: Rename RTEMS_API into _RTEMS_API. | |||||
2011-03-03 | Fix the date. | Ralf Corsepius | 1 | -1/+1 | |
2011-03-03 | 2011-02-03 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* bootstrap: Add -g option. Switch default to autoreconf. | |||||
2011-02-02 | 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Require autoconf-2.68, automake-1.11.1. | |||||
2011-01-26 | 2011-01-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* configure.ac: Don't build tools/schedsim by default. Add --enable-schedsim (Default: disabled). | |||||
2010-12-17 | 2010-12-17 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+5 | |
Add RTEMS Scheduler Simulator. * configure.ac: Add tools/schedsim. | |||||
2010-12-16 | 2010-12-16 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* SUPPORT: Update address. | |||||
2010-09-27 | 2010-09-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* README.configure: Further cleanup. | |||||
2010-09-26 | 2010-09-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* README.configure: Remove the most obsolete parts. | |||||
2010-07-27 | 2010-07-27 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+5 | |
PR 1532/testing * aclocal/project-root.m4: Add initial tests for untar capabilities. | |||||
2010-06-23 | 2010-06-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: autoconf >= 2.65, automake >= 1.11. | |||||
2010-06-21 | 2010-06-21 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* Makefile.maint, README.configure: Remove more ITRON references. | |||||
2010-06-17 | 2010-06-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* aclocal/enable-itron.m4: Remove. * configure.ac: Remove itron. | |||||
2010-06-07 | 2010-06-07 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* aclocal/version.m4: Bump RTEMS_API to 4.11. Bump _RTEMS_VERSION to 4.10.99.0. | |||||
2010-05-11 | 2010-05-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* aclocal/bsp-alias.m4: Change quoting to work-round http://www.freebsd.org/cgi/query-pr.cgi?pr=146378. | |||||
2009-10-23 | 2009-10-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* aclocal/check-custom-bsp.m4: Be less verbose. | |||||
2009-10-21 | 2009-10-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* aclocal/bsp-alias.m4: Fix quoting bug. | |||||
2009-10-17 | 2009-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+6 | |
* aclocal/check-custom-bsp.m4: Remove "${srcdir}/${RTEMS_TOPdir}/make/custom/$1". * aclocal/check-bsps.m4: Remove "blacklist". | |||||
2009-10-16 | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* aclocal/bsp-alias.m4: Remove bare BSP (Abandoned). | |||||
2009-10-16 | added COBRA5475 BSP | Thomas Doerfler | 1 | -0/+9 | |
2009-10-16 | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* aclocal/bsp-alias.m4: Pickup bsps from c/src/lib/libbsp/<cpu>/<bsp_family>/make/custom*.cfg. | |||||
2009-10-15 | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* aclocal/check-bsps.m4: Pickup bsps from c/src/lib/libbsp/<cpu>/<bsp_family>/make/custom*.cfg. | |||||
* aclocal/check-custom-bsp.m4: Let _RTEMS_CHECK_CUSTOM_BSP look for *.cfg into c/src/lib/libbsp/<cpu>/<bsp_family>/make/custom. | |||||
2009-10-14 | 2009-10-14 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* aclocal/canonical-target-name.m4, aclocal/enable-posix.m4: Remove posix/unix simulator. | |||||
2009-10-01 | 2009-10-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+5 | |
* aclocal/bsp-alias.m4: Add BSP for GDB ARM simulator so we can easily experiment with and debug different ARM architectural variations. | |||||
2009-09-14 | 2009-09-14 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* aclocal/check-bsps.m4: Add csb337 bsp family. | |||||
2009-07-23 | 2009-07-23 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* aclocal/enable-itron.m4: Default to not building itron. | |||||
2009-05-28 | 2009-05-28 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* aclocal/bsp-alias.m4: Add csb637 as variant of csb337. | |||||
2009-02-27 | * README: Added NCS. | Thomas Doerfler | 1 | -0/+5 | |
* Makefile.am, configure.ac, preinstall.am: Added BSP variants. * console/console-config.c, clock/clock-config.c, ssp/ssp.c: Fixed register settings. Cleanup. * include/bsp.h: Added network defines and functions. * include/lpc24xx.h: Added AHB and EMC defines. Fixed Ethernet status sizes. * include/system-clocks.h, misc/system-clocks.c: Added micro seconds delay function that uses Timer 1. Changed PLL setup. * network/network.c, startup/bspreset.c, startup/linkcmds.lpc2478, startup/linkcmds.lpc2478_ncs, startup/linkcmds.lpc2478_ncs_ram: New files. * startup/bspstart.c: Added EMC initialization. Changes for ROM boot. | |||||
2009-02-19 | 2009-02-19 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* aclocal/bsp-alias.m4: Add simsh2e. | |||||
2009-02-06 | 2009-02-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+1 | |
* Makefile.maint: rtems_api=4.10. | |||||
2009-02-06 | 2009-02-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.maint: Dump stuff hanging around for much too long. | |||||
2009-02-06 | 2009-02-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* aclocal/canonical-target-name.m4: Remove comment referring to HPUX9. | |||||
2009-02-05 | 2009-02-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Remove pck6 BSP. | |||||
2008-12-31 | 2008-12-31 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* config-ml.in: Comment out arm/thumb exception (Add arm/thumb multilib). | |||||
2008-12-30 | 2008-12-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* aclocal/check-bsps.m4: remove stray ")" from rtl22xx_t alias. | |||||
2008-12-22 | 2008-12-22 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* aclocal/canonical-target-name.m4: Remove tic4x. | |||||
2008-12-04 | 2008-12-04 Jukka Pietarinen <jukka.pietarinen@mrf.fi> | Joel Sherrill | 1 | -0/+4 | |
* README.configure: Add Lattice Mico32 support. | |||||
2008-10-14 | 2008-10-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+5 | |
* aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add h8sxsim as variant of h8sim. | |||||
2008-10-02 | 2008-10-02 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+5 | |
* README.configure: Add new M32R port. It is just a beginning but the BSP is functional enough to initialize and shutdown RTEMS. | |||||
* README.configure, aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add M32C port and m32csim BSP. | |||||
2008-10-01 | 2008-10-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* VERSION: Bump version to 4.9.99.0 | |||||
2008-10-01 | 2008-10-01 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
PR 1324/bsps * aclocal/check-bsps.m4: Revert Joel's icecube patch. | |||||
2008-09-29 | 2008-09-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* MAINTAINERS: Remove myself from avr. | |||||
2008-09-25 | 2008-09-25 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+7 | |
* README.configure, aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Recognize the the GDB SuperH simulator is just an architectural simulator and does not include devices. Rename existing simulator BSP configurations to simsh1 and simsh2 and add simsh4. | |||||
2008-09-24 | 2008-09-24 Ralf Corsépius <ralf.corsepius@rtems.org> | Joel Sherrill | 1 | -0/+5 | |
PR 1324/bsps * aclocal/check-bsps.m4: Add missing icecube. | |||||
2008-09-22 | 2008-09-22 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* aclocal/version.m4: Bump RTEMS_API to 4.10. Bump _RTEMS_VERSION to 4.9.99.0. | |||||
2008-09-22 | added BSP for ARM LPC24xx | Thomas Doerfler | 1 | -0/+5 | |
2008-09-09 | 2008-09-09 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* README.configure: Updated list of BSPs. |
