* librdbg/src/ptrace.c: Remove warning.
* libcsupport/include/ringbuf.h: Use uint8_t instead of char for raw
data buffer.
* rtems/src/regiongetfreeinfo.c: Return RTEMS_SUCCESSFUL instead of
RTEMS_INVALID_ADDRESS on success path.
* libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_load_tar.c: Use uint8_t
instead of char for raw data buffer.
* samples/hello/sptest.adb, sptests/sp03/sptest.adb,
sptests/sp04/sptest.adb, sptests/sp05/sptest.adb,
sptests/sp07/sptest.adb, sptests/sp13/sptest.adb,
sptests/sp14/sptest.adb, sptests/sp20/sptest.adb,
sptests/sp24/sptest.adb, tmtests/tm01/tmtest.adb,
tmtests/tm02/tmtest.adb, tmtests/tm03/tmtest.adb,
tmtests/tm04/tmtest.adb, tmtests/tm05/tmtest.adb,
tmtests/tm06/tmtest.adb, tmtests/tm07/tmtest.adb,
tmtests/tm08/tmtest.adb, tmtests/tm09/tmtest.adb,
tmtests/tm10/tmtest.adb, tmtests/tm11/tmtest.adb,
tmtests/tm12/tmtest.adb, tmtests/tm13/tmtest.adb,
tmtests/tm14/tmtest.adb, tmtests/tm15/tmtest.adb,
tmtests/tm16/tmtest.adb, tmtests/tm17/tmtest.adb,
tmtests/tm18/tmtest.adb, tmtests/tm19/tmtest.adb,
tmtests/tm20/tmtest.adb, tmtests/tm21/tmtest.adb,
tmtests/tm22/tmtest.adb, tmtests/tm23/tmtest.adb,
tmtests/tm24/tmtest.adb, tmtests/tm25/tmtest.adb,
tmtests/tm28/tmtest.adb, tmtests/tm29/tmtest.adb,
tmtests/tmck/tmtest.adb, tmtests/tmoverhd/dummy_rtems.adb,
tmtests/tmoverhd/tmtest.adb: Remove warnings.
* rtems.adb: Remove gcc 4.x warnings.
* include/.cvsignore: New file.
* .cvsignore: New file.
* startup/linkcmds, startup/linkcmds.ram, startup/linkcmds.rom: Fix
overflow of _CPU_Interrupt_stack_high calculation.
* sh7045/sci/sci.c, sh7045/sci/sci_termios.c: Remove warnings.
* comm/tty_drv.c: Modified to support addition of parameter to ISRs.
* libchip/network/dec21140.c, libchip/network/elnk.c,
libchip/network/if_fxp.c, libchip/serial/mc68681.c:
Modified parameter list to remove warnings.
* 3c509/3c509.c, ne2000/ne2000.c: Modified parameters to
remove warnings.
* console/console.c, wd8003/wd8003.c: Added support for
addition of parameter in ISRs.
* clock/ckinit.c, console/console.c: Added support for
* network/network.c: Modified parameter list to remove
warnings.
* gccnewlib/gccnewlib.add: Suppress building tools not supported by
avr, h8300 and mips.
* rtemsdoc/supplement.add.in, rtemsdoc/templ.add.in: Misc.
%infodir/dir handling changes.
* rtemsdoc/rtemsdoc.add: Use BuildRequires instead of BuildPreReq
(rpm anachronism).
* gdb/base-gdb.add, gdb/gdb.add: Misc. %infodir/dir handling
changes.
* gccnewlib/base-g77.add, gccnewlib/base-gcc.add,
gccnewlib/base-gcj.add, gccnewlib/base-gfortran.add,
gccnewlib/base-gnat.add: Misc. %infodir/dir handling changes.
* common/common.add.in: Use FC compliant BuildRoot.
* gccnewlib/gccnewlib.add: Remove gnatgcc hacks.
Misc %infodir/dir handling changes.
* gccnewlib.add: Remove gnatgcc hacks.
* target-c++.add, target-g77.add, target-gcj.add,
target-gfortran.add, target-gnat.add, target-objc.add:
Requires: %{rpmprefix}%{gcc_target}-gcc = %{version}-%{release}.
* Makefile.am: Remove dmv177 and ppcn_60x.
* custom/dmv177.cfg: Removed.
* libfs/src/dosfs/msdos_format.c, librpc/src/xdr/xdr.c: Added
initialization to remove warnings.
* libchip/network/cs8900.c, libchip/network/i82586.c,
libchip/network/open_eth.c, libchip/network/sonic.c,
libchip/serial/mc68681.c: Modified types to remove
warnings. Added initialization to remove warnings.
PR 782/rtems
* rtems.ads: Remove stray ';'.
* rtems.adb: Stub Task_Variable_Add, Task_Variable_Get,
Task_Variable_Delete.
* binutils/base-binutils.add, binutils/binutils.add:
* configure.ac: Reflect changes to autotools/*.
* autotools/Makefile.am: Update.
* autotools/automake-rtems.spec.in, autotools/autoconf-rtems.spec.in:
Remove.
* autotools/automake.add, autotools/autoconf.add,
autotools/header.add: New.
* autotools/Makefile.am: Streamline specs generation with other
tools.
* mptests/mp01/config.h, samples/base_mp/config.h,
samples/base_sp/config.h, samples/hello/config.h,
samples/ticker/config.h, sptests/sp01/config.h,
sptests/sp02/config.h, sptests/sp03/config.h, sptests/sp04/config.h,
sptests/sp05/config.h, sptests/sp06/config.h, sptests/sp07/config.h,
sptests/sp08/config.h, sptests/sp09/config.h, sptests/sp11/config.h,
sptests/sp12/config.h, sptests/sp13/config.h, sptests/sp14/config.h,
sptests/sp15/config.h, sptests/sp16/config.h, sptests/sp17/config.h,
sptests/sp19/config.h, sptests/sp20/config.h, sptests/sp21/config.h,
sptests/sp22/config.h, sptests/sp23/config.h, sptests/sp24/config.h,
sptests/sp25/config.h, tmtests/tm01/config.h, tmtests/tm02/config.h,
tmtests/tm03/config.h, tmtests/tm04/config.h, tmtests/tm05/config.h,
tmtests/tm06/config.h, tmtests/tm07/config.h, tmtests/tm08/config.h,
tmtests/tm09/config.h, tmtests/tm10/config.h, tmtests/tm11/config.h,
tmtests/tm12/config.h, tmtests/tm13/config.h, tmtests/tm14/config.h,
tmtests/tm15/config.h, tmtests/tm16/config.h, tmtests/tm17/config.h,
tmtests/tm18/config.h, tmtests/tm19/config.h, tmtests/tm20/config.h,
tmtests/tm21/config.h, tmtests/tm22/config.h, tmtests/tm23/config.h,
tmtests/tm24/config.h, tmtests/tm25/config.h, tmtests/tm28/config.h,
tmtests/tm29/config.h, tmtests/tmck/config.h,
tmtests/tmoverhd/config.h: Include <rtems/confdefs.h> instead of
<confdefs.h> (obsolete).
* libnetworking/kern/kern_mib.c, libnetworking/sys/libkern.h:
Update from FreeBSD.
* configure.ac: fix evaluating --enable-ada.
* ada/Makefile.am: Use preinstall.am
* ada/preinstall.am: New.
* custom/ppcn_60x.cfg: Remove (Gone from libbsp).
* score/src/objectidtoname.c: Removed warnings
* irq/irq.c, start/start.S: Removed warnings
* New BSP.
* console/config.c: New files.
* gccnewlib/gccnewlib.add: Don't build mips-gcj. Further gnat
cleanup.
* rtemsdoc/supplement.add.in, rtemsdoc/templ.add.in: Misc. info
fixes.
* gccnewlib/base-gnat.add, gccnewlib/gccnewlib.add,
gccnewlib/target-gnat.add: Abandon Gnat for gcc < 4.0
