* | Added some C++/GNU sections. | Joel Sherrill | 1999-07-03 | 1 | -1/+8 |
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> that splits | Joel Sherrill | 1999-07-02 | 36 | -121/+131 |
| | | | | | | boot_card() and main() into separate files to ease configuration of other packages. This was a big step in the way to build TCL, ncurses, and zlib for RTEMS. | ||||
* | Added code to initialize the /etc/group and /etc/passwd files. | Joel Sherrill | 1999-07-02 | 6 | -0/+273 |
* | Fixed format strings and warnings. | Joel Sherrill | 1999-07-02 | 6 | -27/+27 |
* | Reentrant versions added by Joel. Signficant formatting cleanup. | Joel Sherrill | 1999-07-02 | 7 | -346/+529 |
* | Password and group routines added by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 1999-07-02 | 7 | -1/+749 |
* | Patch from Eric Valette <valette@crf.canon.fr> to clean up the | Joel Sherrill | 1999-07-01 | 77 | -709/+751 |
| | | | | previous submission. | ||||
* | Added error status for bad return pointer argument on rtems_task_set_priority. | Joel Sherrill | 1999-07-01 | 1 | -0/+1 |
* | Corrected formatting so argument was in code font. | Joel Sherrill | 1999-07-01 | 1 | -1/+1 |
* | Fixed reference to initialize_executive to use the current name. | Joel Sherrill | 1999-07-01 | 1 | -1/+2 |
* | Filled in. | Joel Sherrill | 1999-07-01 | 1 | -10/+30 |
* | Cleaned up and much neater. | Joel Sherrill | 1999-07-01 | 1 | -19/+33 |
* | Honor 0 as PID of caller. | Joel Sherrill | 1999-07-01 | 2 | -2/+2 |
* | Another attempt at getting everything to build with the new powerpc | Joel Sherrill | 1999-07-01 | 1 | -1/+1 |
| | | | | libcpu. | ||||
* | Fixed typo. | Joel Sherrill | 1999-07-01 | 1 | -2/+2 |
* | Added signal_2 file to contain signal(2). | Joel Sherrill | 1999-07-01 | 1 | -1/+1 |
* | New file to implement signal(2). | Joel Sherrill | 1999-07-01 | 2 | -0/+100 |
* | Modified to reflect change in calling sequence of mount(). | Joel Sherrill | 1999-07-01 | 2 | -2/+2 |
* | Test modified to reflect change in calling sequence of mount(). | Joel Sherrill | 1999-07-01 | 2 | -20/+20 |
* | Cleaned up to behave properly -- does not make a directory in the | Joel Sherrill | 1999-07-01 | 1 | -2/+1 |
| | | | | install tree and does not "cd wrapup." | ||||
* | Now preinstalls header files. | Joel Sherrill | 1999-07-01 | 1 | -4/+8 |
* | Removed mkdir of libcpu. This should have been at the top of the tree. | Joel Sherrill | 1999-07-01 | 1 | -1/+0 |
* | Remove mkdir command. It should be at the top level of the tree. | Joel Sherrill | 1999-07-01 | 1 | -1/+0 |
* | Modified to provide symbols with and without leading underscore in order | Joel Sherrill | 1999-07-01 | 1 | -0/+2 |
| | | | | to support a.out and ELF. | ||||
* | Modified to support ELF. Before SYM() macro was not used consistently. | Joel Sherrill | 1999-07-01 | 2 | -10/+10 |
* | Modified to ignore console interrupts. Otherwise console interrupts were | Joel Sherrill | 1999-07-01 | 1 | -2/+3 |
| | | | | Ada exceptions. Fixed by Joel with advice from Jiri. | ||||
* | Removed hack to set __USER_LABEL_PREFIX__ since late model gcc's and | Joel Sherrill | 1999-07-01 | 3 | -3/+0 |
| | | | | | egcs source tree handle this correctly. No one should be using gcc 2.7.2 anymore. | ||||
* | Added include/libcpu to list of directories made. | Joel Sherrill | 1999-07-01 | 1 | -1/+1 |
* | Patch from Ralf Corsepius to enhance autogen's behavior. | Joel Sherrill | 1999-07-01 | 1 | -1/+6 |
* | Regenerated. | Joel Sherrill | 1999-07-01 | 2 | -464/+294 |
* | Added dummy gnatinstallhandler code for all BSPs. This lets Ada programs | Joel Sherrill | 1999-06-24 | 34 | -33/+50 |
| | | | | link even if they do not actually support Ada interrupts. | ||||
* | Corrected and fleshed out. | Joel Sherrill | 1999-06-18 | 1 | -43/+2 |
* | Patch from Eric Valette <valette@crf.canon.fr> based on bug report from | Joel Sherrill | 1999-06-18 | 1 | -1/+0 |
| | | | | | David.Decotigny@irisa.fr and discussion with Joel. Basically interrupts were enabled too early in this BSP. | ||||
* | Removed pc386 specific command. | Joel Sherrill | 1999-06-18 | 1 | -3/+0 |
* | Switched to using right INSTALL command after report from | Joel Sherrill | 1999-06-17 | 3 | -3/+3 |
| | | | | Ian Lance Taylor <ian@airs.com>. | ||||
* | Patch from Ian Lance Taylor <ian@airs.com> to use INSTALL_CHANGE instead | Joel Sherrill | 1999-06-17 | 1 | -1/+1 |
| | | | | of INSTALL_DATA. | ||||
* | Patcg from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1999-06-16 | 33 | -673/+508 |
| | | | | | | | -- configure now fails to detect the toolchain for linux-posix. As work-around, I have reverted to the old behavior of RTEMS_TARGET_CPU_NAME, thus no_cpu/no_bsp will fail badly in configure again. | ||||
* | Regenerated | Joel Sherrill | 1999-06-15 | 0 | -0/+0 |
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1999-06-15 | 47 | -378/+441 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | > When I run my script that just repeatedly builds different targets, some > of them die with an error like this: > > Making all RTEMS_BSP=gen68360 in cpugmake[5]: Entering directory > `/usr1/rtems/build/build-m68k-rtems/c/src/exec/score/cpu' > Making all RTEMS_BSP=gen68360 in @RTEMS_CPU@ > /bin/sh: @RTEMS_CPU@: No such file or directory > gmake[5]: *** [all] Error 1 > gmake[5]: Leaving directory > `/usr1/rtems/build/build-m68k-rtems/c/src/exec/score/cpu' > > It is not always the same variable substitution that fails. Sometimes it > is @INSTALL@. But reliably, it is a variable substitution that is > failing. > > Do you have any idea why this happens? Yep, I think I know what's going on. AC_SUBST(RTEMS_CPU) is missing in configure.ins, thus @RTEMS_CPU@ in target.cfg.in doesn't get substituted correctly, causing the bug above. Due to the redundancy of RTEMS_CPU, other most BSPs don't seem to be affected. Other similar problems probably exist for the unix/posix bsp and the hppa.1 cpu, because their */tools/*Makefile.ams require RTEMS_CPU, too. | ||||
* | Attempt at getting desired ioctl.h included. :) | Joel Sherrill | 1999-06-15 | 1 | -1/+1 |
* | After comments D. V. Henkel-Wallace <gumby@zembu.com>, the interface to | Joel Sherrill | 1999-06-15 | 14 | -116/+20 |
| | | | | mount() was changed to avoid the use of a string as the options. | ||||
* | Regenerated. | Joel Sherrill | 1999-06-15 | 0 | -0/+0 |
* | Patch from Rosimildo DaSilva <rdasilva@connecttel.com> to make C++ | Joel Sherrill | 1999-06-15 | 4 | -3/+23 |
| | | | | | exceptions work on the pc386 BSP with i386-elf. This patch also included changes to the i386-rtemself egcs configuration. | ||||
* | Directives -> services. | Joel Sherrill | 1999-06-15 | 1 | -4/+4 |
* | Some stuff added. | Joel Sherrill | 1999-06-15 | 1 | -38/+131 |
* | Significantly enhanced. At least the per routine pages for this chapter | Joel Sherrill | 1999-06-15 | 1 | -59/+349 |
| | | | | are now filled in. | ||||
* | RTEMS_FILESYSTEM_READ_WRITE_ONLY changed to RTEMS_FILESYSTEM_READ_WRITE | Joel Sherrill | 1999-06-14 | 7 | -7/+7 |
| | | | | for simplicity. | ||||
* | Wrong prototype corrected. | Joel Sherrill | 1999-06-14 | 3 | -3/+3 |
* | Warning removal from D. V. Henkel-Wallace <gumby@zembu.com>. | Joel Sherrill | 1999-06-14 | 7 | -24/+18 |
* | Patch ("FIX: no_cpu/no_bsp") from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1999-06-14 | 38 | -957/+1021 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | This patch should fix the nastiest configuration bugs for no_cpu/no_bsp. With this patch applied, configure --target=no_cpu-rtems now correctly acknowledges its configuration, but later fails building when trying to build libcsupport (I leave this problem for you :-). Fixes/Changes: * aclocal/canonicalize-target-name.m4: use RTEMS_CPU instead of target_cpu, switch to a native compiler setup if target = no_cpu*rtems, ie. implicitly use host=target (native) and RTEMS_CPU=no_cpu for --target=no_cpu*rtems. * add no_bsp/bsp_specs (Support -qrtems, -qrtems_debug; please check before adding :-) * Use RTEMS_CANONICALIZE_TARGET_CPU instead of AC_CANONICAL_SYSTEM in toplevel/configure.in * All references to $target_cpu in aclocal/*.m4, Makefile.ins and *.cfg files changed to RTEMS_CPU * bug fixes to exec/score/cpu/no_cpu/wrap (This part of the patch may result into patch rejections, because your recently posted patch may also have addressed this problem). After applying this patch, please do: cvs add c/src/lib/libbsp/no_cpu/no_bsp/bsp_specs ./autogen |
