in the previous commits.
to convert the libmisc directory from Makefile.in to Makefile.am.
to convert the psxtests directory from Makefile.in to Makefile.am.
to convert the tmtests directory from Makefile.in to Makefile.am.
to convert the sample tests to automake.
by the same application.
+ Cleaned up code.
+ Corrected enable/disable of dispatch.
+ Added tests for sem_open, sem_close, and sem_unlink.
+ Yellow lined sem_open, sem_close, sem_unlink,
_POSIX_Semaphore_Delete, _POSIX_Semaphore_Name_to_id,
and _POSIX_Semaphore_Create_support. Except for MP, pshared
OBJECT_REMOTE, and out of memory paths.
can be included from the same file.
Synthesizer Control Register to remove use of single letter names.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
<corsepiu@faw.uni-ulm.de> to correct the constraints on the
inline assembly language macro for sh_disable_interrupt.
1. SH-Port:
* Many files renamed.
applying VPATH.
2. SH1-Port
3. SH2-Port
* Merged
you don't mind).
and powerpc targets.
such that the simulator is enabled.
Also corrected a typo which prevented the simulator files from being
included in the file list.
