* 2000-10-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-186-34/+58
| | | | | | | * cpu_asm.S, rtems/score/cpu.h: Modified to better support multilibing. These changes result in the code being able to compile with the default gcc settings. It is not functional in this configuration but does compile.
* 2000-10-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-184-10/+26
| | | | | * rtems/score/c4x.h: Modified to properly multilib. This required using only macros predefined by gcc.
* 2000-10-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-184-10/+58
| | | | | | * include/confdefs.h: Modified code that accounts for initialization task/threads with greater than minimum stack sizes so it would compile even if optional APIs are disabled.
* 2000-10-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-172-2/+7
| | | | | * irq/Makefile.am, irq/idt.c: Added idt.c since it has been moved libcpu/i386 to libbsp/i386/shared/irq.
* 2000-10-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-176-4/+19
| | | | | * startup/Makefile.am: Added idt.c since it has been moved libcpu/i386 to libbsp/i386/shared/irq.
* 2000-10-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-173-290/+6
| | | | | * idt.c, Makefile.am: Moved idt.c to libbsp/i386/shared so i386 RTEMS can be multilib'ed.
* 2000-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-124-0/+22
| | | | | * include/confdefs.h: Account for initialization tasks and threads which use larger than minimum stack sizes.
* 2000-10-12 Nick Simon <Nick.SIMON@syntegra.bt.co.uk>Joel Sherrill2000-10-122-1/+6
| | | | | * shared/src/cache_manager.c: Minor bug fix -- changed > to >= so the last address is invalidated.
* 2000-10-12 John S Gwynne <jgwynne@mrcday.com>Joel Sherrill2000-10-129-79/+285
| | | | | | | | | | | | | | | | | | | | | | * start/start.c: Modified to support generation of ram_init. * start/ram_init.ld, BSP/start/ram_init.sed: New files. These changes enable RTEMS to automatically generate the ram_init file used by gdb with the BDM patches. The 332 has on-board chip select lines (for RAM and FLASH) that must be configured before use of these peripherals. These patches parse data from start.c where the chip select lines are configured in the runtime executable and automatically generates the gdb initialization file using the same settings. A great time saver. A similar file, ram_init_FW (flash writable), is also generated that the flash programming tool uses. * start/Makefile.am: Modified to support above. * CPU/sim.h: Modified to support above. * startup/except_vect_332_ROM.S: Moved to start so it would not be included in libbsp.a. Moving it to start ensures it is available as a single object file. * start/except_vect_332_ROM.S: Moved from startup. * startup/linkcmds, startup/linkcmds_ROM: Fixes to the memory map shown in the comments.
* 2000-10-12 John S Gwynne <jgwynne@mrcday.com>Joel Sherrill2000-10-125-15/+40
| | | | | | | | | | | | | | * sim.h: These changes enable RTEMS to automatically generate the ram_init file used by gdb with the BDM patches. The 332 has on-board chip select lines (for RAM and FLASH) that must be configured before use of these peripherals. These patches parse data from start.c where the chip select lines are configured in the runtime executable and automatically generates the gdb initialization file using the same settings. A great time saver. A similar file, ram_init_FW (flash writable), is also generated that the flash programming tool uses. * BSP/start/start.c: Must be modified to support above. * BSP/start/ram_init.ld, BSP/start/ram_init.sed: New files.
* changed version to ss-20000929Joel Sherrill2000-09-291-1/+1
* 2000-09-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-296-10/+38
| | | | | * sp20/sp20.scn: Corrected to reflect new addition. * sp20/system.h: Removed comment reflecting history.
* 2000-09-29 Stephan Merker <merker@decrc.abb.de>Joel Sherrill2000-09-2910-26/+128
| | | | | | * sp20/getall.c, sp20/init.c, sp20/system.h, sp20/task1.c: Added new task to test sequence of altering a period's length while it is still active.
* 2000-09-29 Stephan Merker <merker@decrc.abb.de>Joel Sherrill2000-09-298-6/+42
| | | | | | | * include/rtems/rtems/ratemon.h, src/ratemonperiod.c, src/ratemontimeout.c: Add next_length field so period length can be changed by the the sequence period(X), period(not X) with no intervening cancel or expiration.
* 2000-09-29 Charles-Antoine Gauthier <charles.gauthier@nrc.ca>Joel Sherrill2000-09-2926-0/+598
| | | | | | * startup/linkcmds: Added lines so DWARF debug information would be available. Otherwise gdb complains that the offsets for the debug info are incorrect and doesn't load the files.
* 2000-09-29 Charles-Antoine Gauthier <charles.gauthier@nrc.ca>Joel Sherrill2000-09-2916-27/+369
* 2000-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-284-12/+22
| | | | | * monitor/mon-driver.c: Accounted for addition of "_entry" to fields in rtems_driver_address_table.
* 2000-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-286-24/+36
| | | | | | * include/rtems/io.h (rtems_driver_address_table): Added "_entry" to all names. * src/io.c: Accounted for above.
* 2000-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-28107-402/+417
| | | | | | | | | | | | | | | * libc/libio.h (rtems_filesystem_file_handlers_r, rtems_filesystem_operations_table): Added _h to all structure fields to indicate they are "handlers". * libc/libio_.h, libc/chdir.c, libc/chmod.c, libc/chown.c, libc/close.c, libc/eval.c, libc/fchdir.c, libc/fchmod.c, libc/fcntl.c, libc/fdatasync.c, libc/fstat.c, libc/fsync.c, libc/ftruncate.c, libc/getdents.c, libc/imfs_eval.c, libc/imfs_unlink.c, libc/ioctl.c, libc/ioman.c, libc/link.c, libc/lseek.c, libc/mknod.c, libc/mount.c, libc/open.c, libc/read.c, libc/readlink.c, libc/rmdir.c, libc/stat.c, libc/symlink.c, libc/unlink.c, libc/unmount.c, libc/utime.c, libc/write.c: Modified to reflect above name change.
* 2000-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-282-0/+1578
| | | | | | * rtems_webserver/Makefile.am, rtems_webserver/base64.c, rtems_webserver/base64.c: Renamed base64.c to wbase64.c. * rtems_webserver/sock.c: Added file missed in merger.
* 2000-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-287-8/+26
* 2000-09-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-253-6/+15
| | | | | | | * clock/ckinit.c: Removed include of <bsp.h>. Also switch to macros to get configuration data. * timer/timer.c: Removed include of <bsp.h>. Fixed comment that said 4650 (a mips part).
* 2000-09-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-253-0/+10
| | | | * shmdr/shm_driver.h: Added _AM29K entry. May not be correct.
* 2000-09-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-255-16/+15
| | | | | | | * include/bsp.h: tty_* renamed to console_*. * tty/tty.c: Ditto. * shmsupp/addrconv.c: Typo fixed. * wrapup/Makefile.am: Merge startup not start directory.
* 2000-09-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-252-5/+13
| | | | * ChangeLog: Entry added to wrong file and moved.
* 2000-09-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-255-4/+21
| | | | | | | | * bsp_specs: Formatting more like other bsp_specs. * include/bsp.h: CPU_CLOCK_RATE_MHZ not a real variable to elimate need for including bsp.h in libcpu. * startup/bspstart.c: Ditto. * wrapup/Makefile.am: Did not list shmdr.
* 2000-09-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-254-4/+18
| | | | | * rtems/system.h: Switched a29k and hppa1.1 to using cpuopts.h not targopts.h to reduce dependency on BSP.
* 2000-09-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-254-0/+24
| | | | | * rtems/score/hppa.h: Switched to using cpuopts.h not targopts.h to reduce dependency on BSP.
* 2000-09-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-256-10/+36
| | | | | * rtems/score/a29k.h, rtems/score/cpu.h: Switched to using cpuopts.h not targopts.h to reduce dependency on BSP.
* 2000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-222-1/+6
| | | | | * startup/linkcmds: Use default object format to avoid name changes in object format due to tool version changes.
* 2000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-2213-27/+70
| | | | | | | | | | * machine/types.h, pppd/pppd.h, rtems/rtems_bsdnet_internal.h, rtems_webserver/webmain.c: machine/types.h should not have included rtems.h. It is now including precisely the least amount of low level, yet portable .h files to get the basic RTEMS types defined. This rippled into other files since rtems_bsdnet_internal.h used machine/types.h to include rtems.h.
* 2000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-226-0/+15
| | | | * src/xdr/xdr_float.c: Added A29K support.
* 2000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-222-0/+14
| | | | * clock/clock.S: Commented out non-GNU assembly.
* 2000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-224-3/+7
| | | | * libc/newlibc.c: Removed _A29K specific ifdef.
* 2000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-2214-16/+174
| | | | | | * amd.ah, cpu.c, cpu_asm.S, register.ah, sig.S, rtems/score/cpu.h: Updated and fixed minor things. Commented out offensive assembly and made applications link.
* 2000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-229-10/+82
| | | | | | | | | | | | * start/crt0.S: Renamed to start/start.S. * start/start.S: Formerly start/crt0.S. * startup/linkcmds: New file. GNU linker script that is not correct for the target board but links programs. * bsp_specs: Use linkcmds. * include/Makefile.am, start/Makefile.am startup/Makefile.am: Now work. * startup/bspstart.c, startup/setvec.c: "#if 0"'ed out references to reoutines in assembly that are in turn "#if 0"'ed out.
* 2000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-221-0/+4
| | | | * Makefile.am: Removed definition of ACLOCAL_AMFLAGS.
* 2000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-227-4/+15
| | | | * Makefile.am: Removed GENERATED_FILES from list of TEXINFOS.
* 2000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-2210-34/+52
| | | | | | * Makefile.am, cpu_asm.S, psmacro.ah, rtems/score/cpu.h: First attempt to compile with GNU tools. Minor modifications to compile enough to get to assembler errors.
* 2000-09-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-204-2/+10
| | | | | * src/objectgetbyindex.c: Do not enable dispatching on an error path it was not disabled on.
* changed version to ss-20000919Joel Sherrill2000-09-190-0/+0
* changed version to ss-20000919Joel Sherrill2000-09-191-1/+1
* 2000-09-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-153-0/+9
| | | | | * include/mvme16x_hw.h: Include rtems/score/targopts.h so we can check which BSP this is being used with.
* 2000-09-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-152-1/+5
| | | | * Makefile.am: Referenceed aclocal/enable-hwapi.m4 that was removed.
* 2000-09-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-142-15/+4
| | | | * aclocal/enable-hwapi.m4: Now longer used and removed.
* 2000-09-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-142-2/+4
| | | | * automake/lib.am: Remove leaf.cfg.
* 2000-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-134-7/+7
| | | | * bsp_specs, console/Makefile.am, include/Makefile.am: Clean up.
* 2000-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-1312-70/+75
| | | | | | | | * Makefile.am, bsp_specs, configure.in, console/Makefile.am, include/Makefile.am, irq/Makefile.am, irq/irq.c, start/Makefile.am, startup/Makefile.am, startup/exit.c, wrapup/Makefile.am: Made to conform to current practice concerning automake and autoconf. Corrected minor warnings.
* 2000-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-136-80/+8
| | | | | * custom/arm_bare_bsp.cfg, custom/armulator.cfg, custom/dmv177.cfg, custom/mcp750.cfg, custom/vegaplus.cfg: Clean up.
* 2000-09-13 Emmanuel Raguet <raguet@crf.canon.fr>Joel Sherrill2000-09-132-0/+101
| | | | | | * vegaplus BSP submitted by Emmanuel Raguet <raguet@crf.canon.fr> and Eric Valette <valette@crf.canon.fr>. * custom/vegaplus.cfg: New file.
