To achieve this:
been removed.
./clock/clock.c,v
./console/Makefile.in,v
./console/config.c,v
./console/console.c,v
./console/console.h,v
./console/debugio.c,v
./console/i8042.c,v
./console/i8042_p.h,v
./console/i8042vga.c,v
./console/i8042vga.h,v
./console/ns16550.c,v
./console/ns16550.h,v
./console/ns16550_p.h,v
./console/ns16550cfg.c,v
./console/ns16550cfg.h,v
./console/vga.c,v
./console/vga_p.h,v
./console/z85c30.c,v
./console/z85c30.h,v
./console/z85c30_p.h,v
./console/z85c30cfg.c,v
./console/z85c30cfg.h,v
./include/Makefile.in,v
./include/bsp.h,v
./include/chain.h,v
./include/coverhd.h,v
./include/extisrdrv.h,v
./include/nvram.h,v
./include/pci.h,v
./include/tod.h,v
./network/Makefile.in,v
./network/amd79c970.c,v
./network/amd79c970.h,v
./nvram/Makefile.in,v
./nvram/ds1385.h,v
./nvram/mk48t18.h,v
./nvram/nvram.c,v
./nvram/prepnvr.h,v
./nvram/stk11c68.h,v
./pci/Makefile.in,v
./pci/pci.c,v
./start/Makefile.in,v
./start/start.s,v
./startup/Makefile.in,v
./startup/bspclean.c,v
./startup/bspstart.c,v
./startup/bsptrap.s,v
./startup/device-tree,v
./startup/genpvec.c,v
./startup/linkcmds,v
./startup/rtems-ctor.cc,v
./startup/sbrk.c,v
./startup/setvec.c,v
./startup/spurious.c,v
./startup/swap.c,v
./timer/Makefile.in,v
./timer/timer.c,v
./tod/Makefile.in,v
./tod/cmos.h,v
./tod/tod.c,v
./universe/Makefile.in,v
./universe/universe.c,v
./vectors/Makefile.in,v
./vectors/README,v
./vectors/align_h.s,v
./vectors/vectors.s,v
./wrapup/Makefile.in,v
./Makefile.in,v
./README,v
./STATUS,v
./bsp_specs,v
./clock/clock.c,v
./console/i8042.c,v
./console/i8042vga.c,v./console/i8042vga.h,v
./console/vga.c,v
./console/vga_p.h,v
./include/bsp.h,v
./include/chain.h,v
./include/nvram.h,v
./include/pci.h,v
./include/tod.h,v
./nvram/ds1385.h,v
./nvram/mk48t18.h,v
./nvram/nvram.c,v
./nvram/prepnvr.h,v
./pci/Makefile.in,v
./pci/pci.c,v
./start/start.s,v
./startup/sbrk.c,v
./startup/swap.c,v
./timer/timer.c,v
./tod/Makefile.in,v
./tod/cmos.h,v
./tod/tod.c,v
./vectors/README,v
./Makefile.in,v
./README,v
./STATUS,v
./bsp_specs,v
You will find enclosed a patch which contains, for Intel PC386 target :
- an Ethernet driver for DEC21140 device based boards.
- a simple cache management with paging mechanism.
based board.
that added ifdef on the pc386.
undefined problem.
that performed the sequence open/write/close/open/read/close on a file.
It did not get the correct result since the file descriptor was reused.
portion is now in the libchip tree and the dmv177 configuration is in
the dmv177 bsp. The performance impact of libchip'ing this driver
was minimal.
hack through some paths to check error checking paths without a network
driver.
to avoid dereferencing NULLs.
and placed in the right shareable directories.
is very useful when debugging a device driver.
