* shared/pci/pcibios.c: replaced pci_find_device implementation by a
pcibios call which already provides the functionality
* startup/ldsegs.S: put IDT and GDT into data segment. The CPU modifies
the 'accessed' bit and GDB's (rtems-gdb-stub) text segment checksum
comparison failed...
* libchip/i2c/i2c-2b-eeprom.c, libchip/i2c/i2c-2b-eeprom.h,
libchip/i2c/i2c-ds1621.c, libchip/i2c/i2c-ds1621.h: New files.
* libchip/Makefile.am, libchip/preinstall.am, wrapup/Makefile.am:
added a simple API/library
for i2c devices and drivers for i2c 2-byte eeproms and a ds1621
temperature sensor; API is documented in libi2c.h
* libi2c/Makefile.am, libi2c/Makefile.in, libi2c/libi2c.c,
libi2c/libi2c.h: New files.
* Makefile.am, configure.ac, preinstall.am, wrapup/Makefile.am: added a
simple API/library for i2c devices and drivers for i2c 2-byte eeproms
and a ds1621 temperature sensor; API is documented in libi2c.h
* mpc6xx/mmu/pte121.c, mpc6xx/mmu/pte121.h: enhancements to mpc6xx page
table support - PTEs can now be modified even if the page table is
already active; bugfix: address range crossing 256MB boundary was not
handled correctly
* mvme5500/start/start.S, shared/start/start.S,
shared/startup/bspstart.c: moved assembly code to C; setdbat now
supports high bats on 7450 CPUs; added argument checking to setdbat;
added getdbat; moved early initialization code (clear_bats) from BSP
to libcpu (CPU_clear_bats_early)
* mpc6xx/mmu/bat.c, mpc6xx/mmu/bat.h, mpc6xx/mmu/mmuAsm.S: moved
assembly code to C; setdbat now supports high bats on 7450 CPUs;
added argument checking to setdbat; added getdbat; moved early
initialization code (clear_bats) from BSP to libcpu
* rtems/powerpc/registers.h: recognize mpc7457 CPU; added definitions
for high bats (#4..7) on 7450 CPUs
* ChangeLog, configure.ac, mpc6xx/exceptions/raw_exception.c,
shared/include/cpuIdent.c, shared/include/cpuIdent.h: recognize
mpc7457 CPU; added definitions for high bats (#4..7) on 7450 CPUs
PR 842/networking
* libnetworking/libc/gethostbydns.c: Avoid use of dprintf(). Rename
dprintf to debugprintf().
* libnetworking/net/zlib.c: Remove.
* libnetworking/net/zlib.h: Remove.
* libnetworking/Makefile.am: Reflect changes above.
* pppd/Makefile.am: Fix typo.
* gccnewlib/gccnewlib.add: Rename src.rpm to *-gcc.src.rpm.
* gccnewlib/target-gcc.add: Reflect changes above.
* gccnewlib/Makefile.am: Re-sort sub-package fragments.
PR 840/rtems:
* include/rtems/irq.h: Fix several typos.
* configure.ac: Add zlib.
* Makefile.am: Add zlib.
* zconf.h: Hard-code using unistd.h.
Hard-code Z_PREFIX.
* zconf.in.h: Remove (Unused).
* zconf.h: Use uint_least*_t types.
* crc32.c, zutil.c, zutil.h: Misc. type fixes.
* Makefile.am: New.
* preinstall.am: New.
trees.c, uncompr.c, zconf.h, zconf.in.h, zutil.c, zutil.h: Reformat
CVS Ids.
* ChangeLog.zlib: Renamed version of zlib's ChangeLog.
* FAQ, INDEX, README, adler32.c, algorithm.txt, compress.c, crc32.c,
crc32.h, deflate.c, deflate.h, gzio.c, infback.c, inffast.c,
inffast.h, inffixed.h, inflate.c, inflate.h, trees.c, trees.h,
uncompr.c, zconf.h, zconf.in.h, zlib.3, zlib.h, zutil.c, zutil.h,
inftrees.h, inftrees.c, ChangeLog: Import from zlib-1.2.2.2.tar.gz.
which included commits to RCS files with non-trunk default branches.
