* aclocal/bsp-configure.m4: Add RTEMS_CHECK_MULTIPROCESSING.
* automake/compile.am: Add test -d $(ARCH) || mkdir $(ARCH) to all
compilation rules (Work-around to an automake bug).
* automake/lib.am: Add test -d $(ARCH) || mkdir $(ARCH) to
make-library.
* aclocal/env-rtemsbsp.m4: Remove RTEMS_BSP_SPECS, PROJECT_RELEASE.
Add project_libdir, libdir. New GCC_SPECS. Various cleanups.
* aclocal/env-rtemscpu.m4: Remove RTEMS_BSP_SPECS, PROJECT_RELEASE.
* aclocal/rtems-top.m4: New PROJECT_ROOT handling.
* automake/compile.am: Remove RTEMS_BSP_SPECS, LD* flags, LINK,
references to bsp_specs. Use project_libdir instead of
$(PROJECT_RELEASE)/lib.
* configure.ac: Activate cpukit. Remove references to c/src/exec.
* kern/Makefile.am: Eliminate LIBNAME.
* lib/Makefile.am: Ditto.
* libc/Makefile.am: Ditto.
* net/Makefile.am: Ditto.
* netinet/Makefile.am: Ditto.
* nfs/Makefile.am: Ditto.
* rtems/Makefile.am: Ditto.
* wrapup/Makefile.am: Use project_libdir instead of
* src/dosfs/Makefile.am: Use AM_CPPFLAGS instead of INCLUDES and
AM_CFLAGS. Eliminate LIBNAME.
* src/imfs/Makefile.am: Use AM_CPPFLAGS instead of INCLUDES and
* wrapup/Makefile.am: Eliminate LIBNAME.
* Makefile.am: Eliminate LIBNAME. Use AM_CPPFLAGS instead of
INCLUDES (Upcoming automake standard).
* Makefile.am: Eliminate LIBNAME. Cosmetical cleanups.
* src/Makefile.am: Add bsplib_DATA. Eliminate LIBNAME. Cosmetical
changes.
* acinclude.m4: Cleanups.
* configure.ac: Build ${srcdir}/../../cpukit/ as ./exec/ instead of
${srcdir}/exec/.
Further adaptations to autoconf >= 2.50.
* Makefile.am: Fix oversights in previous patch.
* startup/Makefile.am: Reformat.
* rtems.S: Remove.
* Makefile.am: Reflect having removed rtems.S. Use AM_CPPFLAGS
instead of INCLUDES (Latest automake standard).
* start/Makefile.am: Fix bug in previous patch.
Really add bsplib_DATA = $(PROJECT_RELEASE)/lib/start$(LIB_VARIANT).o.
Fix bsplib_DATA = $(PROJECT_RELEASE)/lib/rxgen_romld$(LIB_VARIANT).o.
(Didn't make it into cvs at 2002-07-20 :( )
* start/Makefile.am: Eliminate PGMS.
bsplib_DATA += $(PROJECT_RELEASE)/lib/except_vect_332_ROM$(LIB_VARIANT).o
bsplib_DATA += $(PROJECT_RELEASE)/lib/ram_init$(LIB_VARIANT)
bsplib_DATA += $(PROJECT_RELEASE)/lib/ram_init_FW$(LIB_VARIANT)
Add bsplib_DATA = $(PROJECT_RELEASE)/lib/rxgen_romld$(LIB_VARIANT).o.
* start/Makefile.am: Remove leftover from eliminating PGM.
Add bsplib_DATA += $(PROJECT_RELEASE)/lib/start16$(LIB_VARIANT).bin.
* capture/capture.c: include <string.h> for memset.
* startup/Makefile.am: Add bsplib_DATA = linkcmds device-tree.
* startup/Makefile.am: Add bsplib_DATA = linkcmds linkcmds-le.
* startup/Makefile.am: Add bsplib_DATA = linkcmds linkcmds.rom
linkcmds.rom2ram.
* startup/Makefile.am: Add bsplib_DATA = linkcmds ghlinkcmds.
* startup/Makefile.am: Add bsplib_DATA = linkcmds rom debugger.
* startup/Makefile.am: Add bsplib_DATA = linkcmds linkcmds_ROM.
* startup/Makefile.am: Add bsplib_DATA = linkcmds gdbinit
linkcmds.flash.
* startup/Makefile.am: Add bsplib_DATA = linkcmds linkcmds.prom
linkcmds.bootp.
* include/rtems/score/apimutex.h (_API_Mutex_Lock): Added missing
_ISR_Disable.
* setup.def: Updated newlib patch to get sh and hppa crt0 mods.
* startup/Makefile.am: Add bsplib_DATA = linkcmds ramlink romlink.
* Makefile.am: Remove setting up bsplibdir.
