* 2003-07-18 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2003-07-233-48/+22
| | | | | | PR 288/rtems * support/new_exception_processing/cpu.c: _ISR_Nest_level is now properly maintained and does not reside in SPRG0.
* 2003-07-18 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2003-07-182-2/+19
| | | | | | PR 288/rtems * rtems/new-exceptions/cpu.h: _ISR_Nest_level is now properly maintained and does not reside in SPRG0.
* 2003-07-18 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2003-07-183-7/+40
| | | | | | | PR 288/rtems * irq/irq_asm.S, startup/bspstart.c: _ISR_Nest_level is now properly maintained and any BSP which does not do so will trip a panic in the shared code.
* 2003-07-18 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2003-07-182-3/+11
| | | | | PR 288/rtems * startup/bspstart.c: _ISR_Nest_level is now properly maintained.
* 2003-07-18 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2003-07-186-8/+80
| | | | | | PR 288/rtems * irq/irq_asm.S, startup/bspstart.c: _ISR_Nest_level is now properly maintained.
* 2003-07-18 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2003-07-183-14/+17
| | | | | | | | PR 415/bsps * pci/detect_raven_bridge.c, startup/bspstart.c: This patch reverts enabling MCP interrupts for the motorola_powerpc BSPs. REASON: pci config space scanning (as e.g. done by the DEC Ethernet driver) would raise machine check exceptions.
* 2003-07-16 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2003-07-184-20/+69
| | | | | | | | | | | PR 428/bsps PR 432/bsps * bootloader/pci.c: Re-instated code that prevents remapping small IO regions, which if remapped would cause i8259 registers to move out from under the #define'd base addresses. * startup/bspstart.c: Reduced BAT2 PCI memory allocation to 256 megs, I incorrectly had extended it which would cause problems with PCI devices that defined prefetchable memory.
* 2003-07-16 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2003-07-183-0/+74
| | | | | | | PR 428/bsps PR 432/bsps * pci/pcibios.c, pci/pcibios.h: Added BSP_pci_Find_Device() which is copied from motorola_shared.
* 2003-07-18 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2003-07-182-75/+164
| | | | | | | | | PR 429/bsps PR 432/bsps * network/elnk.c: Due to a bug in the driver, if multiple packets are queued onto an elnk board, the ISR will deadlock the device with a tx complete interrupt. Lighter tx loads are not affected as they end up submitting single packets to the device.
* 2003-07-18 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2003-07-185-8/+80
| | | | | | | | | | | | | | | | PR 430/rtems * include/rtems/score/watchdog.h: _Watchdog_Ticks_since_boot should be a VOLATILE variable. * src/watchdoginsert.c: 'restart' algorithm needs to enforce reloading the list head in case a TICK interrupt during ISR_Flash() modified the list. This is achieved by a proper VOLATILE cast. Also _Watchdog_Sync_count++ should be protected by _ISR_Disable (prevent corruption in case ISR calls watchdoginsert) * src/watchdogadjust.c: ISR protection added. * src/watchdogtickle.c: ISR protection added. NOTE: PowerPC BSPs using the new exception processing MUST BE UPDATED to maintain _ISR_Nest_level. See also PR288 which provides fixes for the affected BSPs distributed with RTEMS.
* Fixed formatting so scripts work.Joel Sherrill2003-07-181-0/+1
* 2003-07-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-183-2/+7
| | | | | * src/rdbg.c: Use memset instead of bzero (deprecated). * src/servtsp.c: Ditto.
* 2003-07-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-07-172-1/+41
| | | | | | | | | | | | | | | | | | | | | | PR 433/tools * mips-stub.c: Patch from C. M. Heard <heard@pobox.com> described as: The purpose of the patch is to make the stub ignore all characters except '+' (ack) or '-' (nak) when it has transmitted a packet and expects an acknowledgment. Without the patch, putpacket() will retransmit each time it receives anything other than '+' when expecting an ack, and that, bitter experience has found, frequently results in the stub failing to sync up when initially attaching to gdb. I think that rtems users will notice significant improvement in the of the mips stub if this patch is incorporated in the distribution; certainly I did in my stand-aline environment. I should hasten to add that it is only an improvement and not a 100% cure for synchronization problems because '+' characters can (and do) during as message data, and it's still possible for these to be mistaken as acks. I have no idea how to fix that short of redesigning the gdb-remote protocol.
* 2003-07-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-07-161-1/+7
| | | | * ChangeLog: Correct format.
* 2003-07-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-152-2/+6
| | | | * wrapup/Makefile.am: Remove bogus $(MULTISUBDIR).
* 2003-07-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-152-3/+7
* 2003-07-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-152-15/+17
| | | | | * config-ml.in: Partial sync with gcc-3.4's config-ml.in. Add "autoconf-2.5x unquoting" hack.
* PR431. MSDOS Volume semaphore timeout is now NO TIMEOUT. MSDOS volume ↵Chris Johns2003-07-141-0/+4
| | | | opertations will wait for ever.
* MSDOS Volume semaphore timeout is now NO TIMEOUT. MSDOS volume opertations ↵Chris Johns2003-07-141-2/+3
| | | | will wait for ever.
* 2003-07-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-133-1508/+2
| | | | | | * config.sub: Remove (Automatically added by automake, again). * bootstrap: Reflect change above. * configure.ac: Require automake >= 1.7.6.
* 2003-07-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-132-2/+6
| | | | * autotools/automake-rtems.spec.in: Automake-1.7.6.
* 2003-07-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-103-32/+9
| | | | | | * configure.ac: Remove (Merged into ../configure.ac). * Makefile.am: Reflect having merged configure.ac into ../configure.ac
* 2003-07-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-107-67/+22
| | | | | | | * configure.ac: Remove (Merged into ../configure.ac). * Makefile.am, ide/Makefile.am, network/Makefile.am, rtc/Makefile.am, serial/Makefile.am: Reflect having merged configure.ac into ../configure.ac
* 2003-07-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-102-3/+20
| | | | | * configure.ac: Merge-in libchip/configure.ac. Merge-in optman/configure.ac.
* 2003-07-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-0940-81/+78
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ada.am: Add .adp to SUFFIXES. Remove c-compilation rule. * samples/base_sp/Makefile.am: Add init.$(OBJEXT). * samples/hello/Makefile.am: Add init.$(OBJEXT). * samples/ticker/Makefile.am: Add init.$(OBJEXT). * samples/ticker/Makefile.am: Remove VPATH. * sptests/sp01/Makefile.am: Add init.$(OBJEXT). * sptests/sp01/Makefile.am: Don't include */lib.am. * sptests/sp01/Makefile.am: Remove VPATH. * sptests/sp02/Makefile.am: Add init.$(OBJEXT). * sptests/sp02/Makefile.am: Don't include */lib.am. * sptests/sp03/Makefile.am: Add init.$(OBJEXT). * sptests/sp03/Makefile.am: Don't include */lib.am. * sptests/sp04/Makefile.am: Add init.$(OBJEXT). * sptests/sp04/Makefile.am: Don't include */lib.am. * sptests/sp04/Makefile.am: Remove EXPADA. * sptests/sp04/Makefile.am: Remove VPATH. * sptests/sp05/Makefile.am: Add init.$(OBJEXT). * sptests/sp05/Makefile.am: Don't include */lib.am. * sptests/sp06/Makefile.am: Add init.$(OBJEXT). * sptests/sp06/Makefile.am: Don't include */lib.am. * sptests/sp07/Makefile.am: Add init.$(OBJEXT). * sptests/sp07/Makefile.am: Don't include */lib.am. * sptests/sp07/Makefile.am: Remove EXPADA. * sptests/sp08/Makefile.am: Add init.$(OBJEXT). * sptests/sp08/Makefile.am: Don't include */lib.am. * sptests/sp09/Makefile.am: Add init.$(OBJEXT). * sptests/sp09/Makefile.am: Don't include */lib.am. * sptests/sp11/Makefile.am: Add init.$(OBJEXT). * sptests/sp11/Makefile.am: Don't include */lib.am. * sptests/sp12/Makefile.am: Add init.$(OBJEXT). * sptests/sp12/Makefile.am: Don't include */lib.am. * sptests/sp13/Makefile.am: Add init.$(OBJEXT). * sptests/sp13/Makefile.am: Don't include */lib.am. * sptests/sp14/Makefile.am: Add init.$(OBJEXT). * sptests/sp14/Makefile.am: Don't include */lib.am. * sptests/sp15/Makefile.am: Add init.$(OBJEXT). * sptests/sp15/Makefile.am: Don't include */lib.am. * sptests/sp16/Makefile.am: Add init.$(OBJEXT). * sptests/sp16/Makefile.am: Don't include */lib.am. * sptests/sp17/Makefile.am: Add init.$(OBJEXT). * sptests/sp17/Makefile.am: Don't include */lib.am. * sptests/sp19/Makefile.am: Add init.$(OBJEXT). * sptests/sp19/Makefile.am: Don't include */lib.am. * sptests/sp20/Makefile.am: Add init.$(OBJEXT). * sptests/sp20/Makefile.am: Don't include */lib.am. * sptests/sp21/Makefile.am: Add init.$(OBJEXT). * sptests/sp21/Makefile.am: Don't include */lib.am. * sptests/sp22/Makefile.am: Add init.$(OBJEXT). * sptests/sp22/Makefile.am: Don't include */lib.am. * sptests/sp23/Makefile.am: Add init.$(OBJEXT). * sptests/sp23/Makefile.am: Don't include */lib.am. * sptests/sp24/Makefile.am: Add init.$(OBJEXT). * sptests/sp24/Makefile.am: Don't include */lib.am. * sptests/sp25/Makefile.am: Add init.$(OBJEXT). * sptests/sp25/Makefile.am: Don't include */lib.am. * sptests/spsize/Makefile.am: Add init.$(OBJEXT). * sptests/spsize/Makefile.am: Don't include */lib.am. * tmtests/tm01/Makefile.am: Add init.$(OBJEXT). * tmtests/tm01/Makefile.am: Don't include */lib.am. * tmtests/tm02/Makefile.am: Add init.$(OBJEXT). * tmtests/tm02/Makefile.am: Don't include */lib.am. * tmtests/tm03/Makefile.am: Add init.$(OBJEXT). * tmtests/tm03/Makefile.am: Don't include */lib.am. * tmtests/tm04/Makefile.am: Add init.$(OBJEXT). * tmtests/tm04/Makefile.am: Don't include */lib.am. * tmtests/tm05/Makefile.am: Add init.$(OBJEXT). * tmtests/tm05/Makefile.am: Don't include */lib.am. * tmtests/tm06/Makefile.am: Add init.$(OBJEXT). * tmtests/tm06/Makefile.am: Don't include */lib.am. * tmtests/tm07/Makefile.am: Add init.$(OBJEXT). * tmtests/tm07/Makefile.am: Don't include */lib.am. * tmtests/tm08/Makefile.am: Add init.$(OBJEXT). * tmtests/tm08/Makefile.am: Don't include */lib.am. * tmtests/tm09/Makefile.am: Add init.$(OBJEXT). * tmtests/tm09/Makefile.am: Don't include */lib.am. * tmtests/tm10/Makefile.am: Add init.$(OBJEXT). * tmtests/tm10/Makefile.am: Don't include */lib.am. * tmtests/tm11/Makefile.am: Add init.$(OBJEXT). * tmtests/tm11/Makefile.am: Don't include */lib.am. * tmtests/tm12/Makefile.am: Add init.$(OBJEXT). * tmtests/tm12/Makefile.am: Don't include */lib.am. * tmtests/tm13/Makefile.am: Add init.$(OBJEXT). * tmtests/tm13/Makefile.am: Don't include */lib.am. * tmtests/tm14/Makefile.am: Add init.$(OBJEXT). * tmtests/tm14/Makefile.am: Don't include */lib.am. * tmtests/tm15/Makefile.am: Add init.$(OBJEXT). * tmtests/tm15/Makefile.am: Don't include */lib.am. * tmtests/tm16/Makefile.am: Add init.$(OBJEXT). * tmtests/tm16/Makefile.am: Don't include */lib.am. * tmtests/tm17/Makefile.am: Add init.$(OBJEXT). * tmtests/tm17/Makefile.am: Don't include */lib.am. * tmtests/tm18/Makefile.am: Add init.$(OBJEXT). * tmtests/tm18/Makefile.am: Don't include */lib.am. * tmtests/tm19/Makefile.am: Add init.$(OBJEXT). * tmtests/tm19/Makefile.am: Don't include */lib.am. * tmtests/tm20/Makefile.am: Add init.$(OBJEXT). * tmtests/tm20/Makefile.am: Don't include */lib.am. * tmtests/tm21/Makefile.am: Add init.$(OBJEXT). * tmtests/tm21/Makefile.am: Don't include */lib.am. * tmtests/tm22/Makefile.am: Add init.$(OBJEXT). * tmtests/tm22/Makefile.am: Don't include */lib.am. * tmtests/tm23/Makefile.am: Add init.$(OBJEXT). * tmtests/tm23/Makefile.am: Don't include */lib.am. * tmtests/tm24/Makefile.am: Add init.$(OBJEXT). * tmtests/tm24/Makefile.am: Don't include */lib.am. * tmtests/tm25/Makefile.am: Add init.$(OBJEXT). * tmtests/tm25/Makefile.am: Don't include */lib.am. * tmtests/tm28/Makefile.am: Add init.$(OBJEXT). * tmtests/tm28/Makefile.am: Don't include */lib.am. * tmtests/tm29/Makefile.am: Add init.$(OBJEXT). * tmtests/tm29/Makefile.am: Don't include */lib.am. * tmtests/tmck/Makefile.am: Add init.$(OBJEXT). * tmtests/tmck/Makefile.am: Don't include */lib.am. * tmtests/tmoverhd/Makefile.am: Add init.$(OBJEXT). * tmtests/tmoverhd/Makefile.am: Don't include */lib.am.
* 2003-07-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-0918-44/+161
* CleanupRalf Corsepius2003-07-0810-121/+0
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-081-1/+1
| | | | | | | * configure.ac: Remove (Merged-in into ../configure.ac) * Makefile.am, include/Makefile.am, src/Makefile.am, src/rpc/Makefile.am, src/xdr/Makefile.am: Reflect having merged configure.ac into ../configure.ac.
* 2003-07-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-07-082-1/+5
| | | | * console/console.c: Correct typo.
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-082-1/+5
| | | | * cpu/Makefile.am: Add DIST_SUBDIRS = $(RTEMS_CPU).
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-083-5/+12
| | | | | | * configure.ac: Merge-in librpc/configure.ac. * Makefile.am: Add librpc to SUBDIRS. Remove @subdirs@.
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-086-60/+21
* 2003-07-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-07-084-2/+12
| | | | | PR 418/ada * rtems.adb: Add missing all keyword to derefence pointer.
* 2003-07-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-07-082-1/+11
| | | | | | | | | PR 416/bsps * ppc403/ictrl/ictrl.c (ictrl_isr): We acknolwegde the interrupt in interrupt controller (clr_exisr(mask)) before calling the interrupt handler that will acnowledge the interrupt source. This results in the interrupt beeing seen a second time by the interrupt controller. Reported and fixed by El Kolli Yacine <yacine.elkolli@crf.canon.fr>.
* 2003-07-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-07-082-0/+6
| | | | | PR 419/rtems * src/termios.c: Removed warning.
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-083-3/+64
| | | | | * configure.ac: Merge-in libcsupport/configure.ac. * Makefile.am: Add libcsupport to SUBDIRS.
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-084-94/+18
| | | | | | | * configure.ac: Remove (Merged-in into ../configure.ac) * Makefile.am: DOC_FILES = src/TODO src/CASES, Reflect having merged configure.ac into ../configure.ac. * src/config.h: New.
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-083-38/+42
| | | | | | | * configure.ac: Merge-in posix/configure.ac. Merge-in itron/configure.ac. Misc. cosmetical changes. * Makefile.am: Add posix, itron to SUBDIRS.
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-088-122/+48
| | | | | | | * configure.ac: Remove (Merged-in into ../configure.ac) * Makefile.am: Reflect having merged configure.ac into ../configure.ac. * src/config.h: New.
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-082-1/+6
| | | | | * support/version.c: Reflect having remove "rtems-" from RTEMS_VERSION.
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-083-2/+16
| | | | | | | * configure.ac: Merge-in libnetworking/configure.ac. Remove "rtems-" from RTEMS_VERSION. Add AC_CHECK_FUNCS([strsep strcasecmp snprintf]). * Makefile.am: Add libmisc to SUBDIRS.
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-087-56/+34
| | | | | | | * configure.ac: Remove (Merged into ../configure.ac). * Makefile.am, libc/Makefile.am, lib/Makefile.am, wrapup/Makefile.am: Reflect having merged configure.ac into ../configure.ac. * kern/kern_mib.c: Use RTEMS_VERSION to setup osrelease.
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-083-2/+56
| | | | | * configure.ac: Merge-in libmisc/configure.ac. * Makefile.am: Add libmisc to SUBDIRS.
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-0828-121/+170
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * configure.ac: Remove (Merged into ../configure.ac). * Makefile.am: Reflect having merged configure.ac into ../configure.ac. * capture/config.h: New. * capture/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * cpuuse/config.h: New. * cpuuse/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * devnull/config.h: New. * devnull/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * dummy/config.h: New. * dummy/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * dumpbuf/config.h: New. * dumpbuf/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * monitor/config.h: New. * monitor/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * mw-fb/config.h: New. * mw-fb/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * rtmonuse/config.h: New. * rtmonuse/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * serdbg/config.h: New. * serdbg/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * shell/config.h: New. * shell/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * stackchk/config.h: New. * stackchk/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * untar/config.h: New. * untar/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * wrapup/Makefile.am: Reflect having merged configure.ac into ../configure.ac.
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-083-2/+13
| | | | | * configure.ac: Merge-in libfs/configure.ac. * Makefile.am: Add libfs to SUBDIRS.
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-088-58/+43
| | | | | | | | | | | | * configure.ac: Remove (Merged-in into ../configure.ac) * Makefile.am, src/Makefile.am, src/dosfs/Makefile.am, src/imfs/Makefile.am: Reflect having merged configure.ac into ../configure.ac. * src/dosfs/config.h: New. * src/dosfs/Makefile.am: Add config.h. * src/imfsfs/config.h: New. * src/imfs/Makefile.am: Add config.h. Remove COMMON_C_FILES, DOC_FILES (Unused).
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-085-0/+23
| | | | | | | * src/dosfs/fat.c: include config-header "config.h". * src/dosfs/fat_fat_operations.c: Ditto. * src/dosfs/fat_file.c: Ditto. * src/dosfs/msdos_conv.c: Ditto.
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-0831-0/+175
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * capture/capture-cli.c: Add config-header support. * capture/capture.c: Add config-header support. * cpuuse/cpuuse.c: Add config-header support. * devnull/devnull.c: Add config-header support. * dummy/dummy.c: Add config-header support. * dumpbuf/dumpbuf.c: Add config-header support. * monitor/mon-command.c: Add config-header support. * monitor/mon-config.c: Add config-header support. * monitor/mon-dname.c: Add config-header support. * monitor/mon-driver.c: Add config-header support. * monitor/mon-extension.c: Add config-header support. * monitor/mon-itask.c: Add config-header support. * monitor/mon-manager.c: Add config-header support. * monitor/mon-monitor.c: Add config-header support. * monitor/mon-mpci.c: Add config-header support. * monitor/mon-object.c: Add config-header support. * monitor/mon-prmisc.c: Add config-header support. * monitor/mon-queue.c: Add config-header support. * monitor/mon-server.c: Add config-header support. * monitor/mon-symbols.c: Add config-header support. * monitor/mon-task.c: Add config-header support. * mw-fb/mw_fb.c: Add config-header support. * mw-fb/mw_uid.c: Add config-header support. * rtmonuse/rtmonuse.c: Add config-header support. * serdbg/serdbg.c: Add config-header support. * serdbg/serdbgio.c: Add config-header support. * serdbg/termios_printk.c: Add config-header support. * shell/cmds.c: Add config-header support. * stackchk/check.c: Add config-header support. * untar/untar.c: Add config-header support.
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-083-31/+10
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-083-3/+8
| | | | | * configure.ac: Merge-in libblock/configure.ac. * Makefile.am: Add libblock to SUBDIRS.
