* configure.ac: Add RTEMS_PROG_CCAS
* aclocal/prog-ccas.m4: New.
* aclocal/canonicalize-tools.m4: Remove AS, OBJCOPY, NM, SIZE, STRIP.
RTEMS_GCC_PRINT
* aclocal/check-multiprocessing.m4: Fix typo.
* automake/compile.am: Remove CXX support.
Replace AS by CCAS. Remove LINK_LIBS, LINK_OBJS, LINK_FILES.
RTEMS_GCC_PRINT
* configure.ac: Use AC_CONFIG_AUX_DIR(../..).
Add AC_PROG_RANLIB.
* configure.ac: Use AC_CONFIG_AUX_DIR(..).
* configure.ac: Use AC_CONFIG_AUX_DIR(../../../..).
Add AC_PROG_RANLIB.
* autotools/automake-rtems.spec.in: Update to automake-1.6.2.
* wrapup/Makefile.am: Build libnetapps.a.
Don't preinstall libnetapps.a
* Makefile.am: Pickup libnetapps.a from build directory.
* wrapup/Makefile.am: Don't preinstall libmisc.a.
* Makefile.am: Pickup libmisc.a from build directory.
Remove libxdr.a.
* ChangeLog: Fix bogus changelog entries.
* wrapup/Makefile.am: Don't preinstall libnetworking.a.
* wrapup/Makefile.am: Don't preinstall libfs.a.
* src/Makefile.am: Don't preinstall libblock.a.
* configure.ac: Remove references to RTEMS_BSP.
* src/Makefile.am: Add libposix.a.
* src/Makefile.am: Add libitron.a.
* aclocal/check-multiprocessing.m4: Remove references to RTEMS_BSP.
Allow building w/ --enable-multiprocessing --enable-multilib.
* aclocal/enable-multiprocessing.m4:
Eliminate RTEMS_HAS_MULTIPROCESSING.
* wrapup/Makefile.am: Remove libxdr.a.
Remove RTEMS_CANONICAL_HOST.
Use RTEMS_ENV_RTEMSCPU.
Add AC_PROG_RANLIB.
* include/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* include/rpcsvc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
ACLOCAL_AMFLAGS = -I ../aclocal.
* src/rpc/PSD.doc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/xdr/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* wrapup/Makefile.am: Fix stupid typo in previous patch.
* configure.ac: Add librpc. AC_PROG_RANLIB.
* wrapup/Makefile.am: Add librpc.
Use relative path to lib*.a for
POSIX_OBJS, ITRON_OBJS, NETWORKING_OBJS.
* configure.ac: Remove librpc.
* Per PR233, moved librpc to exec. Ralf will patch after move.
The patches associated with this PR are out of date.
* configure.ac, wrapup/Makefile.am: Modified.
* librpc, librpc/ChangeLog: Removed.
./include/rpc/.cvsignore, ./include/rpc/Makefile.am,
./include/rpc/auth.h, ./include/rpc/auth_des.h,
./include/rpc/auth_unix.h, ./include/rpc/clnt.h,
./include/rpc/des.h, ./include/rpc/des_crypt.h,
./include/rpc/pmap_clnt.h, ./include/rpc/pmap_prot.h,
./include/rpc/pmap_rmt.h, ./include/rpc/rpc.h,
./include/rpc/rpc_com.h, ./include/rpc/rpc_msg.h,
./include/rpc/svc.h, ./include/rpc/svc_auth.h,
./include/rpc/types.h, ./include/rpc/xdr.h,
./include/.cvsignore, ./include/Makefile.am,
./include/rpcsvc/.cvsignore, ./include/rpcsvc/Makefile.am,
./include/rpcsvc/bootparam_prot.x, ./include/rpcsvc/crypt.x,
./include/rpcsvc/key_prot.x, ./include/rpcsvc/klm_prot.x,
./include/rpcsvc/mount.x, ./include/rpcsvc/nfs_prot.x,
./include/rpcsvc/nis.x, ./include/rpcsvc/nis_cache.x,
./include/rpcsvc/nis_callback.x, ./include/rpcsvc/nis_db.h,
./include/rpcsvc/nis_object.x, ./include/rpcsvc/nis_tags.h,
./include/rpcsvc/nislib.h, ./include/rpcsvc/nlm_prot.x,
./include/rpcsvc/pmap_prot.x, ./include/rpcsvc/rex.x,
./include/rpcsvc/rnusers.x, ./include/rpcsvc/rquota.x,
./include/rpcsvc/rstat.x, ./include/rpcsvc/rwall.x,
./include/rpcsvc/sm_inter.x, ./include/rpcsvc/spray.x,
./include/rpcsvc/yp.x, ./include/rpcsvc/yp_prot.h,
./include/rpcsvc/ypclnt.h, ./include/rpcsvc/yppasswd.x,
./include/rpcsvc/ypupdate_prot.x, ./include/rpcsvc/ypxfrd.x,
./.cvsignore, ./Makefile.am, ./README_RTEMS,
./configure.ac, ./src/rpc/PSD.doc/.cvsignore,
./src/rpc/PSD.doc/Makefile.am, ./src/rpc/PSD.doc/nfs.rfc.ms,
./src/rpc/PSD.doc/rpc.prog.ms, ./src/rpc/PSD.doc/rpc.rfc.ms,
./src/rpc/PSD.doc/rpcgen.ms, ./src/rpc/PSD.doc/xdr.nts.ms,
./src/rpc/PSD.doc/xdr.rfc.ms, ./src/rpc/.cvsignore,
./src/rpc/DISCLAIMER, ./src/rpc/Makefile.am,
./src/rpc/README, ./src/rpc/auth_des.c,
./src/rpc/auth_none.c, ./src/rpc/auth_time.c,
./src/rpc/auth_unix.c, ./src/rpc/authdes_prot.c,
./src/rpc/authunix_prot.c, ./src/rpc/bindresvport.3,
./src/rpc/bindresvport.c, ./src/rpc/clnt_generic.c,
./src/rpc/clnt_perror.c, ./src/rpc/clnt_raw.c,
./src/rpc/clnt_simple.c, ./src/rpc/clnt_tcp.c,
./src/rpc/clnt_udp.c, ./src/rpc/clnt_unix.c,
./src/rpc/crypt_client.c, ./src/rpc/des_crypt.3,
./src/rpc/des_crypt.c, ./src/rpc/des_soft.c,
./src/rpc/get_myaddress.c, ./src/rpc/getpublickey.c,
./src/rpc/getrpcent.3, ./src/rpc/getrpcent.c,
./src/rpc/getrpcport.3, ./src/rpc/getrpcport.c,
./src/rpc/key_call.c, ./src/rpc/key_prot_xdr.c,
./src/rpc/netname.c, ./src/rpc/netnamer.c,
./src/rpc/pmap_clnt.c, ./src/rpc/pmap_getmaps.c,
./src/rpc/pmap_getport.c, ./src/rpc/pmap_prot.c,
./src/rpc/pmap_prot2.c, ./src/rpc/pmap_rmt.c,
./src/rpc/publickey.3, ./src/rpc/publickey.5,
./src/rpc/rpc.3, ./src/rpc/rpc.5, ./src/rpc/rpc_callmsg.c,
./src/rpc/rpc_commondata.c, ./src/rpc/rpc_dtablesize.c,
./src/rpc/rpc_prot.c, ./src/rpc/rpc_secure.3,
./src/rpc/rpcdname.c, ./src/rpc/rstat.1,
./src/rpc/rstat_svc.8, ./src/rpc/rtems_portmapper.c,
./src/rpc/rtems_rpc.c, ./src/rpc/rtime.3, ./src/rpc/rtime.c,
./src/rpc/svc.c, ./src/rpc/svc_auth.c,
./src/rpc/svc_auth_des.c, ./src/rpc/svc_auth_unix.c,
./src/rpc/svc_raw.c, ./src/rpc/svc_run.c,
./src/rpc/svc_simple.c, ./src/rpc/svc_tcp.c,
./src/rpc/svc_udp.c, ./src/rpc/svc_unix.c,
./src/xdr/.cvsignore, ./src/xdr/Makefile.am, ./src/xdr/xdr.3,
./src/xdr/xdr.c, ./src/xdr/xdr_array.c,
./src/xdr/xdr_float.c, ./src/xdr/xdr_mem.c,
./src/xdr/xdr_rec.c, ./src/xdr/xdr_reference.c,
./src/xdr/xdr_sizeof.c, ./src/xdr/xdr_stdio.c,
./src/.cvsignore, ./src/Makefile.am: Moved to exec.
* aclocal/subdirs.m4: Remove.
* Makefile.am: Remove commented out net-apps.
* wrapup/Makefile.am: Use relative path to lib*.a for
LIBCSUPPORT_OBJS, LIBBLOCK_OBJS, LIBDOSFS_OBJS, LIBIMFS_OBJS.
* Makefile.am: Merge src/Makefile.am.
* src/Makefile.am: Remove.
* aclocal/env-rtemscpu.m4: Remove.
* aclocal/multi.m4: Remove.
* aclocal/multilib.m4: Remove RTEMS_ENABLE_MULTILIB_MASTER.
* Makefile.am: Include $(top_srcdir)/automake/*.am.
Use aclocal.
* sapi/include/Makefile.am: Include $(top_srcdir)/automake/*.am.
* sapi/Makefile.am: Include $(top_srcdir)/automake/*.am.
* sapi/inline/Makefile.am: Include $(top_srcdir)/automake/*.am.
* sapi/macros/Makefile.am: Include $(top_srcdir)/automake/*.am.
* sapi/src/Makefile.am: Include $(top_srcdir)/automake/*.am.
* score/include/Makefile.am: Include $(top_srcdir)/automake/*.am.
* score/Makefile.am: Include $(top_srcdir)/automake/*.am.
* score/cpu/Makefile.am: Include $(top_srcdir)/automake/*.am.
* score/inline/Makefile.am: Include $(top_srcdir)/automake/*.am.
* score/macros/Makefile.am: Include $(top_srcdir)/automake/*.am.
* score/src/Makefile.am: Include $(top_srcdir)/automake/*.am.
* wrapup/Makefile.am: Include $(top_srcdir)/automake/*.am.
* include/Makefile.am: Include $(top_srcdir)/automake/*.am.
* rtems/include/Makefile.am: Include $(top_srcdir)/automake/*.am.
* rtems/Makefile.am: Include $(top_srcdir)/automake/*.am.
* rtems/inline/Makefile.am: Include $(top_srcdir)/automake/*.am.
* rtems/macros/Makefile.am: Include $(top_srcdir)/automake/*.am.
* rtems/src/Makefile.am: Include $(top_srcdir)/automake/*.am.
* Include $(top_srcdir)/automake/*.am. Use aclocal/.
* Makefile.am: Include $(top_srcdir)/../../../automake/*.am.
Use ../../../aclocal.
Use ../aclocal.
* arpa/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* kern/Makefile.am: Include $(top_srcdir)/../automake/*.am.
Use ../aclocal.
* lib/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* libc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* machine/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* net/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* netinet/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* nfs/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* rtems/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* sys/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* vm/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* wrapup/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/dosfs/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/imfs/Makefile.am: Include $(top_srcdir)/../automake/*.am.
Use ../aclocal.
Use ../aclocal.
Use ../aclocal.
* inline/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* macros/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* aclocal/bsp-alias.m4: Copied over from aclocal/.
* aclocal/canonical-host.m4: Ditto.
* aclocal/canonical-target-name.m4: Ditto.
* aclocal/canonicalize-tools.m4: Ditto.
* aclocal/check-bsp-cache.m4: Ditto.
* aclocal/check-bsps.m4: Ditto.
* aclocal/check-cpu.m4: Ditto.
* aclocal/check-itron.m4: Ditto.
* aclocal/check-multiprocessing.m4: Ditto.
* aclocal/check-networking.m4: Ditto.
* aclocal/check-newlib.m4: Ditto.
* aclocal/check-posix.m4: Ditto.
* aclocal/check-tool.m4: Ditto.
* aclocal/enable-bare.m4: Ditto.
* aclocal/enable-inlines.m4: Ditto.
* aclocal/enable-itron.m4: Ditto.
* aclocal/enable-multiprocessing.m4: Ditto.
* aclocal/enable-networking.m4: Ditto.
* aclocal/enable-posix.m4: Ditto.
* aclocal/enable-rtemsbsp.m4: Ditto.
* aclocal/env-rtemsbsp.m4: Ditto.
* aclocal/env-rtemscpu.m4: Ditto.
* aclocal/gcc-pipe.m4: Ditto.
* aclocal/gcc-specs.m4: Ditto.
* aclocal/multi.m4: Ditto.
* aclocal/multilib.m4: Ditto.
* aclocal/prog-cc.m4: Ditto.
* aclocal/project-root.m4: Ditto.
* aclocal/rtems-cpu-subdirs.m4: Ditto.
* aclocal/rtems-debug.m4: Ditto.
* aclocal/rtems-top.m4: Ditto.
* aclocal/subdirs.m4: Ditto.
* aclocal/sysv-ipc.m4: Ditto.
* aclocal/tool-paths.m4: Ditto.
* aclocal/version.m4: Ditto.
* copied over from aclocal/.
* Makefile.am: Remove multilib support.
* configure.ac: Ditto.
* sapi/Makefile.am: Ditto.
* rtems/Makefile.am: include multilib.am instead of RTEMS_BSP.cfg.
* automake/compile.am: Copied over from automake/.
* automake/lib.am: Copied over from automake/.
* automake/local.am: Copied over from automake/.
* automake/multilib.am: Copied over from automake/.
* automake/subdirs.am: Copied over from automake/.
* Makefile.am: Add automake/*.am.
* mkgdbspec.in, setup.def, gcc3newlib/gccnewlib.add, gdb/gdb.add:
Updated to gcc 3.1 and gdb 5.2.
* custom/jmr3904.cfg, custom/p4650.cfg, custom/p4600.cfg: Switch
to gcc 3.1 arguments.
