CHANGES:
c/Makefile.am removed
still in - remove it?)
(Cygwin support)
REMARK:
inside the build-tree.
APPLYING THE PATCH
autogen
dependencies of "Makefile".
--enable-maintainer-mode.
* I've gone a little ??) further than I had announced before.
from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
information on gdb and bdm for the MPC8xx, MC683xx, and ColdFire.
and xing@ebs330.eb.uah.edu.
init() and fini() routines.
I get the following warning when compiling the latest snapshot. I had
a quick look at the source -- it certainly looks to me like this is a
real bug.
../../../../src/rtems-19990709/c/src/lib/libc/mount.c:97: warning:
`options' might be used uninitialized in this function
Also, I changed the TFTP test program and TFTP driver to reflect the
changes in the way paths are passed to the TFTP driver. The TFTP driver
now needs a proper `dotted-decimal' hostname as the second component of
the path name.
- The same bug fix that was done on pc386 to prevent interrupt
from occuring (never experienced it but who knows as I have 8259
emulation :()
- Removed every compiler warning (except wrong ones and ones I can't do
anything).
- Removed any libc available code in code linked with mcp750 rtems
executbale. Unfortunately using newlib functions for linking the
bootloader does not work as the compilation options in bootloader
(-mrelocatable -fixed-r13) are not compatible with newlib options.
=> I have put any libc external reference in one single new file (lib.c)
that is linked only with the boot loader. Removing the file from
${OBJ} and using -lc crash the bootloader. Added big warning...
+ interrupt masking correction
+ FPU rev.B workaround
+ minor erc32 related fixes
on a single page.
getsockopt: SO_SNDWAKEUP and SO_RCVWAKEUP" from Ian Lance Taylor
<ian@airs.com>.
ncurses, and zlib for RTEMS.
previous submission.
