* | Modified scan file to match. | Jennifer Averett | 1999-11-16 | 2 | -4/+4 |
* | New file. | Joel Sherrill | 1999-11-16 | 3 | -0/+339 |
* | Added. | Joel Sherrill | 1999-11-16 | 16 | -3/+619 |
* | Source and destination arguments to strncpy were swapped. This mistake | Joel Sherrill | 1999-11-16 | 3 | -3/+3 |
| | | | | was made in the conversion of bcopy() to strncpy(). | ||||
* | Added itron tests. | Joel Sherrill | 1999-11-16 | 2 | -2/+2 |
* | Changed to call tmmacros instead of assert. | Jennifer Averett | 1999-11-16 | 2 | -282/+306 |
* | Patch rtems-rc-19991105-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1999-11-16 | 1 | -1/+6 |
| | | | | | | | This is the gdb.spec.in fix patch: * install infos gzip-ed * add gdb to group rtems | ||||
* | Moved start code from lib/start to libbsp. | Joel Sherrill | 1999-11-16 | 14 | -7/+462 |
* | Moved start code from lib/start to libbsp. | Joel Sherrill | 1999-11-16 | 5 | -274/+0 |
* | Moved start code from lib/start to libbsp. | Joel Sherrill | 1999-11-16 | 14 | -829/+22 |
* | Committed modifications from ITRON Task and Task Dependendent Synchronization | Joel Sherrill | 1999-11-16 | 7 | -1953/+0 |
| | | | | Working Group. Included are tests. | ||||
* | Minor changes since new Makefile. | Joel Sherrill | 1999-11-16 | 1 | -4/+5 |
* | Added start subdirectory. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Committed modifications from ITRON Task and Task Dependendent Synchronization | Joel Sherrill | 1999-11-16 | 18 | -2098/+0 |
* | Removed nanosleep() since it is now in its own file. | Joel Sherrill | 1999-11-15 | 2 | -42/+0 |
* | Returned third parameter for a NULL name to the objects open call. | Jennifer Averett | 1999-11-15 | 2 | -2/+2 |
* | + Fixed files to consistantly use a case of the location after calls | Jennifer Averett | 1999-11-15 | 22 | -162/+194 |
| | | | | | | to ITRON_Task_Get. + Modified to consistantly call _ITRON_return_errorno with E_OK. + Optimized the code to not disable dispatch prior to checking input values. | ||||
* | + Modified to use new Thread_Reset routine instead of the restart method. | Jennifer Averett | 1999-11-15 | 2 | -2/+2 |
* | Fixed verificaiton checks to call correct macro if dispatch is disabled. | Jennifer Averett | 1999-11-15 | 2 | -14/+24 |
* | + Added check that a task could be sent to a dormant state | Jennifer Averett | 1999-11-15 | 8 | -24/+188 |
| | | | | | | | | then sta_tsk used to restart the task to its initial state. + Added calls to ref_tsk to yellow paths for suspended and ready but not running tasks. + Fixed output file to correctly state test name + Added priority of preempt to the header file. Allows ref_tsk verification. | ||||
* | + Changed preempt routine into two dummy tasks one that is in dormant | Jennifer Averett | 1999-11-15 | 7 | -34/+164 |
| | | | | | | | | state and one that is in non-dormant state. + Increased the priority of the Init task to force the dummy tasks to run first. + Added calls to ref_tsk to verify the state of the dummy tasks and test ref_tsk. | ||||
* | Added paragraph describing SUSP. | Joel Sherrill | 1999-11-15 | 1 | -0/+9 |
* | Split ITRON Message Buffer Manager into multiple files. | Joel Sherrill | 1999-11-15 | 23 | -709/+1045 |
* | Split ITRON semaphore manager into multiple files. | Joel Sherrill | 1999-11-15 | 17 | -569/+754 |
* | + Modified calls to use TSK_SLF for calls to self. | Joel Sherrill | 1999-11-12 | 2 | -50/+48 |
| | | | | + Modified calls to use the task id macro for calls to the PREEMPT task. | ||||
* | + Added comments on paths tested. | Joel Sherrill | 1999-11-12 | 4 | -2/+28 |
* | + Added check for priority over 256. | Joel Sherrill | 1999-11-12 | 2 | -2/+8 |
| | | | | + Modified output to correctly state the error. | ||||
* | Added comments for path's tested. | Joel Sherrill | 1999-11-12 | 2 | -0/+6 |
* | + Changed validation of the_thread to validation of location. | Joel Sherrill | 1999-11-12 | 8 | -74/+54 |
| | | | | | + Modified correct return path to call _ITRON_return_errorno( E_OK ) instead of enabling dispatching and returning E_OK. | ||||
* | + Changed validation of the_thread to validation of location. | Joel Sherrill | 1999-11-12 | 2 | -22/+22 |
| | | | | + Removed error path that should never happen. | ||||
* | + Changed validation of the_thread to validation of location. | Joel Sherrill | 1999-11-12 | 4 | -34/+16 |
* | + Moved error checks to before the disable dispatch where possible. | Joel Sherrill | 1999-11-12 | 2 | -10/+10 |
* | Added comment about the E_CTX error condition (Implementation dependent). | Joel Sherrill | 1999-11-12 | 2 | -0/+14 |
* | + Moved error checks to before the dispatch disable where possible. | Joel Sherrill | 1999-11-12 | 2 | -26/+24 |
* | + Modified correct return path to call _ITRON_return_errorno( E_OK ) instead | Joel Sherrill | 1999-11-12 | 2 | -30/+20 |
| | | | | | | | of enabling dispatching and returning E_OK. + Changed validation of the_thread to validation of location. + Set correct error code when dormant state. + Fixed comment. | ||||
* | + Modified correct return path to call _ITRON_return_errorno( E_OK ) instead | Joel Sherrill | 1999-11-12 | 2 | -10/+4 |
| | | | | | of enabling dispatching and returning E_OK. + Changed validation of the_thread to validation of location. | ||||
* | Corrected so now actually indexes into the allocation block. | Joel Sherrill | 1999-11-12 | 2 | -20/+12 |
* | Corrected remaining references to struct rtems_task_variable_t since | Joel Sherrill | 1999-11-12 | 4 | -14/+22 |
| | | | | it is now typedef'ed. | ||||
* | Removed unnecessary 3rd parameter. | Joel Sherrill | 1999-11-12 | 2 | -2/+2 |
* | New file. | Joel Sherrill | 1999-11-12 | 2 | -0/+26 |
* | Used typedef so all "struct rtems_task_variable_t" uses are now | Joel Sherrill | 1999-11-12 | 8 | -38/+38 |
| | | | | just "rtems_task_variable_t". | ||||
* | Added per-task variable data stucture (rtems_task_variable_t), | Joel Sherrill | 1999-11-12 | 2 | -8/+72 |
| | | | | | task_variables field to API extension, and two directives (rtems_task_variable_add and rtems_task_variable_delete). | ||||
* | Test name changed to reflect placement after merger. | Joel Sherrill | 1999-11-12 | 12 | -16/+18 |
* | Test name changed to reflect placement after merger. | Joel Sherrill | 1999-11-12 | 4 | -12/+22 |
| | | | | Changed output to reflect what was actually being tested. | ||||
* | Test name changed to reflect placement after merger. | Joel Sherrill | 1999-11-12 | 8 | -10/+18 |
| | | | | Increased stack space. | ||||
* | Added per task variables based on patch from Eric Norum <eric@cls.usask.ca>. | Joel Sherrill | 1999-11-12 | 7 | -7/+446 |
| | | | | | After being submitted, this support was rewritten to be inside the executive rather than layered on top of it using an extension. | ||||
* | Cleaned up style. | Joel Sherrill | 1999-11-12 | 2 | -486/+478 |
* | Removed redundant line. | Joel Sherrill | 1999-11-12 | 2 | -2/+0 |
* | Merged message buffer code from CS595 projects. | Joel Sherrill | 1999-11-12 | 0 | -0/+0 |
* | Enabled after merging message buffer code. | Joel Sherrill | 1999-11-12 | 2 | -12/+4 |
