PR 1839/filesystem
* libcsupport/include/rtems/libio_.h, libcsupport/src/fchdir.c,
libcsupport/src/fdatasync.c, libcsupport/src/fpathconf.c,
libcsupport/src/fsync.c, libcsupport/src/read.c,
libcsupport/src/readv.c, libcsupport/src/write.c,
libcsupport/src/writev.c: Some calls did not return proper status for
permission errors or incorrectly permissions at all.
* Makefile.am, preinstall.am: Include stubs so all tests compile.
* include/tm27.h: New file.
* clock/ckinit.c: Correct back port.
PR 1845/bsps
* custom/rtl22xx_t.cfg: Remove unused line with what is now invalid
syntax.
PR 1778/bsps
* vme/VMEConfig.h: Used the VME shared IRQ handlers.
* include/bsp.h: Removed BSP_PIC_DO_EOI.
* network/if_100MHz/GT64260eth.c:
Recycle the Rx mbuf if there is any Rx error.
PR 1766/bsps
* clock/ckinit.c: Add missing read of Timer_Counter_1.
PR 1837/bsps
* shared/motorola/motorola.c, shared/motorola/motorola.h: Add MVME2400
board with 750 CPU to list of supported Motorola boards.
PR 1838/filesystem
* libcsupport/src/fchmod.c: fchmod() does not need a writeable file
descriptor.
PR 1381/networking
* netinet/ip_output.c: If a null or unreachable gateway is
specified either statically in networkconfig.h or from dhcp/bootp,
sendto() fails on multicast send with errno "118 Host is unreachable".
The failure occurs in networking file ip_output.c since it currently
requires all multicasts to have a valid route to the outside world.
PR 1381/networking
* libnetworking/netinet/ip_output.c: If a null or unreachable gateway
is specified either statically in networkconfig.h or from dhcp/bootp,
sendto() fails on multicast send with errno 118 Host
PR 1833/bsps
* ne2000/ne2000.c: Addition of multicast support disabled broadcast
reception. Patch also includes support to work on big endian CPUs.
PR 1812/filesystem
* libfs/src/imfs/imfs_stat.c: stat() implementation for IMFS did not
set st_blksize field. Set it based upon user configuration.
PR 1783/bsps
* include/bsp.h: Remove dead prototypes of Clock_delay() and delay().
Neither had bodies.
* ne2000/ne2000.c: Add multicast support. Patch submitted to mailing
list 2005-12-21.
PR 1722/networking
* ftpd/ftpd.c: FTPD fails to parse correctly FTP commands relating to
filenames with spaces in them.
PR 1768/bsps
* shared/irq/irq_asm.S: The nbench benchmark highlighted the fact that
we do not perform a cld before calling C code in the ISR. This was
historically not a problem but gcc 4.3 changed the behavior. From
http://gcc.gnu.org/gcc-4.3/changes.html
PR 1772/bsps
* console/sci.c: Use same default baud rate as monitor.
PR 1760/misc
* compilers/gcc-target-default.cfg: Fix typo in CPP definition.
PR 1759/cpukit
* posix/src/cancel.c, posix/src/pthreaddetach.c,
posix/src/pthreadequal.c, posix/src/pthreadgetschedparam.c,
posix/src/pthreadjoin.c, posix/src/pthreadkill.c: Some POSIX pthread
services did not support using Classic API Task Ids.
PR 1756/bsps
* timer/timer.c: Retry on timer calibration loop failure.
PR 1751/bsps
* start/start.S: Fix typo which was not caught by binutils prior to a
recent bug fix.
PR 1748/bsps
* clock/ckinit.c, include/leon.h: When the clock tick generates an
interrupt WHILE we have interrupts disabled doing a get TOD or
uptime, the get nanoseconds handler was returning a bogusly large
number.
PR 1748/bsps
* clock/ckinit.c: When the clock tick generates an interrupt WHILE we
have interrupts disabled doing a get TOD or uptime, the get
nanoseconds handler was returning a bogusly large number.
PR 1749/filesystem
* libcsupport/src/mknod.c: Fix the incorrect handling of the file type
in the mode value o reject invalid types as per the standard.
* setup.def, common/cpright.texi: Update dates.
* libmisc/capture/capture.c: Avoid using TCB of task just deleted.
* Makefile.am, configure.ac, common/cpright.texi, common/rtems.texi.in,
cpu_supplement/.cvsignore, started/Makefile.am, started/binaries.t,
started/buildc.t, started/buildrt.t, started/intro.t,
started/nextstep.t, started/nt.t, started/require.t,
started/sample.t, started/started.texi: Major update which includes
removal of references to specific tool versions and patches.
* started/tversions.texi.in: Removed.
* Makefile.am, configure.ac, develenv/direct.t: Remove Getting Started
with GNAT/RTEMS.
* started_ada/.cvsignore, started_ada/Makefile.am,
started_ada/buildada.t, started_ada/gdb.t, started_ada/intro.t,
started_ada/require.t, started_ada/sample.t,
started_ada/started_ada.texi, started_ada/tversions.texi: Removed.
* SUPPORT: Update address.
* Makefile.am, preinstall.am: Add <bsp/tty_drv.h> to the set of
installed .h files.
PR 1718/cpukit
* sapi/include/confdefs.h: POSIX threads are allocated twice the
minimum stack space by default. confdefs.h only accounts for one
minimum -- not the 2x factor.
PR 1717/cpukit
* libcsupport/src/gxx_wrappers.c: Free memory on error.
PR 1716/doc
* user/concepts.t: print_name example used a variable which did not
match the name of the passed in parameter.
PR 1714/doc
* user/datatypes.t: Add missing description of rtems_status_codes.
PR 1708/build:
* aclocal/check-cpuopts.m4: Fix m4-quoting.
* aclocal/check-cpuopts.m4: Add AC_LANG_SOURCE.
PR 1693/filesystem
* libfs/src/imfs/memfile.c: IMFS_memfile_get_block_pointer() was
checking incorrect pointer and thus had dead code.
PR 1692/filesystem
* libcsupport/include/rtems/libio.h, libfs/src/imfs/imfs_eval.c: Fix
implementation and use of rtems_libio_is_valid_perms().
PR 1689/bsps
* shared/flash/intelFlash.c: Scale erase timeout by actual
system clock rate rather than assuming a fixed value.
PR 1570/cpukit
* posix/src/semtimedwait.c: This routine is supposed to return -1/errno
NOT the status directly.
PR 1554/cpukit
Coverity Id 17
* libi2c/libi2c.c: Fix memory leak on error.
PR 1568/doc
* user/intr.t: Fix list of services callable from ISR.
PR 1520/doc
* user/part.t: Partition create discussion said it returned the number
of buffers created but it does not.
