* network/Makefile.am: Eliminate C_O_FILES.
* rtc/Makefile.am: Ditto.
* serial/Makefile.am: Ditto,
* configure.ac: Require autoconf-2.57 + automake-1.7.2.
* Makefile.am: Eliminate C_O_FILES, S_O_FILES, libscorecpu_a_OBJECTS.
* kern/Makefile.am: Remove C_O_FILES;
Don't let all-local depend on $OBJS)
* lib/Makefile.am: Ditto.
* libc/Makefile.am: Ditto.
* net/Makefile.am: Ditto.
* netinet/Makefile.am: Ditto.
* nfs/Makefile.am: Ditto.
* rtems/Makefile.am: Ditto.
* Makefile.am: Use .$(OBJEXT) instead of .o.
* aclocal/prog-cxx.m4: Swap RTEMS_CHECK_TOOL/AC_PROG_CXX.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP.
* capture/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* cpuuse/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* devnull/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* dummy/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* dumpbuf/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* monitor/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mw-fb/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* rtmonuse/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* serdbg/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shell/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* stackchk/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* untar/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* serial/Makefile.am: Don't include @RTEMS_BSP@.cfg.
Don't use LIBC_DEFINES.
* rtc/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* src/Makefile.am: Remove.
* Makefile.am: Merge-in src/Makefile.am, include/Makefile.am.
Unconditionally check for CXX.
* Makefile.am: Introduce sapi_C_FILES, rtems_C_FILES.
Makefile.am: Fix macro-file installation.
* configure.ac: Remove RTEMS_ENV_RTEMS_BSP, add
AC_ARG_VAR(RTEMS_BSP)-hack instead.
Makefile.am: Move include/rtems/score/cpuopts.h to STD_H_FILES.
* aclocal/env-rtemsbsp.m4: Remove RTEMS_CHECK_CUSTOM_BSP.
* aclocal/env-rtemscpu.m4: Remove RTEMS_CHECK_CUSTOM_BSP.
* aclocal/check-bsps.m4: Remove.
* bootstrap: Require autoconf 2.54 or 2.57.
Require automake-1.7.2.
* wrapup/Makefile.am: Remove *_OBJS, use LIBS+= instead.
* configure.ac: Require autoconf >= 2.54, automake-1.7.2.
* wrapup/Makefile.am: Reflect changes to score/.
* configure.ac: Reflect changes to score/.
* inline/Makefile.am: Remove.
* macros/Makefile.am: Remove.
* Makefile.am: Merge-in removed Makefile.ams.
* wrapup/Makefile.am: Reflect changes to sapi/.
* configure.ac: Reflect changes to sapi/.
* configure.ac: Add AC_SUBST(INLINEdir).
* wrapup/Makefile.am: Reflect changes to rtems/.
* configure.ac: Reflect changes to rtems/.
* wrapup/Makefile.am: Reflect changes to posix/.
Reflect changes to itron/.
* supplement.am: Append -I $(topsrc_dir) to AM_MAKEINFOFLAGS.
* Makefile.am: Merge-in images/Makefile.am, common/Makefile.am.
* images/Makefile.am: Remove.
* common/Makefile.am: Remove.
* main.am: Append -I $(topsrc_dir) to AM_MAKEINFOFLAGS.
* configure.ac: Append RTEMS_CPU_MODEL to ac_configure_args.
Resort cache-checking.
* aclocal/bsp-configure.m4: Remove RTEMS_CHECK_BSP_CACHE.
* aclocal/env-rtemsbsp.m4: Add comments to AC_ARG_VARs.
Add AC_ARG_VAR(RTEMS_CPU_MODEL).
* autotools/automake-rtems.spec.in: Update to automake-1.7.2.
* autotools/autoconf-rtems.spec.in: Update to autoconf-2.57.
* Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ChangeLog: Removed duplicate entry.
* setup.def: Updated patch to fix m68k cut and paste bug which turned
a tab into spaces in a Makefile fragment.
* gcc3newlib/gccnewlib.add: If building gnat for the mips, the library
must be built with a -G0 option.
* src/malloc.c: Fixed code that incorrected did a disable dispatch
instead of locking and unlocking the allocator mutex.
* inline/rtems/posix/cond.inl, macros/rtems/posix/cond.inl:
Implemented PTHREAD_COND_INITIALIZER support. Vladimir implemented
the inline version and Joel adapted it to the macro version.
* automake/compile.am: Rework *FLAGS, AM_*FLAGS handling.
* configure.ac: Expand RTEMS_CHECK_BSP_CACHE.
* automake/compile.am: Remove hard-coded *_PROFILE_V.
Add autoconf-supplied CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V,
CFLAGS_PROFILE_V.
Remove CPPFLAGS_GCC.
* automake/multilib.am: Don't include @RTEMS_BSP@.cfg.
* automake/compile.am: Remove hard-coded CFLAGS_PROFILE_V.
CFLAGS_PROFILE_V.
Hard-code RTEMS_CFLAGS_PROFILE = -pg
* aclocal/prog-cc.m4: Sync with toplevel/aclocal/prog-cc.m4.
Remove GCCSED.
* aclocal/env-rtemsbsp.m4: Add AC_ARG_VAR for CPU_CFLAGS,
CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V, CFLAGS_PROFILE_V.
* custom/posix.cfg: Remove comment referring to host.cfg.
CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V, CFLAGS_PROFILE_V, RTEMS_BSP_FAMILY.
* aclocal/prog-cc.m4: Reworked CFLAGS handling.
* aclocal/prog-cxx.m4: Reworked CXXFLAGS handling.
