* | Upgrade to 4.8.24.8.2 | Joel Sherrill | 2010-03-18 | 5 | -5/+5 |
* | 2010-03-18 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-03-18 | 2 | -2/+8 |
| | | | | | | PR 1497/bsps * startup/bspclean.c: Do not enable interrupts while waiting for board to reset. | ||||
* | Remove. | Ralf Corsepius | 2010-03-11 | 17 | -654/+0 |
* | Sync with CVS-HEAD. | Ralf Corsepius | 2010-01-11 | 1 | -7/+3 |
* | Bump version. | Ralf Corsepius | 2010-01-11 | 1 | -1/+1 |
* | Fix oversight. | Ralf Corsepius | 2010-01-11 | 1 | -1/+0 |
* | Set default osname to centos5. | Ralf Corsepius | 2010-01-11 | 1 | -1/+1 |
* | Bump version. | Ralf Corsepius | 2010-01-11 | 1 | -9/+2 |
| | | | | Remove fedora. | ||||
* | Add rtems-4.8-release. | Ralf Corsepius | 2010-01-11 | 1 | -2/+15 |
* | Add INSTALL | Ralf Corsepius | 2010-01-11 | 1 | -0/+1 |
* | Remove (Bogusly checked in into CVS) | Ralf Corsepius | 2010-01-11 | 1 | -237/+0 |
* | 2009-12-10 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-12-10 | 2 | -1/+8 |
| | | | | | PR 1482 * posix/src/ptimer1.c: Exit dispatching critical section. | ||||
* | 2009-09-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-09-15 | 3 | -35/+10 |
| | | | | | | | | | PR 1441/cpukit * libcsupport/src/tcgetprgrp.c: Remove. * libcsupport/src/tcgetpgrp.c: New (Renamed from libcsupport/src/tcgetprgrp.c). * libcsupport/Makefile.am: Add libcsupport/src/tcgetpgrp.c. Remove libcsupport/src/tcgetprgrp.c. | ||||
* | This commit was manufactured by cvs2svn to create branch 'rtems-4-8-branch'. | cvs2git | 2009-09-15 | 1 | -0/+28 |
| | | | | Cherrypick from master 2009-09-15 05:32:49 UTC Ralf Corsepius <ralf.corsepius@rtems.org> '2009-09-15 Ralf Corsépius <ralf.corsepius@rtems.org>': cpukit/libcsupport/src/tcgetpgrp.c | ||||
* | 2009-09-09 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-09-09 | 3 | -3/+13 |
| | | | | | * sp46/init.c: Make compile on 4.8 branch. * sp46/sp46.scn: New file. | ||||
* | Sync with rtems-4.9. | Ralf Corsepius | 2009-07-26 | 6 | -24/+88 |
* | Update. | Ralf Corsepius | 2009-07-26 | 1 | -2/+2 |
* | Remove. | Ralf Corsepius | 2009-07-24 | 2 | -197/+0 |
* | New. | Ralf Corsepius | 2009-07-24 | 1 | -0/+185 |
* | Regenerate. | Ralf Corsepius | 2009-07-24 | 8 | -64/+312 |
* | Update. | Ralf Corsepius | 2009-07-24 | 8 | -8/+32 |
* | Bump GDB_RPMREL. | Ralf Corsepius | 2009-07-24 | 8 | -8/+8 |
* | Regenerate. | Ralf Corsepius | 2009-07-24 | 1 | -8/+39 |
* | Update. | Ralf Corsepius | 2009-07-24 | 1 | -1/+4 |
* | Bump GDB_RPMREL. | Ralf Corsepius | 2009-07-24 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2009-07-24 | 1 | -8/+36 |
* | Minor fixes. | Ralf Corsepius | 2009-07-24 | 1 | -1/+1 |
* | Remove. | Ralf Corsepius | 2009-07-24 | 1 | -16245/+0 |
* | Remove. | Ralf Corsepius | 2009-07-23 | 6 | -114/+0 |
* | Sync. with rtems-4.10. | Ralf Corsepius | 2009-07-23 | 2 | -6/+34 |
* | Regenerate. | Ralf Corsepius | 2009-07-21 | 28 | -331/+765 |
* | Bump *_RPMREL. | Ralf Corsepius | 2009-07-21 | 10 | -28/+28 |
* | Sync with rtems-4.10. | Ralf Corsepius | 2009-07-21 | 3 | -3/+5 |
* | Sync with rtems-4.10. | Ralf Corsepius | 2009-07-21 | 2 | -9/+27 |
* | Abandon mingw32, cygwin. | Ralf Corsepius | 2009-07-21 | 2 | -11/+1 |
* | Remove. | Ralf Corsepius | 2009-07-21 | 6 | -4131/+0 |
* | Cleanup. | Ralf Corsepius | 2009-07-21 | 9 | -108/+0 |
* | Remove. | Ralf Corsepius | 2009-07-21 | 8 | -523/+0 |
* | This commit was manufactured by cvs2svn to create branch 'rtems-4-8-branch'. | cvs2git | 2009-07-13 | 9 | -0/+33229 |
| | | | | | | | | | | | | Cherrypick from master 2009-07-13 14:20:36 UTC Ralf Corsepius <ralf.corsepius@rtems.org> 'Add autoconf-sources.add.': contrib/crossrpms/autotools/autoconf-sources.add contrib/crossrpms/autotools/automake-sources.add contrib/crossrpms/patches/binutils-2.17.50-cygwin-20060817-1.diff contrib/crossrpms/patches/gdb-6.5-bfinrtems-20071114.diff contrib/crossrpms/patches/gdb-6.5-bfinrtems-20090122.diff cpukit/libnetworking/ifaddrs.h cpukit/libnetworking/libc/getifaddrs.c cpukit/libnetworking/libc/if_indextoname.c cpukit/libnetworking/libc/if_nameindex.c | ||||
* | 2009-07-02 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-07-02 | 2 | -2/+7 |
| | | | | | * user/region.t: Fix typos where semaphore referenced instead of region or segment. | ||||
* | 2009-07-02 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-07-02 | 2 | -8/+11 |
| | | | | * user/preface.texi: Correct list of supported CPU architectures. | ||||
* | 2009-06-03 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-06-03 | 4 | -1/+22 |
| | | | | | | | PR 1421/filesystem * libfs/src/imfs/deviceio.c, libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_handlers_device.c: Backport ftruncate support for devices so fopen(device, w) works. | ||||
* | 2009-05-28 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-05-28 | 6 | -16/+35 |
| | | | | | | | | | PR 1415/cpukit * rtems/src/semcreate.c, rtems/src/semtranslatereturncode.c, score/include/rtems/score/coremutex.h, score/inline/rtems/score/coremutex.inl, score/src/coremutex.c: Address two paths where a task with a priority above the ceiling could obtain a priority ceiling mutex. | ||||
* | 2009-05-21 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-05-21 | 4 | -21/+8 |
| | | | | | | | | PR 1414/cpukit * score/src/objectget.c, score/src/objectgetisr.c, score/src/objectgetnoprotection.c: Tighten math on extraction of index so it is harder to trick by passing in a valid id of an incorrect object class. | ||||
* | 2009-04-20 Kate Feng <feng1@bnl.gov> | Joel Sherrill | 2009-05-04 | 30 | -906/+1127 |
| | | | | | | | | | | | | | | | | | | 1396/bsps * pci/pci.c : Updated it to be consistent with the original pci.c * written by Eric Valette. There is no change in its function. * irq/irq_init.c : set defaultIrq->next_handler to be 0 * for BSP_SHARED_HANDLER_SUPPORT. * network/if_1GHz/if_wm.c : fixed some bugs in the 1GHz driver. * irq/BSP_irq.c : added supports for shared IRQ. * pci/pci_interface.c : Enabled PCI "Read", "Read Line", and "Read Multiple" * Agressive Prefetch to improve the performance of the PCI based * applications (e.g. 1GHz NIC). * irq/BSP_irq.c : Replaced the irq/irq.c, and used GT_GPP_Value * register to monitor the cause of the level sensitive interrupts. * This unique solution solves various bugs in the 1GHz network drivers * Fixed bugs in compute_pic_masks_from_prio() | ||||
* | Merge changes from CVS-HEAD addressing Fedora 11 rpm regressions. | Ralf Corsepius | 2009-04-30 | 4 | -27/+50 |
* | Update. Bump version. | Ralf Corsepius | 2009-04-08 | 1 | -3/+3 |
* | Use mirrorlists. | Ralf Corsepius | 2009-04-08 | 1 | -9/+6 |
* | 2009-04-02 Ralf Corsépius <ralfcorsepius@rtems.org> | Ralf Corsepius | 2009-04-02 | 2 | -1/+5 |
| | | | | * aclocal/check-rtems-debug.m4: Add missing ','. |
