PR 1268/cpukit
* libcsupport/include/rtems/assoc.h: There is no
rtems_assoc_ptr_by_value method.
* develenv/direct.t, develenv/sample.t: Corrected various errors in the
documentation.
* custom/mvme5500.cfg: Fix typo.
* user/clock.t, user/concepts.t, user/conf.t, user/datatypes.t,
user/dpmem.t, user/fatal.t, user/init.t, user/mp.t, user/msg.t,
user/part.t, user/region.t, user/rtmon.t, user/sem.t, user/task.t,
user/timer.t: Corrected various errors in the documentation.
* custom/mvme5500.cfg: Add compiler arguments sine without them, the
BSP has issues.
* develenv/develenv.texi, develenv/direct.t, develenv/intro.texi,
develenv/sample.t, develenv/utils.t: Update directory tree.
* network/network.c: Fix LED configuration to match uCDIMM.
PR 1266/cpukit
* posix/src/keycreate.c, posix/src/keyrundestructors.c: Use API instead
of class for key indexing.
* libmisc/cpuuse/cpuuse.c: Fix date formatting.
* network/if_100MHz/GT64260eth.c: Add else.
* README: Update.
* network/GT64260eth.c, network/GT64260eth.h, network/GT64260ethreg.h: Removed.
* Makefile.am, README, README.booting, README.irq,
preinstall.am, GT64260/MVME5500I2C.c, include/bsp.h, irq/irq.c,
irq/irq.h, irq/irq_init.c, pci/pci.c, pci/pci_interface.c,
pci/pcifinddevice.c, start/preload.S, startup/bspclean.c,
startup/bspstart.c, startup/pgtbl_activate.c, startup/reboot.c:
Merge my improvements in this BSP including a new network
driver for the 1GHz NIC.
* network/if_100MHz/GT64260eth.c, network/if_100MHz/GT64260eth.h,
network/if_100MHz/GT64260ethreg.h, network/if_100MHz/Makefile.am,
network/if_1GHz/Makefile.am, network/if_1GHz/POSSIBLEBUG,
network/if_1GHz/if_wm.c, network/if_1GHz/if_wmreg.h,
network/if_1GHz/pci_map.c, network/if_1GHz/pcireg.h: New files.
PR 1261/cpukit
* posix/src/semaphorecreatesupp.c: Initialize all fields during
semaphore creation.
PR 1260/cpukit
* posix/src/pthread.c: Get initial signals blocked from creating thread
not from ourselves.
PR 1259/rtems
* rtems/src/taskcreate.c: Initialize is_global in all cases since
memory is not guaranteed to be zero.
* Makefile.am, include/bsp.h: Do not include networking
drivers if networking is disabled.
* Makefile.maint: touch all documentation master files so the date on
the manual reflects the release date of the software.
* ChangeLog, sapi/src/io.c: Revert change accidentally committed to
io.c.
PR 1256/networking
* ftpd/ftpd.c, sapi/src/io.c: Fix unaligned access.
PR 1248/networking
* libnetworking/rtems/rtems_glue.c: Luke Stras <luke@spacequest.com>
reported that when no interfaces are successfully attached, the
default route is broken and may result in a jump to an illegal
address.
PR 1249/build
* configure.ac: Jerry Needell <jerry.needell@unh.edu> reported that the
leon3 was left out of the cache enable logic. Thus the cache
management support code was empty on LEON3 CPUs.
* include/rtems/bspIo.h, include/rtems/pci.h:
Add extern "C" guards. Reported by
Robert S. Grimes <rsg@alum.mit.edu>.
* score/include/rtems/score/copyrt.h: Update copyright notice.
PR 1244/bsps
* console/console.c: Remove definition of __assert.
* user/conf.t: Fix typo -- should have read kilobytes.
PR 1237/rtems
* cpu.c, cpu_asm.S, rtems/score/cpu.h: Add logic to prevent stack creep
when interrupts occur at a sufficient rate that the interrupted
thread never gets to clean its stack. This patch ensures that an
interrupted thread will not nest ISR dispatches on its stack.
PR 1243
* pppd/auth.c (set_allowed_addrs): Remove bogus dereference.
* posix/tools/runtest.in: Do not run pppd.exe from batch mode script.
* erc32/tools/runtest.in, leon2/tools/runtest.in,
leon3/tools/runtest.in: Do not run pppd.exe from batch mode script.
