* VERSION: Updated to rtems-4.6.1.
* aclocal/version.m4: Updated to rtems-4.6.1.
PR 594/tools
* setup.def, autotools/autoconf-rtems.spec.in: Increment and rebuild so
GNAT included.
PR 602/bsps
* irq/irq.h: Fix typo.
PR 599/pppd
* pppd/chat.c: Fre memory that is allocated to fix leak.
PR 599/pppd
PR 598/bsps
* cpu_asm.S, rtems/score/cpu.h: Add save of floating point
status/control register on context switches. Missing this register
was causing intermittent floating point errors.
PR 575/bsps
* startup/linkcmds: Remove.
PR 595/tests
* sp13/fillbuff.c, sp13/init.c, sp13/putbuff.c, sp13/system.h,
sp13/task1.c, sp13/task2.c: Fill_buffer() in fillbuff.c overruns the
supplied buffer due to confusion in the definition of MESSAGE_SIZE.
Some files in the sp13 test treat MESSAGE_SIZE as a count of bytes,
others treat it as a count of longs.
PR 596/tests
* sp32/init.c: A missing definition of TEST_INIT before including
<tmacros.h> means that buffered output will not work even if selected
in buffer_test_io.h.
* include/confdefs.h:
* psxmsgq01/init.c, psxtimer/psxtimer.c: Eliminate warning from
previous patch.
PR 576/doc
* FAQ/FAQ.texi, FAQ/Makefile.am: Remove embedded information as it was
out of date and frequently duplicated information available from
other public sources like the CrossGCC Wiki.
* FAQ/embeddedinfo.t: Removed.
PR 505/bsps
* setvec.c: Rework to remove punned pointer warning generated by gcc
3.3 and newer.
* cpu_asm.S: Close window while restoring interrupted task state which
resulted in CWP corruption.
PR 584/RTEMS
* src/eventtimeout.c: Fix critical section window.
PR 583/tests
* tm26/task1.c, tm27/task1.c: Correctly reset
_Thread_Dispatch_disable_level so printing is safe.
PR 582/core
* src/mqueue.c, src/mqueuecreatesupp.c, src/mqueuedeletesupp.c,
src/mqueueunlink.c: Use memory from workspace to avoid use of mutex
during dispatch disable critical section. Besides memory for object
names should come from the Workspace anyway.
PR 582/core
* psxmsgq01/init.c, psxmsgq01/psxmsgq01.scn: Fix the POSIX message
queue test so more of it runs now.
* Makefile.am: Use rtems_source_spec_DEPS instead of
rtems_source_spec_DEPENDENCIES (Conflicts with automake internals).
* configure.ac: Remove rtemsdoc/mkspec.
* rtemsdoc/.cvsignore: Reformat.
* configure.ac: Add RTEMS_RPM_RELEASE.
* Makefile.am: Reformat. Add RTEMS_RPM_RELEASE support to
rtems-source.add
* rtems/rtems-source.add: Add RTEMS_RPM_RELEASE.
* rtemsdoc/mkspec.in: Remove.
* rtemsdoc/Makefile.am: Reworked.
* rtemsdoc/header.add: Update Copyright notice.
* rtemsdoc/rtemsdoc.add: Add RTEMS_RPM_RELEASE.
Add %{rpmgroup}. Remove bzip-ing *.ps.
* rtemsdoc/supplement.add.in: Add %{rpmgroup}.
* rtemsdoc/templ.add.in: Add %{rpmgroup}.
* index.html.in: Change header URL to www.rtems.com.
PR 575/bsps
PR make_build/574
* Makefile.am: Re-added since missing for some reason.
* rtems/rtems-source.add: New.
* Makefile.am: Add rtems/rtems-source.spec handling.
* configure.ac: AC_SUBST(RTEMS_VERSION,[_RTEMS_VERSION]).
* common/common.add.in: Use www.rtems.com as Vendor.
Cherrypick from master 2004-02-01 08:27:24 UTC Ralf Corsepius <ralf.corsepius@rtems.org> '2004-02-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>':
aclocal/rpm.m4
Cherrypick from master 2004-02-09 13:21:24 UTC Ralf Corsepius <ralf.corsepius@rtems.org> '2004-02-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>':
scripts/rtems/rtems-source.add
* VERSION: Updated to rtems-4.6.0.
PR 566/bsps
* start/regs.S: Fix nasty typo.
* aclocal/version.m4: Updated to rtems-4.6.0.
* Makefile.am: Removed.
* include/buffer_test_io.h: Do not use iprintf() if in ANSI compiler
mode.
* HELP.html, index.html.in, rtems_footer.html.in, rtems_header.html.in,
rtems_support.html.in, FAQ/basic.t, gnu_docs/gnu_footer.html,
gnu_docs/index.html, gnu_docs/refcard.html,
gnu_docs/rtems_tools_index.html, started/binaries.t,
started/buildc.t, started/buildrt.t, started/intro.t,
started/require.t, started/sample.t, started/tversions.texi.in:
Attempt to make the documentation more accurately reflect the state
of the world. These changes were primarily concerned with server
layout.
* configure.ac: Add RTEMSRPMGROUP.
* common/rtems.texi.in: Add RTEMSRPMGROUP.
* started/binaries.t: Add RTEMSRPMGROUP.
* aclocal/rpms.m4: New (extracted from scripts/configure.ac).
* binaries.t, buildc.t: Use @value{RTEMSRPMPREFIX} in refs to rpms.
* configure.ac: Add RTEMS_ENABLE_RPMPREFIX.
Add RTEMSRPMPREFIX.
* common/rtems.texi.in: Add RTEMSRPMPREFIX.
PR pppd/564
* net/if_ppp.c, net/if_pppvar.h, net/ppp_tty.c: ppp0 Interface lose
packets if the system use a slow baudrate for the modem or the
tcp/ip-packet is fragmented.
* setup.def: Reflect new binutils RPM revision to correct defattr.
* configure.ac: Use all CAPS RTEMS.
* setup.def: Make it match gcc 3.2.3 RPMs.
