Closes #2775.
This lets the table be changed at runtime for dynamic loading and
debugger support.
Closes #2775.
Updates #2782
Updates #2783
level.
New function arm_cp15_cache_invalidate_level and arm_cp15_cache_clean_level
can be used to maintain single cache level (instruction or data).
Updates #2782
Updates #2783
Protection by rtems_interrupt_disable() is incompatible with SMP build.
Actual page table entries manipulation function does not need locking
and disabling cache and can be run concurrently even on multiple
CPUs as long as changes do not modify same region. If the function
is called from more threads/CPUs to modify same region with different
mapping options concurrently then there is problem at another level
of virtual address space management and has to be solved by mutex
or other locking at that level.
Updates #2782
Updates #2783
The change documents meaning of codes and opens
well defined way to use cache type format for cache
examination/debugging outside of arm-cp15.h file.
Updates #2782
Updates #2783
initialization starts.
The u-boot loader enables the MMU plus the data and instruction caches
in some versions which results in RTEMS boot failure.
Closes #2774.
levels.
This fix strange behavior where some stale content has been
stored in level 2 cache before RTEMS has been start from U-boot
which has reappeared after MMU enable and shadow vector
table at start of SDRAM.
Updates #2782
Updates #2783
architecture variants now.
Next cache operations should work on most of cores now
rtems_cache_flush_entire_data()
rtems_cache_invalidate_entire_data()
rtems_cache_invalidate_entire_instruction()
Instruction cache invalidate works on the first level for now only.
Data cacache operations are extended to ensure flush/invalidate
on all cache levels.
The CP15 arm_cp15_data_cache_clean_all_levels() function extended
to continue through unified levels too (ctype = 4).
Updates #2782
Updates #2783
Disabling MMU requires complex cache flushing and invalidation
operations. There is almost no way how to do that right
on SMP system without stopping all other CPUs. On the other hand,
there is documented sequence of operations which should be used
according to ARM manual and it guarantees even distribution
of maintenance operations to other cores for last generation
of Cortex-A cores with multiprocessor extension.
This change could require addition of appropriate entry
to arm_cp15_start_mmu_config_table for some BSPs to ensure
that MMU table stays accessible after MMU is enabled
.begin = (uint32_t) bsp_translation_table_base,
.end = (uint32_t) bsp_translation_table_base + 0x4000,
.flags = ARMV7_MMU_DATA_READ_WRITE_CACHED
Updates #2782
Updates #2783
Memory content changes caused by relocation has to be
propagated to memory/cache level which is used/snooped
during instruction cache fill.
Closes #2438
Updates #2782
The basic data and instruction rage functions should be compatible
for all ARMv4,5,6,7 functions. On the other hand, some functions
are not portable, for example arm_cp15_data_cache_test_and_clean()
and arm_cp15_data_cache_invalidate() for all versions and there
has to be specialized version for newer cores.
arm_cache_l1_properties_for_level uses CCSIDR which is not present
on older chips.
Actual version is only experimental, needs more changes
and problem has been found on RPi1 with dlopen so there seems
to be real problem.
Updates #2783
Updates #2782
BSPs.
The original ARM architecture wide cache_.h is changed to dummy version
for targets not implementing/enablig cache at all.
The ARM targets equipped by cache should include
appropriate implementation.
Next options are available for now
c/src/lib/libbsp/arm/shared/armv467ar-basic-cache/cache_.h
basic ARM cache integrated on the CPU core directly
which requires only CP15 oparations
c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h
support for case where ARM L2C-310 cache controller
is used. It is accessible as mmaped peripheral.
c/src/lib/libbsp/arm/shared/armv7m/include/cache_.h
Cortex-M specific cache support
Updates #2782
Updates #2783
Updates #2782
Updates #2783
and maximal alignment.
There is need for unambiguous named and defined cache function
which should be called when code is updated, loaded
or is self-modifying.
There should be function to obtain maximal cache line length
as well. This function can and should be used for allocations
which can be used for data and or code and ensures that
there are no partial cache lines overlaps on start and
end of allocated region.
Updates #2782
Some/many Cortex-A cores have data cache line length 64 bytes and maximum
value has to be used for system structures alignment.
Updates #2782
Updates #2783
base access.
The main reason for inclusion of minimum hypervisor related defines
is that current ARM boards firmware and loaders (U-boot for example)
start loaded operating system kernel in HYP mode to allow it take
control of virtualization (Linux/KVM for example).
Updates #2783
The current versions of U-boot start kernel/RTEMS application image
with instruction and data caches enabled and it sets exception
base register to new address after its self-relocation.
ldr r0, [r9, #GD_RELOCADDR] /* r0 = gd->relocaddr */
mcr p15, 0, r0, c12, c0, 0 /* Set VBAR */
Included changes in bsp_start_hook_0 restore default state to
allow RTEMS image to run after startup from newer U-boot version
on Raspberry Pi.
Clear interrupt enable registers in interrupt controller
to ensure that RTEMS starts from well defined state.
Updates #2783
Updates #2782
Updates #2783
Only use CPU_Per_CPU_control if it contains at least one filed. In GNU
C empty structures have a size of zero. In C++ structures have a
non-zero size. In case CPU_PER_CPU_CONTROL_SIZE is defined to zero,
then this structure is not used anymore.
Close #2789.
This patch fixes a number of bugs in the cache when requests are
made to read close to the end of the file and the data is copied
from the top of the cache buffer to the bottom of the buffer. This
was compounded by attempting to read past the end of the file.
Closes #2754.
The Termios modes are now an emum. Do not use them in #if expressions.
Update #2762.
Properly pass the stack aligned context to _CPU_Context_switch_altivec()
since _CPU_altivec_ctxt_off defined via ppc_context.
Update #2761.
There must be an isync after the mtmsr to ensure that the AltiVec is
enabled for subsequent instructions.
Close #2760.
Update #2719.
A cluster size > 32KiB resulted in an infinite loop in
fat_init_volume_info() due to an integer overflow.
Update #2717.
POSIX mandates that an error code is returned and not -1 plus errno.
Update #2715.
POSIX recommends ESRCH in case no thread exists for the specified
identifier.
Update #2713.
The window underflow trap handler used %i5 which destroyed the %o5 of
the calling context. Bug introduced by
0d3b5d47429effb350448d9e9123a67db722109f.
Go back to the pre 0d3b5d47429effb350448d9e9123a67db722109f behaviour
and use the two unused instructions in the trap vector to optimize a
bit.
Close #2651.
Add path length parameter to
rtems_filesystem_eval_path_start_with_root_and_current() so that users
may pass paths without a '\0' termination.
Update #2558.
Close #2502.
Close #2530.
Under certain conditions a new watchdog was inserted with a wrong
and very large delta interval due to a wrong iterator update.
Bug was introduced by 1ccbd052910ed16131c74b0d5595c8a94066942d.
Close #2507.
closes #2508.
Under certain conditions a new watchdog was inserted with a wrong and
very large delta interval due to an incomplete iterator update.
Close #2501.
Fixed as reported by Pavel:
https://lists.rtems.org/pipermail/devel/2015-December/013189.html
Closes #2498.
Show the architecture and BSP count.
Closes #2491.
Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz>
The problem exists for both RTEMS untar implementations and their
variants: Untar_FromMemory(), Untar_FromFile() and rtems_tarfs_load().
If filesystem object already exists at extracted directory path
then if it is directory, creation is ignored. Attempt
to delete/unlink object and make directory is tried for other cases.
This simple approach problem reported in ticket fixes #2413.
Behavior follows GNU tar and BSD tar practice for directories
but much more work is required to achieve full semantics
of the full featured tar implementation still.
remarks.
Signed-off-by: Premysl Houdek <kom541000@gmail.com>
boot loader.
The default tms570ls3137_hdk variant is for building RTEMS
application image starting directly from start of Flash.
Variant tms570ls3137_hdk_with_loader skips 256kB at start
of Flash to allow use with application loader.
Parameters overlay module is initialized and cleared first.
It is used later to replace exception target vectors
only if that is required.
The application loader code with CPU and SDRAM setup
code has to provide well defined pattern of instructions
at addresses 0x00000000 and 0x0000001f, because only data
read accesses can be processed reliably by POM. The expected
instruction pattern can be seen in the next example
https://github.com/hornmich/tms570ls3137-hdk-sdram/blob/master/SDRAM_SCI_configuration/source/sys_intvecs.asm
Comments with detailed description of code, background
and reasons for selected approach have been included
in TMS570 bsp startup code.
