* | ARM removed shared/abort from several ARM BSPs | Alan Cudmore | 2014-11-20 | 6 | -54/+55 |
* | libdl: Update comment with details about the error fix. | Chris Johns | 2014-11-20 | 1 | -0/+3 |
| | | | | See refs #2192. | ||||
* | libdl: Update the comments. | Chris Johns | 2014-11-20 | 1 | -1/+2 |
| | | | | See refs #2191. | ||||
* | libdl: Fix possible 16-bit overflow (Coverity 1255339) refs #2192. | Chris Johns | 2014-11-20 | 1 | -1/+1 |
| | | | | | On a 16-bit target the section value could result in a sign-extension overflow. | ||||
* | libdl: Add a comment. | Chris Johns | 2014-11-20 | 1 | -0/+3 |
| | | | | See ref #2191. | ||||
* | libdl: Add a comment to the previous fix. | Chris Johns | 2014-11-20 | 1 | -0/+3 |
| | | | | The fix is ref #2191. | ||||
* | libdl: Fix allocator NULL check (Coverity 1255328) refs #2191 | Chris Johns | 2014-11-20 | 1 | -1/+1 |
| | | | | | The address returned from the allocator call was not checked when zeroing the memory. | ||||
* | Fix type in MAINTAINERS. | Chris Johns | 2014-11-20 | 1 | -1/+1 |
* | Update MAINTAINERS with blanket commits for Daniel and SPARC. | Chris Johns | 2014-11-20 | 1 | -2/+2 |
* | Update maintainers with Daniel. | Chris Johns | 2014-11-20 | 1 | -1/+2 |
* | Update the maintainers list. | Chris Johns | 2014-11-20 | 1 | -2/+0 |
* | libmisc: Add the libmisc/redirector to the wrap up. | Chris Johns | 2014-11-20 | 1 | -0/+1 |
* | libdl: Disable building libdl for the NIOS2. No relocation support. | Chris Johns | 2014-11-06 | 3 | -46/+2 |
| | | | | This should have been added. | ||||
* | lpc23xx_tli800-testsuite.tcfg: Add dl02 | Joel Sherrill | 2014-11-05 | 1 | -0/+1 |
* | lpc2362-testsuite.tcfg: Add dl02 | Joel Sherrill | 2014-11-05 | 1 | -0/+1 |
* | lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add a handful more tests | Joel Sherrill | 2014-11-05 | 1 | -0/+8 |
* | lm3s3749-testsuite.tcfg: Add dl02 | Joel Sherrill | 2014-11-05 | 1 | -0/+1 |
* | shell/main_edit.c: Fix warnings | Joel Sherrill | 2014-11-05 | 1 | -8/+10 |
* | lpc23xx_tli800-testsuite.tcfg: Add dl01 | Joel Sherrill | 2014-11-04 | 1 | -0/+1 |
* | lpc2362-testsuite.tcfg: Add dl01 | Joel Sherrill | 2014-11-04 | 1 | -0/+1 |
* | lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add rbheap01 | Joel Sherrill | 2014-11-04 | 1 | -0/+1 |
* | lm3s3749-testsuite.tcfg: Add dl01 | Joel Sherrill | 2014-11-04 | 1 | -0/+1 |
* | sapi/src/testextension.c: Fix warnings | Joel Sherrill | 2014-11-04 | 1 | -0/+2 |
* | libdl/rtl-mdreloc-bfin.c: Include rtems/rtl/rtl.h not rtl.h | Joel Sherrill | 2014-11-04 | 1 | -1/+1 |
* | libdl/Makefile.am: Need preinstall on all targets | Joel Sherrill | 2014-11-04 | 1 | -2/+2 |
* | libdl: RTLD_DEFAULT searches the global symbol table. | Chris Johns | 2014-11-04 | 1 | -6/+15 |
* | libtests: Add libdl test dl02. | Chris Johns | 2014-11-04 | 11 | -1/+413 |
| | | | | Loads 2 interdependent ELF object files. | ||||
* | libtests: Update dl01 documentation. | Chris Johns | 2014-11-04 | 3 | -1/+40 |
* | Regenerated preinstall.am file. | Chris Johns | 2014-11-04 | 1 | -0/+1 |
* | libdl: Add a local symbol table to the object module. | Chris Johns | 2014-11-04 | 5 | -87/+193 |
| | | | | | | Adding a local symbol lets the relocator find local symbols referenced in relocation records. The local symbol table is erased once the object module has been loaded. | ||||
* | BSP for several Beagle products | Ben Gras | 2014-11-03 | 36 | -3221/+1485 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Specifically the beagleboard, beagleboard xM, beaglebone, beaglebone black. More info on these targets: http://www.beagleboard.org/ This commit forms a basic BSP by combining Claas's work with . new clock and irq code and definitions for beagle targets (beagleboard and beaglebones), mostly reused from the Minix codebase, thus making irqs, ticks and non-polled console mode work too . new timer code for ns timing with high timer resolution, 24MHz on the AM335X and 13MHz on the DM37XX . select the console uart based on target at configure time . removing all the lpc32xx-specific macros and code and other unused code and definitions that the beagle bsp was based on . re-using some standard functions instead of lpc32xx versions . fixed some whitespace problem in preinstall.am . fixed some compile warnings . configure MMU: set 1MB sections directly in the TTBR, just to show the difference between cacheable RAM and non-cacheable device memory and invalid ranges; this lets us turn on caches and not rely on boot loader MMU configuration. Verified to work when MMU is initially either on or off when RTEMS gets control. Thanks for testing, commentary, improvements and fixes to Chris Johns, Brandon Matthews, Matt Carberry, Romain Bornet, AZ technology and others. Signed-Off-By: Ben Gras <beng@shrike-systems.com> | ||||
* | Added BeagleBoard BSP | Claas Ziemke | 2014-11-03 | 29 | -0/+4596 |
| | | | | | | | Coding done in course of GSoC2012. Commit edited to be brought up-to-date with mainline by Ben Gras <beng@shrike-systems.com>. | ||||
* | Add some generic ARM am335x and omap definitions | Ben Gras | 2014-11-03 | 3 | -0/+692 |
* | cpuuse: Resolve compile errors. | Jennifer Averett | 2014-11-03 | 1 | -28/+68 |
* | dl01/dl-load.c: Add missing const | Joel Sherrill | 2014-11-02 | 1 | -1/+1 |
* | libcpu/bfin/clock/tod.h: Delete - missed on previous commits | Joel Sherrill | 2014-10-31 | 1 | -61/+0 |
* | bsp/mpc55xxevb: Fix flash settings for MPC5510 | Sebastian Huber | 2014-10-31 | 2 | -23/+45 |
* | libnetworking: Fix the sethostname decl to match newlib. | Chris Johns | 2014-10-31 | 3 | -3/+3 |
* | cpukit: Add libdl with the Runtime Loader (RTL) code. | Chris Johns | 2014-10-31 | 91 | -5/+14746 |
| | | | | This is a merge of the RTL project. | ||||
* | Added missing stm32f4xxxx_adc.h | Chris Nott | 2014-10-30 | 1 | -0/+320 |
* | top: Add new test. | Jennifer Averett | 2014-10-28 | 9 | -1/+388 |
* | capture: Remove ctload command. | Jennifer Averett | 2014-10-28 | 1 | -272/+0 |
| | | | | rtems_cpu_usage_top should be used for this information. | ||||
* | libmisc: Add top to shell. | Jennifer Averett | 2014-10-27 | 3 | -1/+67 |
* | libmisc: Add top to cpuusage. | Jennifer Averett | 2014-10-27 | 3 | -1/+357 |
* | capture01: Remove capture task tracking. | Jennifer Averett | 2014-10-27 | 1 | -27/+85 |
| | | | | | This involved adding a new variable record to the capture buffer and modifing the trace method to read those records. | ||||
* | capture: Removal of capture task tracking. | Jennifer Averett | 2014-10-27 | 5 | -892/+415 |
| | | | | | | | | | | This patch removes functionality for stack checking from the capture engine and requiresi the use of existing rtems functions for this information. It modifies ctload to use functionality similar to rtems cpuusage. It removes the capture task and stores a new capture task record the first time the task is seen. The per task data that was still needed is scaled down and stored in the tcb. | ||||
* | cpuuse: Move is_executing_on_a_core to threadimpl.h | Jennifer Averett | 2014-10-27 | 1 | -24/+1 |
* | score: Move is_executing_on_a_core from cpuusagereport.c to threadimpl.h | Jennifer Averett | 2014-10-27 | 1 | -0/+30 |
* | score: Add capture data to tcb. | Jennifer Averett | 2014-10-27 | 2 | -0/+10 |
* | shell: Add an editor to the shell. | Chris Johns | 2014-10-24 | 3 | -1/+2266 |
| | | | | | | This is a small (21K on sparc) editor that provides some powerful features useful when a file needs editing on an embedded board. No need to copy files off, edit, copy back. |
