The
KEEP (*(SORT(.ctors.*)))
KEEP (*(.ctors))
cannot be simplified to
KEEP (*(SORT(.ctors*)))
since
.ctors < .ctors.*
in lexicographical order.
See spglobalcon02 test case.
Close #3319.
Check in init3 not needed since same data is already checked in init2
stage. Adds an extra check that the APB register space is available before
accessing it.
Closes #2331
Updates #3877
- Fix the passing of std[in/out] to child threads
- Fix deleting of managed memory in the key destructor
- Only set the key in the main loop thread
- Only allocate a shell env outside of the main loop
- Fix memory leak if the task start fails
- Remove error level from shell env, it cannot be returned this way. Add
exit_code but the API is broken so it cannot be returned.
Closes #3877
- Newlib overtites any FILE pointers set in stdin, stdout or stderr.
Closes #3870
Close #3722.
(cherry picked from commit 2e8a66d13f04015c0024a084578f720ceb15ea00)
This bug had probably no effect since the interrupt enable is idempotent
on all CPU ports.
Close #3497.
The function rtems_rfs_buffer_sync() erroneously calls
rtems_disk_release(). This screws up the reference counting of the disk.
Close #3494.
It tests the (never really working) strict order mutex option.
Update #3406.
Closes #3324
Update #2747
Handles possible NULL return value
Updates #2747
POSIX specifies char *, not const char *
Updates #2747
Updates #2747
Updates #2747
The configure order effects how it works.
Close #3297
If there is already a file with a long file name it isn't possible to
create a second file which has a name that ends on the first files name
(for example ets.beam and sets.beam). This patch fixes that.
Close #3258.
Take care that a file in the root directory with the same name as the
volume name can be found.
Close #3257.
Close #3164.
The RTEMS_MILLISECONDS_TO_TICKS() macro doesn't round up. Do not use it
to calculate the program timeout in ticks. Check program done condition
after the timeout check to account for pre-emptions.
Close #3162.
Close #3161.
Do not update the non-existant meta-data of the root directory.
Close #2944.
Close #2964.
Set a proper name buffer length for each converter invocation.
Close #2987.
- Add AM C++ support to the testsuite configure.ac script.
- Fix the dependences in the DL tests.
Closes #3024.
- Add 'rtems_shell_init_environment()' so a user can create the
shell environment without needing to run a shell.
- Move 'rtems_shell_lookup_topic', 'rtems_shell_can_see_cmd',
and 'rtems_shell_execute_cmd' from the internal interface to
the public interface.
Closes #3104.
Remove the OBJECTS_UNLIMITED_OBJECTS flag for the memory size
configuration.
Close #3105.
Close #3093.
Do not touch the FPSCR[QC] bit since this is DNM/RAZ on Cortex-R4.
Close #3092.
Right after a "msr basepri_max, %[basepri]" instruction an interrupt
service may still take place (observed at least on Cortex-M7). However,
pendable service calls that are activated during this interrupt service
may be delayed until interrupts are enable again. The
_ARMV7M_Pendable_service_call() did not check that a thread dispatch is
allowed. Move this test from _ARMV7M_Interrupt_service_leave() to
_ARMV7M_Pendable_service_call().
Close #3060.
Close #3002.
Closes #2956.
Do not use our long file name entry count to optimize the file name
search. The Unicode comparison must be taken into account.
Close #2939.
Obtain file system instance lock before member access.
Close #2937.
The name "fat_entries" for long file name directory entries is quite
misleading.
Close #2934.
Simplify.
Make sure that long file names work accross cluster boundaries.
Close #2929.
Update #2929.
Update #2929.
Update #2929.
Update #2929.
Remove forced overwrite which leads to file data corruption. The logic
to determine a forced overwrite was fundamentally broken. For simplity,
disable this feature.
Close #2622.
It is all right in case the result uses the full destination buffer.
Without this fix the handling of a maximum 8.3 short file name is
broken.
Close #2928.
Perform a context-dependent deferred location release to avoid a
deadlock on the file system instance locks, for example during a
chdir().
Close #2936.
Closes #2827.
In canonical mode, the raw input buffer or the canonical buffer may
overflow without an end of line. Avoid an infinite loop in this case.
Update #2915.
Use the device lock to protect the raw input buffer management, e.g.
tail, head and buffer content updates.
Update #2914.
Remove dead code.
Update #2914.
The second FAT entry contains a bit to indicate if the FAT32 filesystem
is not dirty and a bit to indicate if there was no IO error. Set both
bits for a fresh filesystem. This prevents a warning if mounted on
Windows.
Update #2913.
