* | removed need for exceptbdr.h file | Joel Sherrill | 1996-09-06 | 2 | -2/+2 | |
* | new file for MIPS port by Craig Lebakken (lebakken@minn.net) and | Joel Sherrill | 1996-09-06 | 71 | -0/+16850 | |
| | | | | Derrick Ostertag (ostertag@transition.com). | |||||
* | added MIPS port by Craig Lebakken (lebakken@minn.net) and Derrick Ostertag | Joel Sherrill | 1996-09-06 | 1 | -0/+5 | |
* | modified test to take into account change in default value of | Joel Sherrill | 1996-09-06 | 2 | -0/+10 | |
| | | | | | inheritsched pthread attribute from implicit to explicit scheduling parameters. | |||||
* | changed _TOD_Is_set from a function to a boolean variable | Joel Sherrill | 1996-09-06 | 20 | -86/+47 | |
* | default thread attributes: default value for inheritsched changed from | Joel Sherrill | 1996-09-05 | 2 | -10/+50 | |
| | | | | | | | | | | | | explicit to inherit scheduler to be consistent with FSU pthreads for gnat. _POSIX_Threads_Create_extension: now inherit signal blocked mask from creator if the new thread is a posix thread. _POSIX_Threads_Initialize_user_threads: make sure posix initialization threads start with a useful priority. If they inherit the priority of the creating thread, they will end up at the same priority as the idle thread. Since the idle thread does not yield, they will not run. | |||||
* | pthread_mutex_setprioceiling: fixed bug where returned priority was | Joel Sherrill | 1996-09-05 | 2 | -2/+6 | |
| | | | | not converted from core priority to posix priority. | |||||
* | added printf of status when not successful | Joel Sherrill | 1996-09-05 | 2 | -2/+6 | |
* | nanosleep: negative value for tv_sec is no longer an error. It now | Joel Sherrill | 1996-09-05 | 2 | -8/+20 | |
| | | | | is changed into being a 0 delay. | |||||
* | nanosleep no longer consider a negative value of tv_sec to be an error. | Joel Sherrill | 1996-09-05 | 2 | -12/+14 | |
| | | | | Instead it is an indication of a request for a small delay. | |||||
* | new file to support GNU Ada. | Joel Sherrill | 1996-08-29 | 2 | -0/+56 | |
| | | | | | currently the only routine in this file simply returns the minimum stack size for each thread. | |||||
* | fixed typo .. changed == to != | Joel Sherrill | 1996-08-27 | 2 | -2/+2 | |
* | check that we were passed a valid mutex and ignore errors from the | Joel Sherrill | 1996-08-27 | 2 | -0/+16 | |
| | | | | | later pthread_mutex_lock. This makes our behavior more compatible with that of FSU pthreads. | |||||
* | Changed all EFAULTS to EINVALs | Mark Johannes | 1996-08-23 | 2 | -28/+40 | |
* | filled in screen | Mark Johannes | 1996-08-23 | 2 | -0/+22 | |
* | Filled in screen | Mark Johannes | 1996-08-23 | 4 | -0/+156 | |
* | Filled in the screen | Mark Johannes | 1996-08-23 | 18 | -0/+958 | |
* | Added build_time statement to provide a tm for the test | Mark Johannes | 1996-08-23 | 2 | -4/+8 | |
* | Changed test 5 to test 10 at bottom | Mark Johannes | 1996-08-23 | 2 | -2/+2 | |
* | pthread_create: changed EINVAL for no more threads back to EAGAIN | Mark Johannes | 1996-08-23 | 2 | -40/+42 | |
* | Commented out the EINVAL for mutex not acquired befor cond_wait call | Mark Johannes | 1996-08-22 | 2 | -8/+18 | |
* | updated to support ENOTSUP | Mark Johannes | 1996-08-21 | 2 | -20/+20 | |
* | Added Einval case for mutex not initialized | Mark Johannes | 1996-08-20 | 2 | -0/+20 | |
* | Changed all EFAULTs to EINVALs | Mark Johannes | 1996-08-19 | 2 | -14/+28 | |
* | pthread_mutex_init: added error messages for NULL mutex and EBUSY | Mark Johannes | 1996-08-19 | 2 | -12/+44 | |
* | updates from Tony Bennett (tbennett@divnc.com) | Joel Sherrill | 1996-08-15 | 3 | -4/+30 | |
* | _Thread_Start_multitasking: added code to initialize the floating point | Joel Sherrill | 1996-08-15 | 2 | -2/+50 | |
| | | | | context of the first thread to execute. | |||||
* | changed ENOMEM error message | Mark Johannes | 1996-08-15 | 2 | -2/+8 | |
* | init: added tests for pthread_kill and kill errors. | Mark Johannes | 1996-08-15 | 2 | -64/+372 | |
* | changed error code | Joel Sherrill | 1996-08-15 | 2 | -4/+4 | |
* | changed error for too many threads to EAGAIN | Joel Sherrill | 1996-08-15 | 2 | -4/+4 | |
* | clock_gettime: changed assert condition to a standard error code | Joel Sherrill | 1996-08-15 | 2 | -4/+6 | |
| | | | | clock_getres: now checking for a null pointer being passed in | |||||
* | sched_rr_get_interval: converted assert condition into a standard error | Joel Sherrill | 1996-08-15 | 2 | -2/+10 | |
| | | | | code and added check for a NULL interval being passed in. | |||||
* | added constant to indicate there is no mutex associated with this | Joel Sherrill | 1996-08-15 | 3 | -0/+21 | |
| | | | | condition variable | |||||
* | pthread_kill: fixed the move of SIG_IGN not SA_SIGINFO | Mark Johannes | 1996-08-15 | 2 | -8/+12 | |
* | pthread_kill: moved check for SA_SIGINFO to allow for validation of all | Mark Johannes | 1996-08-15 | 2 | -14/+14 | |
| | | | | parameters. Also changed returns to macro of -1 and errno set. | |||||
* | fixed typo for NOTSUP -> ENOTSUP | Mark Johannes | 1996-08-15 | 2 | -26/+24 | |
* | pthread_mutex_init returns EAGAIN not ENOMEM when there are too many mutexes. | Joel Sherrill | 1996-08-14 | 2 | -4/+4 | |
* | added test cases for NULL being passed to pthread attribute get routines | Joel Sherrill | 1996-08-14 | 2 | -0/+40 | |
* | added test case for pthread_attr_getscope being passed a NULL contentionscope | Joel Sherrill | 1996-08-14 | 2 | -0/+8 | |
* | commented of ENOTSUP until fixed in newlib | Mark Johannes | 1996-08-14 | 2 | -0/+2 | |
* | pthread_cond_timedwait: added error cases for abstime | Mark Johannes | 1996-08-14 | 2 | -0/+22 | |
* | system.h: added task3 and changed condition variable config to 1 | Mark Johannes | 1996-08-14 | 2 | -2/+12 | |
* | task3: added to test error case in Wait_support for lock on mutex | Mark Johannes | 1996-08-14 | 2 | -0/+92 | |
* | init: added error case for wait timedwait, and wait support | Mark Johannes | 1996-08-14 | 2 | -16/+306 | |
* | pthread_attr_setscope: returns ENOTSUP not ENOSYS for unsupport scope | Joel Sherrill | 1996-08-14 | 2 | -4/+4 | |
* | pthread_cond_destroy: added enable dispatch to EBUSY case | Mark Johannes | 1996-08-13 | 2 | -2/+6 | |
* | pthread_codn_destroy: EBUSY case moved and uses Thread_queue_First | Mark Johannes | 1996-08-13 | 2 | -6/+6 | |
* | pthread_cond_destroy: EBUSY case now uses Thread_queue_First | Mark Johannes | 1996-08-13 | 2 | -2/+2 | |
* | removed count from Thread_queue_Control | Mark Johannes | 1996-08-13 | 3 | -3/+0 | |
