path: root/.gitignore (follow)
* gitignore: ignore top-level ini filesGedare Bloom2020-09-181-0/+1
* build: Alternative build system based on wafSebastian Huber2020-09-141-2/+9
| | | | Update #3818.
* Update Doxyfile to Doxygen 1.8.15Sebastian Huber2019-03-041-0/+1
| | | | | | | | | | Generate Doxygen output in doc and ignore this directory in Git. Add RTEMS logo. The Doxygen documentation is now built using the source tree. Just invoke "doxygen" in the top-level source directory. The Doxyfile works also with at least Doxygen 1.8.13 and Doxygen 1.8.14. Update #3705.
* Revert "Ignore emacs backfiles and TAGS."Chris Johns2014-05-301-2/+0
| | | | | | This reverts commit dac56968e343cccfcae46e25805ede1a8d67550a. Use local git ignore for development tool files.
* Ignore emacs backfiles and TAGS.Chris Johns2014-05-281-0/+2
* Revert "Add config.h.in."Gedare Bloom2012-08-061-0/+1
| | | | This reverts commit cf42a6ea9dbb6ebee498ae8db319d3e475bcd6be.
* Add config.h.in.Ralf Corsépius2012-05-241-1/+0
* 2012-02-22 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsépius2012-02-221-4/+0
| | | | | * .gitignore: Remove config.guess, config.sub, missing, install-sh. * config.guess, config.sub, missing, install-sh: New.
* Add minimal .gitignore files.Joel Sherrill2012-02-011-0/+9
