2020-09-14 | build: Alternative build system based on waf | Sebastian Huber | 1 | -2/+9 | |
Update #3818. | |||||
2019-03-04 | Update Doxyfile to Doxygen 1.8.15 | Sebastian Huber | 1 | -0/+1 | |
Generate Doxygen output in doc and ignore this directory in Git. Add RTEMS logo. The Doxygen documentation is now built using the source tree. Just invoke "doxygen" in the top-level source directory. The Doxyfile works also with at least Doxygen 1.8.13 and Doxygen 1.8.14. Update #3705. | |||||
2014-05-30 | Revert "Ignore emacs backfiles and TAGS." | Chris Johns | 1 | -2/+0 | |
This reverts commit dac56968e343cccfcae46e25805ede1a8d67550a. Use local git ignore for development tool files. | |||||
2014-05-28 | Ignore emacs backfiles and TAGS. | Chris Johns | 1 | -0/+2 | |
2012-08-06 | Revert "Add config.h.in." | Gedare Bloom | 1 | -0/+1 | |
This reverts commit cf42a6ea9dbb6ebee498ae8db319d3e475bcd6be. | |||||
2012-05-24 | Add config.h.in. | Ralf Corsépius | 1 | -1/+0 | |
2012-02-22 | 2012-02-22 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsépius | 1 | -4/+0 | |
* .gitignore: Remove config.guess, config.sub, missing, install-sh. * config.guess, config.sub, missing, install-sh: New. | |||||
2012-02-01 | Add minimal .gitignore files. | Joel Sherrill | 1 | -7/+4 | |
2011-03-20 | Add config.status, config.sub, config.log. | Ralf Corsepius | 1 | -1/+3 | |
2009-11-30 | Update. | Ralf Corsepius | 1 | -1/+1 | |
2006-08-09 | 2006-08-09 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+1 | |
* .cvsignore: Add INSTALL. | |||||
2006-02-15 | Update. | Ralf Corsepius | 1 | -0/+3 | |
2006-02-15 | New. | Ralf Corsepius | 1 | -3/+4 | |
2002-10-21 | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -1/+1 | |
* .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | |||||
2002-10-09 | 2002-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+1 | |
* .cvsignore: Add autom4te.cache. | |||||
2002-01-06 | 2002-01-06 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+2 | |
* .cvsignore: Added aclocal.m4 and configure. | |||||
2002-01-06 | 2002-01-06 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+0 | |
* .cvsignore: New file. | |||||
* wrapup/.cvsignore: Readded. * include/.cvsignore: New file. | |||||
2000-04-13 | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 1 | -0/+2 | |
adds .cvsignore. |
