* | Add configurations for all h8 GDB simulator BSP variants | Joel Sherrill | 2015-03-12 | 4 | -0/+220 | |
* | Add configurations for all arm GDB simulator BSP variants | Joel Sherrill | 2015-03-12 | 10 | -9/+503 | |
* | Add configuration for m32csim BSP for simulator in GDB | Joel Sherrill | 2015-03-12 | 2 | -0/+110 | |
* | Add configuration for m32rsim BSP for simulator in GDB | Joel Sherrill | 2015-03-12 | 2 | -0/+110 | |
* | Add configurations for all v850 GDB simulator BSP variants | Joel Sherrill | 2015-03-12 | 12 | -0/+660 | |
* | Modified waf scripts to have a minimum python version requirement of 2.6.6, ↵ | Adit Sahasrabudhe | 2015-02-25 | 1 | -1/+1 | |
| | | | | instead of 2.7.3 | |||||
* | Fix the chmod octal value to use the correct Python syntax. | Chris Johns | 2015-02-16 | 1 | -2/+2 | |
* | Update the Windows header to direct.h for _mkdir per the MSDN. | Chris Johns | 2015-02-16 | 1 | -1/+1 | |
* | Fix the tester wscript. | Chris Johns | 2015-02-08 | 1 | -2/+2 | |
* | Fixes to the run the waf built tests when installed. | Chris Johns | 2015-02-08 | 5 | -11/+17 | |
* | Install the rtems-test command. | Chris Johns | 2015-02-08 | 5 | -12/+62 | |
| | | | | | | | This installs the Python RTEMS Toolkit. The copmiler has been switched from forcing gcc to allowing waf to detect the host's tool chain. | |||||
* | Fix covoar so it builds for Windows. | Chris Johns | 2015-01-20 | 3 | -25/+36 | |
* | typo | Ben Gras | 2014-11-02 | 1 | -1/+1 | |
* | Add new OpenRISC/or1ksim BSP script using qemu | Hesham ALMatary | 2014-09-29 | 1 | -0/+53 | |
* | waf: Include waf in the souce tree and updated README on building. | Chris Johns | 2014-09-13 | 2 | -6/+50 | |
| | | | | Add support to build all parts of The RTEMS Tools project. | |||||
* | covoar: Merger the covoar source from rtems-testing.git. | Chris Johns | 2014-06-18 | 99 | -0/+16751 | |
| | | | | Use waf to build covoar. | |||||
* | config: Fix the name for the xilinx_zynq_a9_qemu bsp. | Chris Johns | 2014-06-01 | 1 | -1/+1 | |
* | config: Add support for the gdbarmsim for the arm920 BSP. | Chris Johns | 2014-06-01 | 1 | -0/+56 | |
* | config: Clean up the qemu configurations. | Chris Johns | 2014-06-01 | 5 | -15/+72 | |
* | test: Strengthen the timeout handling by killing the process. | Chris Johns | 2014-06-01 | 1 | -2/+8 | |
* | tester: Correctly handle contro-c. | Chris Johns | 2014-05-31 | 3 | -17/+75 | |
| | | | | Add support to kill running tests if the user presses control-c. | |||||
* | Add jmr3904 GDB simulator support | Joel Sherrill | 2014-05-14 | 2 | -0/+110 | |
* | add --filter to specify the set of selected tests. | Ben Gras | 2014-05-09 | 1 | -3/+12 | |
| | | | | | | | | . parameter is a glob . default is *.exe as it was . it is a convenient way to select a particular test to run over and over again while debugging it, without laboriously manipulating the .exe's that are present (i.e. moving/deleting them) | |||||
* | bsp: Clean up the BBxM BSP configuration. | Chris Johns | 2014-04-29 | 1 | -4/+5 | |
* | bsp: Break on the terminate halt to get fatal handlers run. | Chris Johns | 2014-04-29 | 1 | -1/+1 | |
* | bsp: Add Beagleboard xM support. | Chris Johns | 2014-04-29 | 1 | -0/+61 | |
* | tester: Fix the psim script. | Chris Johns | 2014-04-10 | 1 | -1/+1 | |
* | bsp: Add psim. | Chris Johns | 2014-03-26 | 3 | -0/+139 | |
* | tester: The process returns an exit code not an errno. | Chris Johns | 2014-03-26 | 1 | -1/+1 | |
* | rt: Add the rtems-tester. | Chris Johns | 2014-02-15 | 30 | -0/+4199 | |
