* | tester: Add support for test-too-long | Chris Johns | 2020-09-08 | 8 | -57/+348 |
| | | | | | - A test that loops generating output did not timeout. Monitor the the session time and set a maximum test period. | ||||
* | tester: Fix the install with the new TFTP server | Chris Johns | 2020-09-07 | 2 | -15/+8 |
* | tester: Fix TFTP server Python2 issues. | Chris Johns | 2020-09-07 | 1 | -4/+28 |
| | | | | | | | - Add a --show-backtrace option to make it easier for users to get an exception backtrace if something goes wrong. - Fix the --packet-trace option so it actually decodes the packets | ||||
* | tester: Change to a simpler TFTP server | Chris Johns | 2020-09-01 | 13 | -2193/+766 |
| | | | | | | | | - Add a simpler TFTP to allow parallel test hardware - Remove the imported tftpy server Closes #4063 | ||||
* | Change version to RTEMS 6 | Sebastian Huber | 2020-06-30 | 1 | -1/+1 |
| | | | | Update #4020. | ||||
* | rtems-test: target_exe_filter fails when there is no filter5.1 | Chris Johns | 2020-06-17 | 2 | -0/+3 |
| | | | | Closes #4006 | ||||
* | rtems-tester: Add rv64imafdc_medany for QEMU | Hesham Almatary | 2020-04-09 | 1 | -0/+36 |
* | bsps: Deletes erc32-run.ini | Cláudio Maia | 2020-04-05 | 1 | -38/+0 |
* | tester: Add configuration pc-qemu.ini | Jan Sommer | 2020-04-03 | 1 | -0/+39 |
* | tester/gdb: Add lock timing and remote fetching registers. | Chris Johns | 2020-03-30 | 1 | -3/+6 |
| | | | | | | | - Add timing for the locks to aid performance profiling - Remove fetching registers as the MI parser is slow on pyton2 Updates #3864 | ||||
* | gdbarmsim: Remove all variants | Joel Sherrill | 2020-03-20 | 10 | -400/+0 |
| | | | | Updates #3911. | ||||
* | Improve Python 3 compatibility | Sebastian Huber | 2020-03-17 | 1 | -1/+1 |
* | psim-device-tree: Rework so devices do not conflict with 256MB RAM | Joel Sherrill | 2020-03-05 | 1 | -18/+18 |
| | | | | closes #3849. | ||||
* | tester: Use prefix for rtems_tools by default | Sebastian Huber | 2020-02-26 | 1 | -0/+2 |
| | | | | | | | | | | Commit 72c684eff2cd932b4948e21902680a93473340c3 removed the default value of rtems_tools. If the --rtems--tools option was omitted the rtems-test command printed lots of error: run.cfg:61: macro '%{rtems_tools}' not found error messages. | ||||
* | Fix typo in error message | Cláudio Maia | 2020-02-26 | 1 | -1/+1 |
* | tester: Add qemu_opts_serial | Sebastian Huber | 2020-02-25 | 7 | -8/+9 |
| | | | | | | The realview_pbx_a9_qemu test configuration for Qemu produced no output due to wrong serial/monitor settings. Remove the serial/monitor settings from qemu_opts_base and move them to the new qemu_opts_serial. | ||||
* | covoar/wscript: Install covoar.css and table.js | Vijay Kumar Banerjee | 2020-01-28 | 1 | -0/+1 |
* | tester: Prefer '_' as test state separator char | Sebastian Huber | 2019-12-19 | 1 | -9/+11 |
* | tester: Add basic support to generate JUnit test reports | Hesham Almatary | 2019-11-22 | 1 | -1/+51 |
* | Fix exception when no output format is specified | Kinsey Moore | 2019-09-24 | 1 | -0/+2 |
| | | | | | The JSON log generation patch introduced a bug when the report output generation was not configured due to attempting to iterate over 'None'. | ||||
* | bsp-builder: Do not clean the build space when starting with --no-clean | Chris Johns | 2019-09-05 | 1 | -1/+1 |
* | tester: Minor fix to prefix handling. | Chris Johns | 2019-09-05 | 1 | -3/+1 |
* | tester/tftp: Handle ctl-C when active. | Chris Johns | 2019-09-05 | 1 | -7/+12 |
* | Add JSON log generation | Kinsey Moore | 2019-08-22 | 1 | -13/+111 |
| | | | | | Add log formatter hooks and JSON log formatter to the test infrastructure for consumption by automated processes or report generators. | ||||
* | tester: Add raspberrypi2 BSP. | Chris Johns | 2019-07-26 | 1 | -0/+43 |
* | waf: Update the check_cc tests to a newer method supported by waf. | Chris Johns | 2019-05-27 | 2 | -3/+11 |
| | | | | - Fix a minor issue in covoar's use of 64bit calls. | ||||
* | rtemstoolkit/path : Add listdir function | Vijay Kumar Banerjee | 2019-05-21 | 1 | -2/+2 |
* | coverage: Add subdirectory name in HTML reports | Vijay Kumar Banerjee | 2019-03-27 | 1 | -0/+18 |
* | coverage: remove utf-8 encoding in symbolset names | Vijay Kumar Banerjee | 2019-03-22 | 1 | -2/+1 |
* | testing/bsps: Add covoar commands in bsp ini file | Vijay Kumar Banerjee | 2019-02-19 | 2 | -6/+8 |
* | Coverage: Add support for TSIM format | Vijay Kumar Banerjee | 2019-02-14 | 3 | -18/+33 |
* | Coverage : Add coverage support for RISCV | Vijay Kumar Banerjee | 2019-02-12 | 5 | -1/+222 |
* | tester: Ignore the execute return code for some commands | Chris Johns | 2019-02-08 | 2 | -6/+7 |
| | | | | | Some simulators like psim-run return a non-zero error code. Allow a BSP configuration to ignore the return code. | ||||
* | rtemstoolkit/config: Unlock when printing to avoid blocking. | Chris Johns | 2019-02-08 | 1 | -1/+10 |
* | tester/check: Convert the indent size to an int. | Chris Johns | 2019-02-08 | 1 | -1/+1 |
* | tester: Increase the psim memory size to match the BSP. | Chris Johns | 2019-02-08 | 1 | -1/+1 |
* | rtems-test: add bsp for leon3 on sis with coverage | Jiri Gaisler | 2019-01-25 | 1 | -0/+39 |
* | covoar: wrong symbol length in coverage map | Jiri Gaisler | 2019-01-25 | 2 | -2/+2 |
* | covoar: enable -f switch to select other coverage formats | Jiri Gaisler | 2019-01-25 | 1 | -1/+2 |
* | covoar: debug print-out of addresses should be in hex | Jiri Gaisler | 2019-01-25 | 1 | -0/+1 |
* | rtems-tester: added griscv bsps for gdb and sis | Jiri Gaisler | 2019-01-22 | 2 | -0/+80 |
* | rtems-test: Fix qemu coverage logic errors. | Chris Johns | 2019-01-09 | 1 | -4/+4 |
* | tester: Run leon3-sis with four processors | Jiri Gaisler | 2018-12-17 | 1 | -1/+1 |
| | | | | Update #3460. | ||||
* | tester: Fix leon2.ini | Sebastian Huber | 2018-12-17 | 1 | -1/+1 |
* | tester : Add support to use QEMU serial console when coverage is enabled | Vijay Kumar Banerjee | 2018-12-02 | 2 | -7/+11 |
* | tester/coverage: Remove warnings in covoar on Windows. | Chris Johns | 2018-11-29 | 3 | -76/+65 |
* | Coverage : install covoar in tester/bin | Vijay Kumar Banerjee | 2018-11-27 | 3 | -5/+11 |
* | tester/tftpd: Set the socket option to reuse. | Chris Johns | 2018-11-27 | 1 | -0/+8 |
* | tester: Fix the handling of the version and tools recs when running parallel ↵ | Chris Johns | 2018-11-27 | 2 | -118/+128 |
| | | | | jobs | ||||
* | tester/gdb: mi_parser, fix on Python3 and remove globals | Chris Johns | 2018-11-26 | 3 | -50/+61 |
| | | | | | | | | - Fix mi_parser on Python3. Python3 does not support the __cmp__ operator and rich comparision operators are required, See PEP 207. - Remove the global variables and make a class containing them. Update the gdb class to use the mi_parser session class. Removing the globals means the global lock in the gdb module can be removed. |
