2021-11-30 | TraceConverter.cc: Add final catch for exceptions | Ryan Long | 1 | -3/+13 | |
CID 1471639: Add catch for exception Closes #4501 | |||||
2021-11-04 | TraceConverter.cc: Add catch for exception | Ryan Long | 1 | -4/+18 | |
2021-10-29 | rtems-bsp-builder: Fix mail support | Alex White | 1 | -1/+16 | |
This fixes a problem with mailer options support that occurred because check.py uses argparse.ArgumentParser instead of tester.rt.options. | |||||
2021-10-13 | TraceConverter.cc: Add catch for exception | Ryan Long | 1 | -16/+29 | |
2021-10-13 | tester: Fix rtems-test installation | Sebastian Huber | 1 | -1/+2 | |
2021-10-13 | tester: Add realview_pbx_a9_qemu_smp configuration | Sebastian Huber | 1 | -0/+38 | |
Add a configuration for the arm/realview_pbx_a9_qemu BSP to run the tests if it was built with SMP support enabled. | |||||
2021-10-08 | TraceConverter.cc: Add catch for exception | Ryan Long | 1 | -7/+21 | |
CID 1471639: Uncaught exception Closes #4501 | |||||
2021-10-07 | ReportsBase.cc: Add assert for member variables | Ryan Long | 1 | -0/+5 | |
The uncoveredRanges and uncoveredBranch member variables are allocated as a pair. They are both either NULL or not NULL. Coverity does not know this though, so this assert is added to ensure they are not NULL before being dereferenced. CID 1503710: Dereference after null check Closes #4428 | |||||
2021-09-28 | TraceWriterQEMU.h: Fix formatting | Ryan Long | 1 | -3/+3 | |
2021-09-28 | TraceReaderLogQEMU.h: Fix formatting | Ryan Long | 1 | -1/+0 | |
2021-09-28 | TraceWriterQEMU.cc: Fix formatting | Ryan Long | 1 | -20/+26 | |
2021-09-28 | TraceReaderLogQEMU.cc: Fix formatting | Ryan Long | 1 | -8/+7 | |
2021-09-28 | TraceWriter: Convert to C++ | Ryan Long | 3 | -27/+16 | |
2021-09-28 | TraceReader: Convert to C++ | Ryan Long | 8 | -86/+68 | |
2021-09-28 | CoverageRanges.cc: Fix formatting | Ryan Long | 2 | -14/+12 | |
2021-09-27 | GcovFunctionData.cc: Initialize member variables | Ryan Long | 1 | -3/+7 | |
CID 1399640: Uninitialized pointer field Closes #4432 | |||||
2021-09-27 | DesiredSymbols.h: Initialize symbolInfo | Ryan Long | 1 | -0/+1 | |
CID 1399627: Uninitialized pointer field Closes #4433 | |||||
2021-09-27 | TraceWriterQEMU.cc: Initialize header._pad | Ryan Long | 1 | -0/+1 | |
CID 1506204: Uninitialized scalar variable Closes #4488 | |||||
2021-09-27 | TraceWriterQEMU.cc: Change strncpy to memcpy | Ryan Long | 1 | -1/+3 | |
CID 1506207: Buffer not null terminated Closes #4491 | |||||
2021-09-21 | tester/mvme2307: Add support for the MVME2307 (MVME2700) BSP | Chris Johns | 1 | -0/+59 | |
- Assumes a stand alone TFTP server | |||||
2021-09-21 | tester/wait: Add a wait directive to the tester | Chris Johns | 3 | -2/+233 | |
- Lets you test with stand alone TFTP or other services | |||||
2021-09-21 | tester/exe: Adjust timeouts by the step size | Chris Johns | 1 | -3/+3 | |
2021-09-19 | tester/tftp: Fix recovery of timed out TFTP sessions | Chris Johns | 6 | -59/+184 | |
- Add support to retry the tftp session if the target has not started - Add target handlers for the test directives to allow recovery on error | |||||
2021-09-19 | tester: Simplify the console data handling | Chris Johns | 1 | -7/+4 | |
2021-09-15 | check.py: Fix incorrect use of os.linesep | Ryan Long | 1 | -2/+2 | |
Replaced a couple of calls to os.linesep() with os.linesep because os.linesep() does not exist. | |||||
2021-09-14 | tester: Add MicroBlaze KCU105 QEMU BSP | Alex White | 2 | -1/+42 | |
2021-09-13 | CoverageWriterTSIM.h: Fix formatting | Ryan Long | 1 | -3/+3 | |
2021-09-13 | CoverageWriterTSIM.cc: Fix formatting | Ryan Long | 1 | -11/+11 | |
2021-09-13 | CoverageWriterSkyeye.h: Fix formatting | Ryan Long | 1 | -3/+3 | |
2021-09-13 | CoverageWriterSkyeye.cc: Fix formatting | Ryan Long | 1 | -5/+5 | |
2021-09-13 | CoverageWriterRTEMS.h: Fix formatting | Ryan Long | 1 | -3/+3 | |
2021-09-13 | CoverageWriterRTEMS.cc: Fix formatting | Ryan Long | 1 | -12/+11 | |
2021-09-13 | covoar.cc: Fix formatting | Ryan Long | 1 | -133/+167 | |
2021-09-13 | CoverageWriterBase.h: Fix formatting | Ryan Long | 1 | -3/+3 | |
2021-09-13 | covoar.cc: Convert to C++ | Ryan Long | 1 | -27/+23 | |
Got rid of C-strings, changed FILE pointer to ifstream. | |||||
2021-09-13 | CoverageWriter: Convert to C++ | Ryan Long | 7 | -45/+59 | |
2021-09-09 | tester/zynqmp: Simpify the reasons to reset | Chris Johns | 2 | -2/+3 | |
- Only reset if the bootloader error is hardware related. | |||||
2021-09-09 | tester/tftp: Fix prptocol timeout handling | Chris Johns | 2 | -15/+15 | |
- Change some of the notification messages | |||||
2021-09-09 | tester: Count tester header errors | Chris Johns | 3 | -12/+29 | |
- Remove the hard tester error and count the header errors. | |||||
2021-09-09 | tester/telnet: Only reopen once a second | Chris Johns | 1 | -1/+9 | |
- Limit the reopen to once a second - Make sure the socket is closed when reopening | |||||
2021-09-09 | tester/zynqmp: Limit the restarts to 3 | Chris Johns | 1 | -0/+1 | |
2021-09-07 | CoverageReaderTSIM.cc: Fix formatting | Ryan Long | 1 | -4/+6 | |
2021-09-07 | CoverageReaderSkyeye.cc: Fix formatting | Ryan Long | 1 | -9/+12 | |
2021-09-07 | CoverageReaderRTEMS.cc: Fix formatting | Ryan Long | 1 | -13/+13 | |
2021-09-07 | CoverageReaderQEMU.cc: Fix formatting | Ryan Long | 1 | -11/+11 | |
2021-09-07 | CoverageMapBase.h: Fix formatting | Ryan Long | 1 | -21/+45 | |
2021-09-07 | CoverageFactory.h: Fix formatting | Ryan Long | 1 | -9/+3 | |
2021-09-07 | CoverageMapBase.cc: Fix formatting | Ryan Long | 1 | -102/+159 | |
2021-09-07 | CoverageFactory.cc: Fix formatting | Ryan Long | 1 | -6/+10 | |
2021-09-07 | CoverageReader: Convert to C++ | Ryan Long | 11 | -68/+54 | |
