* | coverage/symbol-sets.ini : Add libtrace | Alex White | 2021-03-30 | 1 | -1/+2 |
* | tester: Add coverage variants for a few BSPs | Alex White | 2021-03-30 | 4 | -0/+161 |
| | | | | | Adds coverage variants for the following BSPs: a53_qemu, pc686, xilinx_zynq_a9_qemu, and xilinx_zynqmp. | ||||
* | tester: Remove target from BSP coverage configs | Alex White | 2021-03-30 | 3 | -3/+0 |
* | tester: Update to support new build system | Alex White | 2021-03-30 | 1 | -45/+46 |
| | | | | | | The tester configurations had not been updated to match the paths and conventions used by the new build system. These have been updated, and a few more libraries have been enabled in symbol-sets.ini. | ||||
* | bsps/sparc: Remove INI files using SIS in GDB | Ryan Long | 2021-03-23 | 3 | -123/+0 |
| | | | | | | | | Removed the INI files that use the "target sim" option since the SIS sparc simulator in GDB is no longer used with RTEMS. A newer version of SIS is built separately. Closes #4355 | ||||
* | tester: Update for ZynqMP QEMU BSP name change | Kinsey Moore | 2021-03-05 | 2 | -6/+6 |
| | | | | | The ZynqMP QEMU BSPs were renamed to include _qemu for more consistent identification. This updates the tester configurations to match. | ||||
* | tester: Swap Xilinx ZynqMP BSPs to secondary UART | Kinsey Moore | 2021-01-14 | 2 | -2/+2 |
| | | | | | | | Qemu's machine definition uses the second UART in the memory map as the primary UART. This follows from the hardware itself where the second UART in the memory map is UART 0. This switches the tester to using the correct UART. | ||||
* | tester: Add support for arm/fvp_cortex_r52 BSP | Sebastian Huber | 2020-12-16 | 3 | -0/+114 |
| | | | | Update #4202. | ||||
* | tester: Add configs for AArch64 ZynqMP BSPs | Kinsey Moore | 2020-12-11 | 2 | -0/+76 |
* | tester: Add support for sparc/gr740 BSP | Sebastian Huber | 2020-12-02 | 1 | -0/+38 |
| | | | | Update #4195. | ||||
* | bsps/a53_*: Fix typo in qemu options | Vijay Kumar Banerjee | 2020-11-15 | 2 | -2/+2 |
* | tester: Add a53_ilp32_qemu.ini | Kinsey Moore | 2020-10-05 | 1 | -0/+38 |
* | tester: Add a53_lp64_qemu.ini | Kinsey Moore | 2020-10-05 | 1 | -0/+38 |
* | tester: Add support for test-too-long | Chris Johns | 2020-09-08 | 1 | -1/+2 |
| | | | | | - A test that loops generating output did not timeout. Monitor the the session time and set a maximum test period. | ||||
* | Change version to RTEMS 6 | Sebastian Huber | 2020-06-30 | 1 | -1/+1 |
| | | | | Update #4020. | ||||
* | rtems-tester: Add rv64imafdc_medany for QEMU | Hesham Almatary | 2020-04-09 | 1 | -0/+36 |
* | bsps: Deletes erc32-run.ini | Cláudio Maia | 2020-04-05 | 1 | -38/+0 |
* | tester: Add configuration pc-qemu.ini | Jan Sommer | 2020-04-03 | 1 | -0/+39 |
* | gdbarmsim: Remove all variants | Joel Sherrill | 2020-03-20 | 10 | -400/+0 |
| | | | | Updates #3911. | ||||
* | psim-device-tree: Rework so devices do not conflict with 256MB RAM | Joel Sherrill | 2020-03-05 | 1 | -18/+18 |
| | | | | closes #3849. | ||||
* | tester: Add qemu_opts_serial | Sebastian Huber | 2020-02-25 | 7 | -8/+9 |
| | | | | | | The realview_pbx_a9_qemu test configuration for Qemu produced no output due to wrong serial/monitor settings. Remove the serial/monitor settings from qemu_opts_base and move them to the new qemu_opts_serial. | ||||
* | tester: Add raspberrypi2 BSP. | Chris Johns | 2019-07-26 | 1 | -0/+43 |
* | testing/bsps: Add covoar commands in bsp ini file | Vijay Kumar Banerjee | 2019-02-19 | 2 | -6/+8 |
* | Coverage: Add support for TSIM format | Vijay Kumar Banerjee | 2019-02-14 | 2 | -5/+11 |
* | Coverage : Add coverage support for RISCV | Vijay Kumar Banerjee | 2019-02-12 | 1 | -0/+40 |
* | tester: Ignore the execute return code for some commands | Chris Johns | 2019-02-08 | 1 | -5/+6 |
| | | | | | Some simulators like psim-run return a non-zero error code. Allow a BSP configuration to ignore the return code. | ||||
* | tester: Increase the psim memory size to match the BSP. | Chris Johns | 2019-02-08 | 1 | -1/+1 |
* | rtems-test: add bsp for leon3 on sis with coverage | Jiri Gaisler | 2019-01-25 | 1 | -0/+39 |
* | rtems-tester: added griscv bsps for gdb and sis | Jiri Gaisler | 2019-01-22 | 2 | -0/+80 |
* | rtems-test: Fix qemu coverage logic errors. | Chris Johns | 2019-01-09 | 1 | -4/+4 |
* | tester: Run leon3-sis with four processors | Jiri Gaisler | 2018-12-17 | 1 | -1/+1 |
| | | | | Update #3460. | ||||
* | tester: Fix leon2.ini | Sebastian Huber | 2018-12-17 | 1 | -1/+1 |
* | tester : Add support to use QEMU serial console when coverage is enabled | Vijay Kumar Banerjee | 2018-12-02 | 1 | -7/+10 |
* | tester: Change the QEMU command line to match the RSB built QEMU. | Chris Johns | 2018-11-23 | 1 | -2/+5 |
| | | | | | The command line changed and the RSB is the newer version. Make the old version via a config variable. | ||||
* | tester: Remove riscv_generic | Hesham Almatary | 2018-11-12 | 3 | -129/+0 |
| | | | | Now each BSP/ISA variant has its own .ini file | ||||
* | Remove m32c support | Sebastian Huber | 2018-11-12 | 2 | -80/+0 |
| | | | | Update #3599. | ||||
* | tester: Support testing all riscv bsps on Spike | Hesham Almatary | 2018-11-09 | 13 | -0/+494 |
* | Coverage : Generate reports using the object files in cpukit | Vijay Kumar Banerjee | 2018-10-25 | 1 | -45/+45 |
* | config: Create a config directory and move the RTEMS arch/bsp data to it. | Chris Johns | 2018-10-02 | 21 | -896/+0 |
| | | | | Closes #3536 | ||||
* | tester/bsp-builder: No network builds for the epiphany BSP. | Chris Johns | 2018-09-04 | 1 | -1/+1 |
* | coverage/symbol-sets.ini : Add symbol-sets and paths to respective libraries | Vijay Kumar Banerjee | 2018-08-08 | 1 | -3/+45 |
* | tester: Exclude SMP build of some RISC-V BSPs | Sebastian Huber | 2018-08-07 | 1 | -0/+1 |
| | | | | | | | It makes no sense to build BSPs without support for atomic instructions with SMP enabled. Update #3433. | ||||
* | tester: Add RISC-V support to BSP builder | Sebastian Huber | 2018-08-06 | 2 | -0/+29 |
* | tester: Add use virt machine for rv64imafd_medany | Sebastian Huber | 2018-07-25 | 1 | -1/+1 |
* | rtems-bsps-tiers.ini: Add amd64 | Joel Sherrill | 2018-07-18 | 1 | -0/+1 |
* | tester: Remove obsolete BSP variants | Sebastian Huber | 2018-07-03 | 2 | -6/+4 |
| | | | | Update #3459. | ||||
* | tester: Add rv64imafd_medany.ini | Sebastian Huber | 2018-06-29 | 1 | -0/+35 |
* | tester: Make leon3-run command use run and not sis. | Chris Johns | 2018-06-18 | 1 | -2/+2 |
* | tester: Add script to generate html coverage report from covoar output | Vijay Kumar Banerjee | 2018-06-05 | 3 | -3/+40 |
| | | | | | | | Add support in tester to run covoar and generate an html report to display the summary of the coverage reports generated from covoar. Co-authored-by : Cillian O'Donnell <cpodonnell8@gmail.com> | ||||
* | rtems-bsps-epiphany.ini: Correct spelling of ephiphany_sim | Joel Sherrill | 2018-06-05 | 1 | -1/+1 |
