* | qemu.cfg: Options changed to capture test output | Ric Claus | 2015-09-26 | 1 | -1/+2 |
* | xilinx_zynq_a9_qemu_smp.mc: Change realview_pbx_a9_qemu reference to ↵ | Ric Claus | 2015-09-26 | 1 | -1/+1 |
| | | | | xilinx_zynq_a9_qemu. | ||||
* | Rename or1ksim BSP to generic_or1k | Hesham ALMatary | 2015-04-19 | 1 | -6/+6 |
* | bf537Stamp: Add configuration files | Joel Sherrill | 2015-04-14 | 2 | -0/+110 |
* | leon3-tsim*: First attempt at LEON3 on tsim support | Joel Sherrill | 2015-04-05 | 3 | -0/+113 |
| | | | | | | The rtems-tester does not thing the tests run correctly because the test output is coming to the terminal window with tsim running in it. | ||||
* | lm32_evr_gdbsim: Add configuration files | Joel Sherrill | 2015-04-05 | 3 | -0/+118 |
* | psim*.mc: Fix typo | Joel Sherrill | 2015-04-04 | 2 | -2/+2 |
* | Add configurations for erc32, leon2, and leon3 in GDB SIS | Joel Sherrill | 2015-03-29 | 6 | -0/+330 |
| | | | | | | These require a GDB >= 7.9 with Jiri Gaisler's patches applied. These are currently in the RSB and are in the process of being merged by the GDB project. | ||||
* | Add rtems-tester configurations for simsh family of BSPs | Joel Sherrill | 2015-03-26 | 8 | -0/+440 |
* | Add configurations for all h8 GDB simulator BSP variants | Joel Sherrill | 2015-03-12 | 4 | -0/+220 |
* | Add configurations for all arm GDB simulator BSP variants | Joel Sherrill | 2015-03-12 | 10 | -9/+503 |
* | Add configuration for m32csim BSP for simulator in GDB | Joel Sherrill | 2015-03-12 | 2 | -0/+110 |
* | Add configuration for m32rsim BSP for simulator in GDB | Joel Sherrill | 2015-03-12 | 2 | -0/+110 |
* | Add configurations for all v850 GDB simulator BSP variants | Joel Sherrill | 2015-03-12 | 12 | -0/+660 |
* | Fixes to the run the waf built tests when installed. | Chris Johns | 2015-02-08 | 1 | -2/+2 |
* | Install the rtems-test command. | Chris Johns | 2015-02-08 | 1 | -1/+0 |
| | | | | | | | This installs the Python RTEMS Toolkit. The copmiler has been switched from forcing gcc to allowing waf to detect the host's tool chain. | ||||
* | Add new OpenRISC/or1ksim BSP script using qemu | Hesham ALMatary | 2014-09-29 | 1 | -0/+53 |
* | config: Fix the name for the xilinx_zynq_a9_qemu bsp. | Chris Johns | 2014-06-01 | 1 | -1/+1 |
* | config: Add support for the gdbarmsim for the arm920 BSP. | Chris Johns | 2014-06-01 | 1 | -0/+56 |
* | config: Clean up the qemu configurations. | Chris Johns | 2014-06-01 | 5 | -15/+72 |
* | Add jmr3904 GDB simulator support | Joel Sherrill | 2014-05-14 | 2 | -0/+110 |
* | bsp: Clean up the BBxM BSP configuration. | Chris Johns | 2014-04-29 | 1 | -4/+5 |
* | bsp: Break on the terminate halt to get fatal handlers run. | Chris Johns | 2014-04-29 | 1 | -1/+1 |
* | bsp: Add Beagleboard xM support. | Chris Johns | 2014-04-29 | 1 | -0/+61 |
* | tester: Fix the psim script. | Chris Johns | 2014-04-10 | 1 | -1/+1 |
* | bsp: Add psim. | Chris Johns | 2014-03-26 | 3 | -0/+139 |
* | rt: Add the rtems-tester. | Chris Johns | 2014-02-15 | 14 | -0/+869 |
