* | Move all python commands to use env python | Chris Johns | 2020-09-26 | 1 | -7/+5 |
| | | | | | | | | - If you host does not provide a python command consult the User manual for ways you can run the python commands. - Full package paths are being used to avoid namespace pollution and crosstalk. | ||||
* | tester: Fix the install with the new TFTP server | Chris Johns | 2020-09-07 | 1 | -2/+4 |
* | tester: Change to a simpler TFTP server | Chris Johns | 2020-09-01 | 1 | -0/+45 |
- Add a simpler TFTP to allow parallel test hardware - Remove the imported tftpy server Closes #4063 |
