- Removed BranchInfoAvailable from app_common
- Created member variable in CoverageReaderBase and ReportsBase and a function
to get the value of the member variable
- Removed SymbolsToAnalyze from app_common and replaced it with the
symbolsToAnalyze_m member variable in DesiredSymbols, GcovData, and
ObjdumpProcessor
- Added a parameter to constructors to initialize symbolsToAnalyze_m
- Moved the definition of objdumpLine_t out of ObjdumpProcessor to make
it work with DesiredSymbols
- Replaced outputDirectory in app_common with a local variable in
covoar()
- Created the outputDirectory_m member variable
- Added parameters to Reports* constructors to initialize
outputDirectory_m and non member functions
- Replaced projectName in app_common with a local variable in covoar()
- Changed datatype to string
- Changed conditionals to reflect this
- Created projectName_m member variable for ReportsBase
- Added parameter to Reports* constructors to initialize projectName_m
- Replaced AllExplanations in app_common with a local variable in covoar()
- Added the allExplanations_m member variable to ReportsBase
- Added a parameter to ReportsBase and its derived classes' constructors
to initialize allExplanations_m
- Added parameter to GenerateReports() to pass the variable from
covoar() to the constructors for Reports*
Some of the loops in the ReportsBase::Write* methods contained both
regular and range-based for loops. This changes them to use only range-
based for loops.
Closes #4374
This changes the way covoar organizes the symbols. Instead of treating
all symbols as one set, covoar is now aware of multiple symbol sets and
tracks statistics for each set. It now also generates reports for each
symbol set.
This change relieves the caller of covoar of the reponsibility of
managing the symbol sets. As a result, covoar can minimize the work
done for each symbol set, yielding a significant speedup.
Updates #4374
Use waf to build covoar.
