This can be used by applications to filter the symbols by type.
Note, ARM destructors are registered at runtime and currently not
easly found.
Update libiberty to get a newer demangler.
Closes #3102.
Show user friendly labels for the C++ constructors and destructors.
This is useful if you need to look up a symbol based on its address.
This change adds support to the rtems-syms code to generate a suitable
ELF object you can link to the base image kernel in the embed mode or
you can load with the run-time load mode.
The change fixes a bug in the framework where local ELF symbols
were being placed in the external symbol table. The external
symbol table has been removed and a global, weak and local set
of tables is now provided as this is more aligned with the ELF
format.
