* | rtemstoolkit: Detect native SPARCV9 ELF arch | Sebastian Huber | 2020-03-05 | 1 | -0/+2 |
* | fix native elf detection on x86_64 machines | Christian Spindeldreier | 2018-11-27 | 1 | -1/+1 |
| | | | | Closes #3616 | ||||
* | rtemstoolkit: Add ARM and AArch64 support to Linux elftoolchain. | Chris Johns | 2018-11-15 | 1 | -1/+5 |
* | rtemstoolkit: Add DWARF function support. | Chris Johns | 2018-06-18 | 1 | -1/+4 |
| | | | | Load the functions in each CU. | ||||
* | elftoolchain: Add libelftc. | Chris Johns | 2018-06-18 | 30 | -0/+10521 |
* | _elftc.h: Make compile on Cygwin | Joel Sherrill | 2018-04-30 | 1 | -1/+1 |
* | rtemstoolkit: Add libdwarf from elftoolchain. | Chris Johns | 2018-04-30 | 198 | -0/+36456 |
| | | | | | | | | The code is taken from: https://svn.code.sf.net/p/elftoolchain/code/trunk Update #3417 | ||||
* | rtemstoolkit: Update elftoolchain to the latest code. | Chris Johns | 2018-04-30 | 82 | -1099/+2564 |
| | | | | | | | | The update is taken from: https://svn.code.sf.net/p/elftoolchain/code/trunk Update #3417 | ||||
* | Revert "rtemstoolkit: Update elftoolchain to the latest code." | Chris Johns | 2018-04-30 | 120 | -306/+434 |
| | | | | This reverts commit 0c5db2dd13b8270bb80c497d5f53ae2471f8a819. | ||||
* | rtemstoolkit: Update elftoolchain to the latest code. | Chris Johns | 2018-04-29 | 120 | -434/+306 |
| | | | | | | The update is taken from https://github.com/elftoolchain/elftoolchain. Update #3417 | ||||
* | libelf: Use minimal environment for C translation with readelf. | Chris Johns | 2017-01-09 | 1 | -2/+1 |
| | | | | The output of readelf needs to be in English. | ||||
* | Fix Windows build issues. | Chris Johns | 2015-10-19 | 1 | -1/+2 |
| | | | | | Fix biulding the mmap Windows code. Fix installing the files for Windows. | ||||
* | rtemstoolkit: Remove warning on Windows. | Chris Johns | 2015-03-18 | 1 | -9/+9 |
* | elftoolchain: Add support for Cygwin. | Chris Johns | 2015-03-17 | 1 | -3/+3 |
* | Refactor code into the RTEMS Toolkit. | Chris Johns | 2014-09-13 | 119 | -0/+20534 |
