* | misc/tftprpoxy: Correctly scale the protocol timeout | Chris Johns | 2021-09-09 | 1 | -6/+7 |
| | | | | | | - Fix data decoding - Fix get MAC call | ||||
* | misc/wscript: Specify C language version | Joel Sherrill | 2021-04-02 | 1 | -1/+2 |
| | | | | | CentOS 7 has gcc 4.8 which defaults to C90 and this results in warnings for code that is valid C99 but not C90. | ||||
* | rtems-bin2c.c: Define _XOPEN_SOURCE to 700 for strnlen() visibility | Joel Sherrill | 2021-04-02 | 1 | -0/+1 |
* | misc: tools: fix mkimage.py script type processing | Andre Nahrwold | 2021-02-16 | 1 | -0/+10 |
* | Move all python commands to use env python | Chris Johns | 2020-09-26 | 7 | -68/+46 |
| | | | | | | | | - If you host does not provide a python command consult the User manual for ways you can run the python commands. - Full package paths are being used to avoid namespace pollution and crosstalk. | ||||
* | Move mkimage.py to install_files so chmod is preserved and installed in bin/ | Amar Takhar | 2020-03-07 | 1 | -2/+2 |
* | Add print statement similar to the original mkimage. | Amar Takhar | 2020-03-04 | 1 | -2/+15 |
| | | | | This is limited to Python 2.6+ | ||||
* | Fix to work under Pyhon 2 and Python 3. | Amar Takhar | 2020-03-04 | 1 | -9/+9 |
| | | | | Also changed 'python2' to 'python' in the shebang. | ||||
* | Convert optparse to argparse. | Amar Takhar | 2020-03-04 | 1 | -20/+22 |
| | | | | | * Fix exceptions and print exception message. * Also add myself to copyright. | ||||
* | Remove EOL whitespace. | Amar Takhar | 2020-03-04 | 1 | -21/+21 |
* | Add to wscript and add python2 shebang. | Amar Takhar | 2020-03-03 | 2 | -0/+3 |
| | | | | | This script does work but needs some user friendliness added which is acknowledged by the author as it was meant as a quick replacement. | ||||
* | Add a pure Python clone of mkimage written by Craig Barker. | Amar Takhar | 2020-03-03 | 1 | -0/+139 |
| | | | | | | | | | I emailed Craig Barker to ask if he would release his mkimage Python rewrite as 2BSD. He graciously accepted and you can see his work here: https://github.com/cmbarker83/pythonmkimage This is a verbatim commit of 35d6d from his repository. | ||||
* | bin2c: Improve file name sanitation | Sebastian Huber | 2019-12-02 | 1 | -12/+12 |
| | | | | Only use alpha-numeric characters for header guards. | ||||
* | misc/tftpproxy: Add a proxy TFTP server. | Chris Johns | 2019-08-19 | 8 | -2/+1209 |
| | | | | | | | | | | - Uses a config INI file to map clients to servers - Handle a number of requests to a single server's TFTP port (69) and multiplex to a non-su ports or different servers. - Supports running rtems-test to more than one hardware device using TFTP at once. | ||||
* | misc/boot-image: fix uenv_exe_ftd bug. | Nils Hölscher | 2019-06-25 | 1 | -1/+1 |
* | misc/boot-image: Fix Linux bugs. | Chris Johns | 2019-06-13 | 1 | -12/+15 |
* | misc/boot-image: Fix image convert. Add --build option. | Chris Johns | 2019-06-13 | 1 | -16/+21 |
| | | | | | - Change the build directory away from `build`, avoid the tool wiping out a libbsd build directory. | ||||
* | misc/boot-image: Fix macro set logic and --net-boot-dhcp processing. | Chris Johns | 2019-06-12 | 1 | -5/+6 |
* | misc/boot-image: Add a tool to create boot images. | Chris Johns | 2019-06-12 | 5 | -0/+1414 |
| | | | | | | | | - FreeBSD support. - MacOS support. - Linux support. - Support for 1st and 2nd loaders. - Support uenv templates and uenv.txt support. | ||||
* | waf: Update the check_cc tests to a newer method supported by waf. | Chris Johns | 2019-05-27 | 1 | -2/+5 |
| | | | | - Fix a minor issue in covoar's use of 64bit calls. | ||||
* | Fix warnings on Windows. | Chris Johns | 2018-11-29 | 1 | -2/+2 |
* | bin2c: Fix warnings | Sebastian Huber | 2018-06-14 | 1 | -1/+0 |
| | | | | Update #3380. | ||||
* | bin2c: Import from RTEMS | Sebastian Huber | 2018-06-14 | 3 | -0/+445 |
Corresponding RTEMS commit is 75933d5d25cd50f80162b7a0d2f66a5534e1763f. Update #3380. |
