2020-09-26 | Move all python commands to use env python | Chris Johns | 1 | -1/+1 | |
- If you host does not provide a python command consult the User manual for ways you can run the python commands. - Full package paths are being used to avoid namespace pollution and crosstalk. | |||||
2014-02-15 | rt: Add the rtems-tester. | Chris Johns | 1 | -0/+30 | |
