* | rtems-bsps-aarch64.ini: Remove trailing comma causing empty BSP name | Joel Sherrill | 2022-09-21 | 1 | -2/+2 |
* | rtems-bsps-aarch64.ini, rtems-bsps-tiers.ini: Remove versal ilp32 variants | Joel Sherrill | 2022-09-07 | 2 | -7/+10 |
* | rtems-bsps-tiers: add new stm32h7 BSP variants to the tier-3 | Karel Gardas | 2022-06-04 | 1 | -1/+2 |
* | rtems-bsps-arm: add new stm32h7 BSP variants | Karel Gardas | 2022-06-04 | 1 | -1/+4 |
* | rtems-bsps.ini: Correct spelling of aarch64 | Joel Sherrill | 2022-02-03 | 1 | -1/+1 |
* | rtems-bsps-tiers.ini: Move appropriate aarch64 BSPs to Tier 1 and 2 | Joel Sherrill | 2022-01-21 | 1 | -9/+10 |
| | | | | | | | This also resulted in finding some BSPs listed which were no longer in the RTEMS source. Updates #4581. | ||||
* | rtems-bsps.ini: Add missing architectures and BSPs | Joel Sherrill | 2022-01-21 | 1 | -4/+16 |
| | | | | The aarch64, microblaze, nios2, and x86_64 needed to be added. | ||||
* | rtems-bsps-arm.ini, config/rtems-bsps.ini: Remove build variance on network | Joel Sherrill | 2022-01-21 | 2 | -11/+1 |
| | | | | | | | | With the legacy TCP/IP stack no longer in rtems.git, there is nothing to turn on/off with regards to BSPs or the stack itself. Removing this significantly reduces the number of configurations built. Closes #4583. | ||||
* | rtems-bsps-tiers.ini: Update comment to use tier 2 definitiion in docs | Joel Sherrill | 2022-01-20 | 1 | -2/+1 |
| | | | | | See rtems-docs/user/hardware/tiers.rst. Tier 2 is test results on simulator not hardware and simulator. | ||||
* | rtems-bsps-tiers.ini: Add missing architectures and BSPs as tier 3 | Joel Sherrill | 2022-01-20 | 1 | -4/+20 |
* | rtems-bsps-x86_64.ini: New file | Joel Sherrill | 2022-01-19 | 1 | -0/+25 |
* | rtems-bsps-microblaze.ini: New file | Joel Sherrill | 2022-01-19 | 1 | -0/+25 |
* | rtems-bsps-aarch64.ini: New file | Joel Sherrill | 2022-01-19 | 1 | -0/+31 |
* | rtems-bsps-riscv.ini: Add missing BSPs | Joel Sherrill | 2022-01-19 | 1 | -1/+3 |
| | | | | | | frdme310arty, griscv, grv32i, grv32im, grv32imac, grv32imafdc, rv32iac, rv32i, rv32imac, rv32imafc, rv32imafdc, rv32imafd, rv32im | ||||
* | rtems-bsps-arm.ini: Add missing BSPs | Joel Sherrill | 2022-01-19 | 1 | -3/+13 |
| | | | | | fvp_cortex_r52, imxrt1052, nucleo-h743zi, stm32h7, xen_virtual, xilinx_zynqmp_ultra96 | ||||
* | tiers: Add AArch64 to tier 1 | Kinsey Moore | 2022-01-19 | 1 | -1/+2 |
| | | | | | | Hardware test results have recently been posted for AArch64. Closes #4581 | ||||
* | rtems-bsps-powerpc.ini: Remove powerpc/halekala | Joel Sherrill | 2022-01-19 | 1 | -1/+0 |
| | | | | Updates #4302. | ||||
* | rtems-bsp-builder: Change to waf build system | Ryan Long | 2021-05-25 | 1 | -14/+14 |
| | | | | Closes #4124 | ||||
* | config: Remove obsolete BSPs | Sebastian Huber | 2020-12-10 | 1 | -10/+8 |
| | | | | Update #3951. | ||||
* | rtems-bsps-tiers.ini: Delete removed PowerPC BSPs | Joel Sherrill | 2020-10-15 | 1 | -5/+4 |
* | Remove support for epiphany target | Sebastian Huber | 2020-07-03 | 3 | -30/+1 |
| | | | | Update #3941. | ||||
* | Change version to RTEMS 6 | Sebastian Huber | 2020-06-30 | 1 | -1/+1 |
| | | | | Update #4020. | ||||
* | gdbarmsim: Remove all variants | Joel Sherrill | 2020-03-20 | 1 | -3/+2 |
| | | | | Updates #3911. | ||||
* | tiers: Move bsps from tier-3 to tier-2 | Chris Johns | 2019-12-14 | 1 | -5/+8 |
| | | | | Closes #3213 | ||||
* | config: Add x86_64 to tier-3 archs | Sebastian Huber | 2019-03-18 | 1 | -1/+1 |
* | Remove m32c support | Sebastian Huber | 2018-11-12 | 3 | -30/+1 |
| | | | | Update #3599. | ||||
* | config: Consolidate the version information into a single configuration file | Chris Johns | 2018-10-03 | 1 | -0/+8 |
* | config: Create a config directory and move the RTEMS arch/bsp data to it. | Chris Johns | 2018-10-02 | 22 | -0/+940 |
Closes #3536 |
