* | config: Remove obsolete BSPs | Sebastian Huber | 2020-12-10 | 1 | -10/+8 |
| | | | | Update #3951. | ||||
* | rtems-bsps-tiers.ini: Delete removed PowerPC BSPs | Joel Sherrill | 2020-10-15 | 1 | -5/+4 |
* | Remove support for epiphany target | Sebastian Huber | 2020-07-03 | 3 | -30/+1 |
| | | | | Update #3941. | ||||
* | Change version to RTEMS 6 | Sebastian Huber | 2020-06-30 | 1 | -1/+1 |
| | | | | Update #4020. | ||||
* | gdbarmsim: Remove all variants | Joel Sherrill | 2020-03-20 | 1 | -3/+2 |
| | | | | Updates #3911. | ||||
* | tiers: Move bsps from tier-3 to tier-2 | Chris Johns | 2019-12-14 | 1 | -5/+8 |
| | | | | Closes #3213 | ||||
* | config: Add x86_64 to tier-3 archs | Sebastian Huber | 2019-03-18 | 1 | -1/+1 |
* | Remove m32c support | Sebastian Huber | 2018-11-12 | 3 | -30/+1 |
| | | | | Update #3599. | ||||
* | config: Consolidate the version information into a single configuration file | Chris Johns | 2018-10-03 | 1 | -0/+8 |
* | config: Create a config directory and move the RTEMS arch/bsp data to it. | Chris Johns | 2018-10-02 | 22 | -0/+940 |
Closes #3536 |
