Updates #4111
Closes #4112
Updates #4111
Add any weak symbols that have been linked into the base image to the
global symbol table. A weak symbol is global when view viewed from
a dynamically loaded module.
Closes #2704.
On certain targets (e.g. PowerPC) global data below a certain threshold
(e.g. 8 bytes) may resided in a special memory area, the small-data
area. This allows more efficient load/store operations. Placing such
data into the wrong section (e.g. .rodata) leads to relocation errors
during link-time. See test program libtests/dl02 in the RTEMS
testsuite. Using an array of unspecified size prevents that the
compiler assumes that a certain variable is in the small-data area.
Updates #2619.
The conversion to Python3 added an eval() call which is wrong.
Fix the spelling in execute.
Fix labels in the tester gdb locking.
Check the debug-trace arguments.
Close #2642.
Updates #2619.
Add solaris and netbsd.
Close #2619.
This patch is based on this post ..
https://lists.gnu.org/archive/html/automake-patches/2015-07/msg00000.html
This warnign appears with a recent MSYS2.
Update #2616.
Limit the compilers used to gcc and clang. Clang has not been tested.
Users with MSVC install does not need to remove now.
Force the os.sep path to the standard '\\' on Windows. The MSYS2 python
sets it to '/' for internal project reasons. Doing this does cause waf
problems when running configure so only do this for the build target.
Closes #2583.
Installing PYO and PYC does not work so disable this. Move the
Python check to the top level and have a single place.
Closes #2582.
Thanks to ita for the example.
One section is supported [version] with a 'release' entry.
Support a top level VERSION file that defines an RTEMS release.
Fix the install of the python modules including thertems-test.
Update the git python module to the RSB version. Fix the options to
not call clean and to call dirty.
Update the version python module.
Fix the rtld C++ support to the VERSION file and the top level waf
script.
The rtems-tester does not thing the tests run correctly because
the test output is coming to the terminal window with tsim running
in it.
These require a GDB >= 7.9 with Jiri Gaisler's patches applied.
These are currently in the RSB and are in the process of being
merged by the GDB project.
Seacch the path for the program name if not found and set it as
an absolute path. This allow the prefix to be found.
This patch set adds a lot of new capability including support for
the leon2 and leon3. It also eliminates the difference between
the initial state of the simulated erc32 and the real hardware.
This gives the tools the ability to extract all needed data from the
executable.
Fixes #2312.
Trace buffering traces into a static buffer complete with timestamp
and the executing context.
A shell command provides access to the data.
Generators can control a lock and buffer allocation so a single
alloc can happen and a lock released.
Move the options to a section so an option can be a single line. This
gives the user the ability to localise specific configurations in a
top level configuration file.
Provide support for names, enables and triggers. Names is an array of
names of the trace functions. The table is sorted and you can use an
index to reference the trace function. There is a @FUNC_INDEX@ macro
that is replaced with the trace function's index. Enables is a bitmap
of default trace enabled states for all trace functions. Triggers is
a bitmap of default triggers bit states for each trace function.
Generators can use these bitmaps to control functionality.
Currently the bitmaps are const but a generator option can be added
to disable the const and allow the capture engine access to update
the bitmaps.
The commit references #2312.
