Add support in tester to run covoar and generate an html report to display
the summary of the coverage reports generated from covoar.
Co-authored-by : Cillian O'Donnell <cpodonnell8@gmail.com>
The patches fix the endian checks in the simulator, print filtering,
and the run command.
Updates #2644.
Support a top level VERSION file that defines an RTEMS release.
Fix the install of the python modules including thertems-test.
Update the git python module to the RSB version. Fix the options to
not call clean and to call dirty.
Update the version python module.
Fix the rtld C++ support to the VERSION file and the top level waf
script.
Add support to build all parts of The RTEMS Tools project.
Also add a git ignore.
