2012-09-13 | pc386/console: alternative framebuffer implementation for cirrus GD5446 QEMU ↵ | Pavel Pisa | 1 | -0/+7 | |
device Command-line option -D configures Cirrus GD5446 PCI display adapter emulation in QEMU environment. QEMU option -vga cirrus Signed-off-by: Pavel Pisa <pisa at cmp.felk.cvut.cz> | |||||
2012-06-12 | v850sim: New script for GDB v850 simulator | Joel Sherrill | 3 | -1/+32 | |
2012-06-12 | gdb-sim-run.in: Add skip interrupt critical section tests option | Joel Sherrill | 1 | -6/+21 | |
This is the -S option. These take a long time to run and will never produce any useful results if the BSP uses the IDLE Clock Tick implementation. | |||||
2012-05-29 | pc386.in - qemu may now be named qemu-system-i386 | Joel Sherrill | 1 | -1/+13 | |
2012-05-15 | rtems-testing - Remove CVS Ids (manual edits) | Joel Sherrill | 7 | -15/+0 | |
2012-05-15 | XXX | Joel Sherrill | 2 | -0/+0 | |
2012-05-15 | rtems-testing - Remove CVS Ids (scripted) | Joel Sherrill | 35 | -74/+0 | |
2012-01-14 | Rename .cvsignore to .gitignore. | Joel Sherrill | 1 | -0/+0 | |
2011-12-01 | 2011-12-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -1/+9 | |
* jmr3904.in: Add Data Bus Error to detected faults to exit simulator on. | |||||
2011-11-06 | 2011-11-06 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -1/+6 | |
* uC5282.in: Use grep -E rather rather than egrep as Open Group has marked it legacy. | |||||
2011-11-06 | 2011-11-06 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 3 | -1/+16 | |
* sis.in: Increase memory. * uC5282.in: Add pattern for exception meaning program end. | |||||
2011-11-04 | 2011-11-04 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 3 | -2/+9 | |
* pc386.in: Use CPU supported by older qemu. * uC5282.in: Use trace argument supported by newer qemu. | |||||
2011-09-24 | 2011-09-24 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 4 | -1/+49 | |
* lm3s6965.in.: New file. * Makefile: Reflect change above. | |||||
2011-09-16 | 2011-09-16 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 4 | -26/+8 | |
* check_endof: Update due to test case output changes. * gdb-sim-run.in: Run more test cases. * sis.in: Use 180 seconds time limit for all test cases. | |||||
2011-08-31 | 2011-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 3 | -2/+8 | |
* gdb-sim.in: Default bspDoTrace variable to no. * qemuppc.in: Update arguments to match newer qemu. | |||||
2011-08-21 | 2011-08-21 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -0/+5 | |
* gdb-sim.in: Initialize doTrace variable. | |||||
2011-07-20 | 2011-07-20 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 4 | -16/+37 | |
* gdb-sim-run.in: Add option to skip critical section tests. * pc386.in: Default to core2duo CPU. * rtems-gdb-macros-4.11: Update to 4.11. | |||||
2011-03-14 | 2011-03-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -0/+5 | |
* gdb-sim-run.in: Add another generic failure message. | |||||
2011-03-13 | 2011-03-13 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2 | -0/+5 | |
* pc386.in: Add another failure message. | |||||
2011-02-14 | 2011-02-14 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2 | -4/+4 | |
* gdb-sim-run.in: math tests now run. | |||||
2011-02-10 | 2011-02-10 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2 | -0/+8 | |
* gdb-sim-run.in: Add math tests as link only. | |||||
2011-02-07 | 2011-02-07 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -1/+5 | |
* gdb-sim-run.in: Match ACATS failure messages correctly. | |||||
2011-02-06 | 2011-02-06 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 3 | -2/+8 | |
* gdb-sim-run.in, pc386.in: Messages have changed. | |||||
2011-01-28 | 2011-01-28 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -1/+6 | |
* pc386.in: Now running Go tests on PowerPC (2/3 passing) and i386 (in process). | |||||
2011-01-21 | 2011-01-21 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2 | -4/+5 | |
* gdb-sim-run.in: Remove lines which break running tests in RTEMS and gcc tests suite frameworks. | |||||
2010-11-05 | 2010-11-05 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 4 | -3/+15 | |
* gdb-sim-run.in, gdb-sim.in, psim.in: Add trace support. | |||||
2010-11-05 | 2010-11-05 Chris Johns <chrisj@rtems.org> | Chris Johns | 1 | -2/+9 | |
* sim-scripts/gdb-sim-run.in: Fix logdir option. | |||||
2010-07-22 | 2010-07-21 Vinu Rajashekhar <vinutheraj@gmail.com> | Joel Sherrill | 2 | -1/+5 | |
* pc386.in: Add Go support. Plus some cleanup from Joel. | |||||
2010-07-20 | 2010-07-20 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 3 | -2/+6 | |
* gdb-sim-run.in, gdb-sim.in: Use bash. | |||||
2010-07-08 | 2010-07-08 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2 | -19/+23 | |
* gdb-sim-run.in: Changed non-interactive test run status messages. | |||||
2010-07-07 | 2010-07-07 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 3 | -15/+5 | |
* gdb-sim-run.in, skyeye-support: Removed special case for fatal tests. | |||||
2010-07-01 | 2010-07-01 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2 | -0/+5 | |
* tsim-support: Increase time limit for block05. | |||||
2010-06-22 | 2010-06-22 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2 | -1/+6 | |
* tsim-support: Increase stack check tests maximum run allowed to 15 seconds of simulated CPU time for tsim SPARC simulators. | |||||
2010-06-04 | 2010-06-04 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 5 | -3/+1073 | |
* Makefile, gdb-sim-run.in, gdb-sim.in: Add 4.11 support. * rtems-gdb-macros-4.11: New file. | |||||
2010-05-10 | 2010-05-10 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 4 | -5/+13 | |
* gdb-sim-run.in: Use 50 millisecond per period. * pc386.in: Switch from 486 to qemu32 CPU model. * qemu-lm32_evr.in: Increase time limits on some tests. | |||||
2010-04-20 | 2010-04-20 Joel Sherrill <joel.sherrilL@oarcorp.com> | Joel Sherrill | 7 | -29/+139 | |
* .cvsignore, Makefile, bf537Stamp.in, ezkit533.in: Move current scripts to skyeye named ones so the default is to use the new simulator in gdb. * bf537Stamp-skyeye.in, ezkit533-skyeye.in: New files. | |||||
2010-04-13 | 2010-04-13 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -1/+5 | |
* pc386.in: Specify CPU as 486 | |||||
2010-03-23 | 2010-03-23 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2 | -0/+5 | |
* .cvsignore: Add qemu-lm32_evr. | |||||
2010-03-23 | 2010-03-23 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 3 | -1/+57 | |
* Makefile: Probe for parallelism. * qemu-lm32_evr.in: New file. | |||||
2010-03-11 | 2010-03-11 Joel Sherrill <joel.sherrilL@oarcorp.com> | Joel Sherrill | 5 | -6/+13 | |
* pc386.in, qemu-gumstix.in, qemu-leon2.in, qemuppc.in: Use qemu on path. | |||||
2010-01-14 | 2010-01-14 Glenn Humphrey <glenn.humphrey@OARcorp.com> | Glenn Humphrey | 2 | -1/+5 | |
* pc386.in: Should not have committed localized path to qemu. | |||||
2010-01-13 | 2010-01-13 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -2/+6 | |
* qemuppc.in: Fix path and coverage output file name. | |||||
2010-01-13 | 2010-01-13 Glenn Humphrey <glenn.humphrey@OARcorp.com> | Glenn Humphrey | 6 | -35/+14 | |
* gdb-sim-run.in, pc386.in, qemu-gumstix.in, qemuppc.in, uC5282.in: Removed explicit conversion from a trace. It is now being read as a trace from covmerge. | |||||
2009-10-30 | add qemuppc support | Thomas Doerfler | 1 | -1/+3 | |
2009-10-19 | 2009-10-19 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -0/+5 | |
* gdb-sim-run.in: Attempt to detect assertions as generic exits. | |||||
2009-10-16 | 2009-10-16 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 3 | -0/+12 | |
* check_endof: Add minimum. * qemuppc.in: Add trace conversion. | |||||
2009-10-12 | 2009-10-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 28 | -4/+42 | |
* ant5206.in, avrtest.in, bf537Stamp.in, csb337.in, csb350.in, csb360.in, ezkit533.in, gdb-sim-run.in, gdbarmsim.in, gumstix.in, h8sim.in, jmr3904.in, lm32_evr.in, m32csim.in, m32rsim.in, pc386.in, psim.in, qemu-gumstix.in, qemu-leon2.in, qemuppc.in, rtl22xx.in, simsh.in, sis.in, skyeye-support, smdk2410.in, tsim-support, uC5282.in: Add running minimum to pick up path where there are no Classic API Initialization Tasks. Minimum has IDLE task as first application task. | |||||
2009-10-01 | Add script to run gdb ARM simulator. | Joel Sherrill | 5 | -4/+50 | |
2009-09-30 | 2009-09-30 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 5 | -7/+88 | |
* .cvsignore, Makefile, gdb-sim-run.in: Add QEMU Gumstix Connex support. * qemu-gumstix.in: New file. | |||||
2009-09-27 | 2009-09-27 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 15 | -18/+36 | |
* avrtest.in, ezkit533.in, h8sim.in, jmr3904.in, lm32_evr.in, m32csim.in, m32rsim.in, pc386.in, psim.in, qemu-leon2.in, qemuppc.in, simsh.in, sis.in, uC5282.in: Fix typos. Support coverage and adjust run times on uC5282. |
