Closes #2442.
closes #2447.
updates #2453.
* lm3s6965.in.: New file.
* Makefile: Reflect change above.
* Makefile, gdb-sim-run.in, gdb-sim.in: Add 4.11 support.
* rtems-gdb-macros-4.11: New file.
* .cvsignore, Makefile, bf537Stamp.in, ezkit533.in: Move current
scripts to skyeye named ones so the default is to use the new
simulator in gdb.
* bf537Stamp-skyeye.in, ezkit533-skyeye.in: New files.
* Makefile: Probe for parallelism.
* qemu-lm32_evr.in: New file.
* .cvsignore, Makefile, gdb-sim-run.in: Add QEMU Gumstix Connex
support.
* qemu-gumstix.in: New file.
* .cvsignore, Makefile: Rename most qemu scripts to match the BSP name.
qemu-leon2 not renamed since we prefer tsim for it.
* pc386.in, qemuppc.in, uC5282.in: New files.
* qemu-ppc.in, qemu-rtems.in, qemu-uc5282.in: Removed.
* .cvsignore, Makefile, qemu-uc5282.in: Add script to run qemu-ppc
simulator.
* qemu-ppc.in: New file.
* .cvsignore, Makefile: Add lm32_evr simulator script support.
* lm32_evr.in: New file.
* Makefile, gdb-sim.in: Add RTEMS GDB macro packages as they exist
today. This provides a baseline which can be used to improve them.
* rtems-gdb-macros-4.10, rtems-gdb-macros-4.7, rtems-gdb-macros-4.8,
rtems-gdb-macros-4.9: New files.
* Makefile: Add script to check for END OF test messages.
* check_endof: New file.
* .cvsignore, Makefile: Add initial version of Qemu uc5282 and LEON2
scripts.
* qemu-leon2.in, qemu-uc5282.in: New files.
* Makefile, gdb-sim-run.in, gdb-sim.in, mkrun, skyeye-support,
tsim-support: GDB now works with tsim and skyeye simulator BSPs.
* .cvsignore, Makefile, edb7312.in, gdb-sim-run.in, skyeye-support: Add
support for invoking a simulator external to gdb in gdb server mode.
Have the gdb commands generated to include attaching to that server
instance.
* .cvsignore, Makefile, gdb-sim-run.in: Add support for avrtest BSP
using simulavrxx.
* avrtest.in: New file.
* Makefile: Fix dependencies on tsim scripts.
* edb7312.in: Disable instruction limit until tuned. Only do coverage
on 1 MB of RAM. Code is smaller than that and it is faster.
* gdb-sim-run.in: Clean up killing simulator to hopefully avoid
zero length coverage files.
* rtl22xx.in: Attempt to add coverage and shutdown device support.
* smdk2410.in: Add coverage and shutdown device support.
* tsim-support: Tune time limits.
* Makefile: Add Gumstix on Skyeye script.
* gumstix.in: New file.
* .cvsignore, Makefile: Add first cut at script to run leon2 BSP on
Skyeye.
* leon2-skyeye.in: New file.
* Makefile: Add nosim.
* nosim: New file.
* .cvsignore, Makefile, gdb-sim-run.in, gdb-sim.in, skyeye-support: Add
qemu-rtems script.
* qemu-rtems.in: New file.
* .cvsignore, Makefile, erc32.in, gdb-sim-run.in, mkrun: Add TSIM
support for ERC32, LEON2, and LEON3 BSPs. Include using all three for
coverage.
* leon2.in, leon3.in, tsim-support: New files.
* .cvsignore, Makefile, README, gdb-sim-run.in: Add first cut at ERC32.
Need to test on machine with TSIM license.
* erc32.in: New file.
* .cvsignore, Makefile: Add rest of Skyeye configurations whether
they work completely at this point or not.
* ant5206.in, bf537Stamp.in, csb337.in, csb350.in, csb360.in,
ezkit533.in, rtl22xx.in, smdk2410.in: New files.
* Makefile, edb7312.in, gdb-sim-run.in, gdb-sim.in, h8sim.in,
jmr3904.in, m32csim.in, m32rsim.in, psim.in, simsh.in, sis.in,
skyeye-support: Find run or gdb along PATH. Check for multiple RTEMS
versions so there is only one version of the script. Default the
simulator name so the BSP specific files do not have to do as much.
* .cvsignore, Makefile, gdb-sim-run.in, gdb-sim.in, h8sim.in,
jmr3904.in, m32csim.in, m32rsim.in, mkrun, psim.in, simsh.in, sis.in:
Add ARM/edb7312 support. This is the first Skyeye BSP and adding this
required tinkering with all BSP scripts. All appear to still work OK.
* edb7312.in, skyeye-support: New files.
* .cvsignore, Makefile, gdb-sim-run.in, gdb-sim.in: Add psim support.
* psim.in: New file.
* .cvsignore, Makefile, jmr3904.in, mkrun: Now generate gdb script for
h8sim, jmr3904 m32csim, m32rsim, simsh and sis.
* gdb-sim.in: New file.
* .cvsignore, Makefile: Switch to using script to do sed and add
versioning on installation.
* mkrun: New file.
* .cvsignore, Makefile, gdb-sim-run.in: Add m32csim, m32rsim, and
simsh.
* m32csim.in, m32rsim.in, simsh.in: New files.
* .cvsignore, Makefile, gdb-sim-run.in: Add h8300/h8sim.
* h8sim.in: New file.
* ChangeLog, Makefile, README, gdb-sim-run.in, jmr3904.in,
usleep.c: New files.
