- Move the qemu config to a common file shared by qemu and qemu4.
- Disable nettle on qemu4, FreeBSd complained.
- Add some extra git cleaning steps to the git path. These however
do not full clean the qemu submodules and it is not worth the
effort to try and fix.
- The devel/qemu will not build on machines with python set to
python3. This will not be fixed, use qemu4.
Closes #3966
Starting with Python 3.8, python3-config requires the "--embed" flag to
print the flags required for embedding Python in an application.
Fixes:
error: shell macro failed: /home/anders/work/rtems/rsb/source-builder/sb/rtems-build-dep -c gcc -l : 2: error: no library (-l) provided
Signed-off-by: Anders Montonen <Anders.Montonen@iki.fi>
The platform.dist() interface has been deprecated since Python 3.5, and
has been removed in Python 3.8.
Fixes:
Traceback (most recent call last):
File "/home/anders/work/rtems/rsb/source-builder/sb/options.py", line 682, in load
overrides = linux.load()
File "/home/anders/work/rtems/rsb/source-builder/sb/linux.py", line 60, in load
distro = platform.dist()[0]
AttributeError: module 'platform' has no attribute 'dist'
Fixes:
SyntaxWarning: "is" with a literal. Did you mean "=="?
* There is no all$ target in Spike
* There is no longer --with-fesvr flag since fesvr is source-inlined
by default
Adds a --sanitize option to command line for reports.py
and also for the reports.report() interface from setbuilder.py
to remove the Remotes information from git.
Closes #3887.
closes #3927.
The error path is taken when list-bsets or list-cfgs returns
true (meaning it listed them). So the error is invalid.
- Use this command to get a smaller sha512 checksum
Update the glib version to 2.48.2 in order to fix build failure on newer
gcc[0].
Force internal version of libpcre for glib, since otherwise the build
failed, presumably since libpcre is not provided as a module (maybe it
should?).
Increasing the glib version further to the current latest was not
tested.
[0]
CC libglib_2_0_la-gdate.lo
../../glib-2.39.3/glib/gdate.c: In function 'g_date_strftime':
../../glib-2.39.3/glib/gdate.c:2497:7: error: format not a string literal, format string not checked [-Werror=format-nonliteral]
tmplen = strftime (tmpbuf, tmpbufsize, locale_format, &tm);
The previous implementation does not work on some Linux distributions,
e.g. Debian on sparc64. Use a standard function instead.
- The release procedure uses the sb-set-sources command now.
Closes #3896
Closes #3893
- Looks like protobuf is now not under Google. I failed to notice that.
- Caching on name falsely assumed checks across different config
instances in nested build sets as used in vertical stack
building was valid. This stopped a valid check for a prefix
seeing if a valid BSP config was present.
Updates #3893
Updates #3893
Updates #3893
- The bsdtar command does not handle symlinks cleanly, GNU tar does
Closes #3868
This helps to avoid issues with user names which contain space
characters.
Close #3830.
Close #3781.
- Use the same VERSION file format as rtems-tools so a common release
generation can be used.
- The version.py is almost the same as rtems-tools. There are some
minor differences, one is the RTEMS version is present in this
file while rtems-tool uses config/rtems-release.ini.
Updates #3822
Updates #3814
Latest Spike integrated fesvr in its source directory, so there
is no separate fesvr anymore.
Also use a revision of Spike that fixes the file permissions
when getting installed.
The local host overrides have to be loaded so host specific commands
and settings can be found and used.
- Fix GDB's library checks to ignore errors when getting the source.
- Add line continuation support so empty macros can be used at
the end of configure command lines, ie RTEMS kernel. The
config parser removes empty lines and wihout this support a
trailing line continuation character joins a configure command
line to next command.
- Fix freetype's gmake support for non-GNU operating systems.
Split only on the first '=' in an option so BSPOPTS can contain
an '='.
Tar on Windows raises an error if a symlink appears before the target.
Windows needs the target to exist before a link can be created. This
patch adds support via the -E option to catch the error and rerun the
tar command a second time. The symlink should work as the target should
exist on the second pass.
Updates #3802.
- Add '%source download <source>' to only download the source
and do not unpack and prep. This can used when a package
internally needs another source package.
- Install the staging root only if it is present. A package
may internally build another package that is not staged as it
is not suitable for installing.
Updates #3250
Updatew #3797
