- Include build sizes in the email report.
Updates #3516
- Track the size of a build of a package in a build set to determine the
maximum amout of disk space used. This can be used as a guide to
documenting how much space a user needs to set aside to build a specific
set of tools.
- The `%clean` stage of a build is now split into a separate script.
I do not think this is an issue because I could not find any `%clean`
sections in any build configs we have. In time support for the
`%clean` section will be removed, the package builder cleans up.
Closes #3516
Close #3519.
Updates #3460
The Binutils and GDB share a repository. In order to build the GDB
from a repository snapshot some components must be disabled.
Update #3453.
The Binutils and GDB share a repository. In order to build the Binutils
Update #3452.
Add a build set and configuration to build a QEMU we can use for
coverage testing.
Do not generate files which are part of the Git repository. These files
should be maintained manually in the future.
Update #3285.
A dirname of / is / so the path will never have a length of 0.
Close #3392
This changes the previous functionality where the RSB switch to
dry run mode. This functionality can be enabled by adding
`--keep-going`.
Close #3209.
Close #3315
Closes #3312
Signed-off-by: Maksim E. Kozlov <maksim.e.kozlov@gmail.com>
The option expansion is missing `--with-download'.
Using the RSB release version for the gcc version string means the
tools have a version string that matches the release.
Close #3294
is_abspath() now considers zero-length strings
Also: Remove not needed line in expand()
In order to build a tool chain with Ada support a native GCC with Ada
support of the same version as the cross compiler is required. The RSB
used hard coded paths for the gcc and g++ programs. This forced the RSB
user to change the main GCC installation of the machine to build a
particular RTEMS tool chain. This is undesired/infeasible in most
situations.
Close #3284.
Fix a minor issue in the log module.
The orphans check lets you see which configuration and build set
files in the RSB are not referernced. You can audit the list and
remove any configuration files not being used. Top level
build set files are included so you need to becareful not to
remove something that is valid and useful. To run:
$ ./source-builder/sb-check --check-orphans
Updates #3520.
Update #3220.
Update #3109
- Fix a minor bug in the to addr processing.
Update #3210
Close #3210.
Update #3210.
- Increase the tail logged to 400 lines.
Update #3210.
Updates #3210.
- Add an is_abspath call.
- Convert the path or paths to shell paths on entry to all path
calls. This is safe to do for a path that is already a shell path.
- Fix exists to use shell paths.
Updates #2536.
This is needed to test #2536.
Add an option to disable any log.
Updates #2536.
Updates #2536.
Closes #3157.
Closes #2960.
Newer makeinfo tools cannot build the existing texinfo in gcc so
disable building it. This will not be fixed on the gcc branch.
Updates #3027.
The change lets the LM32 target build on Windows which has temporary
install paths greater than the Win32 API max size. The buildroot path
compression is still needed as the GNU assembler does not like paths
that exceed the max Windows limit.
Closes #2992.
The RSB documentation is now in ReST format and part of the RTEMS
Documentation project. See https://docs.rtems.org/.
Remove support for the GPL based asciidoc tool and remove the
asciidoc package from the RSB.
Add the Python Markdown package and update the reporter to use
Markdown for HTML generation. The resuling HTML report is a single
self contained file.
Closes #3047.
The released sources use the local file name so always force it when
the RSB is released.
Closes #3064.
Archlinux provides both, libguile v2.0 and v2.2. GDB states in
configuration its compatibility with both versions of libguile which is
false. The SCM_port interface of libguile was removed in v2.2 and
therefore breaks GDB as a user.
RTEMS does not use libguile and therefore it can be compiled without
support.
https://sourceware.org/bugzilla/show_bug.cgi?id=21104
Close #3054.
Enable traceability from the error message to the script location. This
eases debugging.
